Topic: Windows/Linux/Mac Eclipse plugin to compile and upload arduino sketches (Read 394534 times) previous topic - next topic
Jantje
For teensy just add [teensyduino]/hardware/teensy to the private hardware
you probably also want to add [teensyduino]/libraries to your private libraries
Private libraries can be the parent or the root of the library.
If the private library folder you provide contains a .h file it is considered a library, else it is consider the parent of libraries.
As far as I remember there are no known bugs in this area.
Best regards
Jantje
Do not PM me a question unless you are prepared to pay for consultancy.
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
adim
Hello again and thank you for your response,
i have added teensy in the private hardware path and also i have added the directory of my libraries to the private software path. All the libraries contain the header files but when i try to add a library to the selected project, the list is empty and now i  get a " Unhandled event loop exception" error. Also teensy board has not be added to the "platform and board" menu.
Thank you
walterpre
Hi Jantje,
I installed the Eclipse Pluin on Mac (Eclipse Photon). I added the hardware platform "Adafruit/hardware/samd/1.2.1" and want to use "Adafruit Metro M4 (SAMD51)" board.
I could select the board in the properties menu of the project. If I verify the sketch, there is the following error:
/Users/walter.prechtl/eclipse/cpp-latest-released/Eclipse.app/Contents/Eclipse/arduinoPlugin/packages/adafruit/hardware/samd/1.2.1/cores/arduino/Arduino.h:48:17: fatal error: sam.h: No such file or directory
 #include "sam.h"
Do you know, how to install and include "sam.h"?
Jantje
It should work. I can't tell based on the info you provided what could be the root cause.
However eclipse provides all the tools and openness to find out yourself.
Things to check
Are you running Sloeber V4.3?
Does this also happen with a new default sketch?
Does the indexer find the sam.h file
Is the package correctly installed?
Is the package dependent on another package?
And if so is that one properly? installed
looping04
Just thanks for your very good work, it's very more easy to use than the standard arduino editor
Pinja
Firstly, love this plugin! I've got a bit of a weird situation though... I've got a sketch to run on an Atmega2560. Everything compiles, everything works, but in the code window Serial1 is underlined red and flagged Symbol 'Serial1' could not be resolved. But when I compile I get 0 errors, 0 warnings, and like I said everything works, but the error flag in the code remains. It's not actually causing an issue, but the red marks feel like they are mocking me!
Jantje
edje11
I'm trying to compile the basicOTA.ino sample with Sloeber 4.3 for the esp32 but keep getting error's.
It's totally not clear to me what's wrong.
For the esp8266 it works fine and the other (the one i tried) esp32 samples didn't gave me troubles.
I tried a lot of suggestions that where found on Github and google but nothing helped me.
Jantje
edje11
Hi Jantje,
Thanks for the quick reply, the solution from issue 1028 will indeed solve the # include filename error, however the other error is still there.
Code: [Select]
"C:\sloeber\/arduino-esp32/tools/xtensa-esp32-elf/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM -DMBEDTLS_CONFIG_FILE="mbedtls/esp_config.h" -DHAVE_CONFIG_H "-IC:\sloeber\/arduino-esp32/tools/sdk/include/config" "-IC:\sloeber\/arduino-esp32/tools/sdk/include/bluedroid" "-IC:\sloeber\/arduino-esp32/tools/sdk/include/bluedroid/api" "-IC:\sloeber\/arduino-esp32/tools/sdk/include/app_trace" "-IC:\sloeber\/arduino-esp32/tools/sdk/include/app_update" "-IC:\sloeber\/arduino-esp32/tools/sdk/include/bootloader_support" "-IC:\sloeber\/arduino-esp32/tools/sdk/include/bt" "-IC:\sloeber\/arduino-esp32/tools/sdk/include/driver" "-IC:\sloeber\/arduino-esp32/tools/sdk/include/esp32" "-IC:\sloeber\/arduino-esp32/tools/sdk/include/esp_adc_cal" "-IC:\sloeber\/arduino-esp32/tools/sdk/include/esp_http_client" "-IC:\sloeber\/arduino-esp32/tools/sdk/include/esp_https_ota" "-IC:\sloeber\/arduino-esp32/tools/sdk/include/esp-mqtt" "-IC:\sloeber\/arduino-esp32/tools/sdk/include/esp-tls" "-IC:\sloeber\/arduino-esp32/tools/sdk/include/ethernet" "-IC:\sloeber\/arduino-esp32/tools/sdk/include/fatfs" "-IC:\sloeber\/arduino-esp32/tools/sdk/include/freertos" "-IC:\sloeber\/arduino-esp32/tools/sdk/include/heap" "-IC:\sloeber\/arduino-esp32/tools/sdk/include/http_server" "-IC:\sloeber\/arduino-esp32/tools/sdk/include/jsmn" "-IC:\sloeber\/arduino-esp32/tools/sdk/include/log" "-IC:\sloeber\/arduino-esp32/tools/sdk/include/mdns" "-IC:\sloeber\/arduino-esp32/tools/sdk/include/mbedtls" "-IC:\sloeber\/arduino-esp32/tools/sdk/include/mbedtls_port" "-IC:\sloeber\/arduino-esp32/tools/sdk/include/newlib" "-IC:\sloeber\/arduino-esp32/tools/sdk/include/nvs_flash" "-IC:\sloeber\/arduino-esp32/tools/sdk/include/openssl" "-IC:\sloeber\/arduino-esp32/tools/sdk/include/spi_flash" "-IC:\sloeber\/arduino-esp32/tools/sdk/include/sdmmc" "-IC:\sloeber\/arduino-esp32/tools/sdk/include/smartconfig_ack" "-IC:\sloeber\/arduino-esp32/tools/sdk/include/spiffs" "-IC:\sloeber\/arduino-esp32/tools/sdk/include/tcpip_adapter" "-IC:\sloeber\/arduino-esp32/tools/sdk/include/tcp_transport" "-IC:\sloeber\/arduino-esp32/tools/sdk/include/ulp" "-IC:\sloeber\/arduino-esp32/tools/sdk/include/vfs" "-IC:\sloeber\/arduino-esp32/tools/sdk/include/wear_levelling" "-IC:\sloeber\/arduino-esp32/tools/sdk/include/xtensa-debug-module" "-IC:\sloeber\/arduino-esp32/tools/sdk/include/lwip" "-IC:\sloeber\/arduino-esp32/tools/sdk/include/coap" "-IC:\sloeber\/arduino-esp32/tools/sdk/include/console" "-IC:\sloeber\/arduino-esp32/tools/sdk/include/expat" "-IC:\sloeber\/arduino-esp32/tools/sdk/include/json" "-IC:\sloeber\/arduino-esp32/tools/sdk/include/newlib" "-IC:\sloeber\/arduino-esp32/tools/sdk/include/nghttp" "-IC:\sloeber\/arduino-esp32/tools/sdk/include/soc" "-IC:\sloeber\/arduino-esp32/tools/sdk/include/wpa_supplicant" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -Wall -Werror=all -Wextra -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti -MMD -c -DF_CPU=240000000L -DARDUINO=10802 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ARDUINO-ESP32 -DARDUINO_BOARD="ESP32_DEV" -DARDUINO_VARIANT="doitESP32devkitV1"  -DESP32 -DCORE_DEBUG_LEVEL=0    -I"C:\sloeber\arduino-esp32\cores\esp32" -I"C:\sloeber\arduino-esp32\variants\doitESP32devkitV1" -I"C:\sloeber\arduino-esp32\libraries\ArduinoOTA\src" -I"C:\sloeber\arduino-esp32\libraries\ESPmDNS\src" -I"C:\sloeber\arduino-esp32\libraries\Update\src" -I"C:\sloeber\arduino-esp32\libraries\WiFi\src" -MMD -MP -MF"libraries\ESPmDNS\src\ESPmDNS.cpp.d" -MT"libraries\ESPmDNS\src\ESPmDNS.cpp.o" -D__IN_ECLIPSE__=1 -x c++ "C:\sloeber\arduino-esp32\libraries\ESPmDNS\src\ESPmDNS.cpp"  -o  "libraries\ESPmDNS\src\ESPmDNS.cpp.o"
<command-line>:0:21: warning: ISO C++11 requires whitespace after the macro name
C:\sloeber\arduino-esp32\libraries\ESPmDNS\src\ESPmDNS.cpp: In member function 'void MDNSResponder::enableArduino(uint16_t, bool)':
<command-line>:0:17: error: 'doitESP32devkitV1' was not declared in this scope
C:\sloeber\arduino-esp32\libraries\ESPmDNS\src\ESPmDNS.cpp:85:41: note: in expansion of macro 'ARDUINO_VARIANT'
         {(char*)"board"         ,(char*)ARDUINO_VARIANT},
This brings me to ESPmDNS.cpp where a symbol cold not be resolved.
I Tried the suggestion's that has been done for a esp8266 in issue #960, but could not find the file mentioned by you.
When commenting out this line in ESPmDNS it will compiles fine. However this is not "the" solution.
Any tips where to look at what the problem is with the symbol?
Jantje
It is the same issue and the same solution applies https://github.com/Sloeber/arduino-eclipse-plugin/issues/1028
edje11
Jantje
VicomtedeValmont
I'm trying to find out since hours the differences between Sloeber V4 and Eclipse C++ IDE for Arduino 3.0. Which one is the recommended tool? I tend to use Sloeber since the IDE 3.0 has an annoying bug with include resolving. But I'm still interested about your thoughts on why using Sloeber.
