Topic: Variable DC (Read 1 time) previous topic - next topic
Pokey
Hello all,
I need a simple way to dim some 12vdc lights manually. I tried a few AC dimmer switches (the ones that are usually used for house lighting), but I couldn't get any 12vdc to flow through them.
This is probably a really simple/stupid question...but are there special DC dimmer switches?  :smiley-red:
TIA
magnethead794
High-power Potentiometer or Rheostat, that can handle the load (amps)?
Grumpy_Mike
Quote
Yes they are used for dimming LEDs. You can get DC SSRs and feed them with a PWM signal from the arduino.
The normal mains dimmers will not work on DC as they require the fact that AC goes to zero volts twice a cycle to turn them off. This is because they use a Triac.
http://en.wikipedia.org/wiki/TRIAC
terryking228
hi,
You need power transistors and Arduino PWM to dim 12 volt lights..
Here's an example: http://arduino-info.wikispaces.com/ArduinoPower (near the bottom)
Here's a photo:
There is example arduino dimming code at bottom of that page...
Regards, Terry King terry@yourduino.com  - Check great prices, devices and Arduino-related boards at http://YourDuino.com
HOW-TO: http://ArduinoInfo.Info
Pokey
Thank you all for your replies, they are much appreciated!
I just need a simple solution this time, so I went with an adjustable 100w power resistor capable of handling the 80 watts of lighting. Rheostats at that power rating are far too expensive for me.
