Loading...
Pages: [1]   Go Down
Author Topic: Can my UNO or MEGA run of of 15v dc safely???  (Read 436 times)
Los Angeles
Offline Offline
Jr. Member
View Profile
WWW
In doing a project which uses an UNO to drive a laser galvo.
The galvo has a 15v power supply.  It would be great to tap into that to power the arduino rather than getting a second power supply since space is limited in the project box.
Is it safe to run the arduino off of the same 15v power supply???  Ive never used an arduino with anything other than 5V...
Logged
Pittsburgh, PA, USA
Offline Offline
Faraday Member
I only know some basic electricity....
View Profile
http://arduino.cc/en/Main/ArduinoBoardUno
Quote
Summary
Microcontroller   ATmega328
Operating Voltage   5V
Input Voltage (recommended)   7-12V
Input Voltage (limits)   6-20V
At over 12V the 5V regulator will likely get very warm even without pulling much load.
You can look up the MEGA here, the practice will do you good. Without it you are dependent on others.
http://arduino.cc/en/Main/Hardware
Here is another good place to find answers to what 90% of questions seem to be.
http://arduino.cc/en/Tutorial/Foundations
Logged
Examples can be found at Learning in the Main Site and at the Playground
Manchester (England England)
Online Online
Brattain Member
Solder is electric glue
View Profile
WWW
Quote
I would say yes. The major limiting factor is the voltage rating of the electrolytic capacitors on the input. On my Uno these are 25V so 15V should pose no problems.
Yes the regulator will run hotter but this is unlikely to be a problem unless you draw a lot of current off the 5V lines. For a discussion of how much hotter see:-
http://www.thebox.myzen.co.uk/Tutorial/Power.html
and the specific issue of the arduino board is shown here:-
http://www.thebox.myzen.co.uk/Tutorial/Power_Examples.html
Logged
Ft. Worth, Texas
Offline Offline
God Member
View Profile
Could always add a 9V regulator for the arduino, couldn't you? Would be easy insurance to me.
Logged
KF5RVR
Offline Offline
Newbie
View Profile
Drop the voltage using a series of diodes (properly rated), i'm also about to use them to reduce a 5v supply to 4.5v range.
Logged
Online Online
Brattain Member
View Profile
WWW
I have been running my arduino from 15V all day today developing a project that needs 15V to drive some coils, there has been no noticeable heating on the regulator.
Logged
Pages: [1]   Go Up
Print
Jump to:
