Topic: Windows/Linux/Mac Eclipse plugin to compile and upload arduino sketches (Read 404812 times) previous topic - next topic
Jantje
Which one is the recommended tool?
Depends on who you ask the recommendation. Given this is a Sloeber thread the recommendation here is Sloeber :-)
But I'm still interested about your thoughts on why using Sloeber.
My thoughts on this subject (not having been able to get "Eclipse C++ IDE for Arduino" to work ever).
The main reason to use Sloeber is that it is supported far better.
Basically I bother to ...
1) write documentation and make video's on how to
2) test boards/setups I don't use. (currently more than 500 boards compile the default ino successfully out of the box)
3) be responsive when there are issues.
4) be even more responsive to people who support me on patreon https://www.patreon.com/jantje
IMHO this makes the end user experience far better because
1) I limit my response efforts by fixing issues
2) If there are issues there is help available
I'm trying to find out since hours the differences between Sloeber V4 and Eclipse C++ IDE for Arduino 3.0.
Both tools are build on top of CDT and as such have at least 95% the same functionality.
The differences are only at the level of
1) implementation/integration differences of the arduino framework -Sloeber supports multiple versions of the same platform at the same time -
2) specific boards features -like esp debug info-.
3) What is included in the package. Sloeber product comes with everything you need to do hardware/software debug
4) Add on functionality/integrations like the x-y plotter and serial monitor
5) Support for boards which do not come in a json package (like teensy)
This is my opinion. Please share yours :-)
Jantje
Do not PM me a question unless you are prepared to pay for consultancy.
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
VicomtedeValmont
Thanks for your extensive response, Jantje. I'm convinced now and will start using Sloeber. I was confused since the Arduino IDE 3.0 was preinstalled in the latest version of CDT. But Sloeber works perfectly. Good work!
mAzharIqbal
I am facing an issue in using ESP8266.
Arduino Nano works fine. But no example compiles for any ESP8266. I have installed ESP8266 board manager v2.4.2.
12:52:44 **** Incremental Build of configuration Release for project genericesp ****
"C:\\eclipse\\arduinoPlugin\\tools\\make\\make" all
'Building file: ..\sloeber.ino.cpp'
'Starting C++ compile'
"C:\eclipse\arduinoPlugin\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\eclipse\/arduinoPlugin/packages/esp8266/hardware/esp8266/2.4.1/tools/sdk/include" "-IC:\eclipse\/arduinoPlugin/packages/esp8266/hardware/esp8266/2.4.1/tools/sdk/lwip/include" "-IC:\eclipse\/arduinoPlugin/packages/esp8266/hardware/esp8266/2.4.1/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:/Users/azhariqbal/eclipse-workspace-arduino/genericesp/Release/core" -c -Wall -Wextra -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -MMD -ffunction-sections -fdata-sections -DF_CPU=80000000L -DLWIP_OPEN_SRC -DDEBUG_ESP_PORT=Serial -DDEBUG_ESP_CORE -DARDUINO=10802 -DARDUINO_ESP8266_GENERIC -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="\"ESP8266_GENERIC\"" -DLED_BUILTIN=11  -DESP8266   -I"C:\eclipse\arduinoPlugin\packages\esp8266\hardware\esp8266\2.4.1\cores\esp8266" -I"C:\eclipse\arduinoPlugin\packages\esp8266\hardware\esp8266\2.4.1\variants\generic" -MMD -MP -MF"sloeber.ino.cpp.d" -MT"sloeber.ino.cpp.o" -D__IN_ECLIPSE__=1 -x c++ "..\sloeber.ino.cpp"  -o  "sloeber.ino.cpp.o"
'"C:\eclipse\arduinoPlugin\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++"' is not recognized as an internal or external command,
operable program or batch file.
subdir.mk:18: recipe for target 'sloeber.ino.cpp.o' failed
make: *** [sloeber.ino.cpp.o] Error 1
12:52:45 Build Failed. 2 errors, 0 warnings. (took 264ms)
Jantje
It looks like there is a install issue.
Does '"C:\eclipse\arduinoPlugin\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" exists on your disk?
If not delete the folder C:\eclipse\arduinoPlugin\packages\esp8266\tools\xtensa-lx106-elf-gcc\ and deinstall and reinstall the esp8266 platform.
mAzharIqbal
It exists. I removed and reinstalled the plugin with no luck.
I have also downloaded sloeber single file "V4.3.1_win64.2018-10-10_08-21-58.tar.gz". Same issue in it also. (build successful for nano but no luck with any esp8266 board).
I also have Eclipse for eSi-RISC development which I use for another chipset. Could it be messing with sloeber?
01:16:00 **** Build of configuration Release for project test5 ****
"C:\\sloeber\\arduinoPlugin\\tools\\make\\make" all
'make' is not recognized as an internal or external command,
make -C "C:\sloeber\/arduinoPlugin/packages/esp8266/hardware/esp8266/2.4.2/tools/sdk/lwip/src" install TOOLS_PATH="C:\sloeber\arduinoPlugin\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-"
01:16:01 Build Failed. 2 errors, 0 warnings. (took 708ms)
Jantje
You can't build lwip from source unless you have lots of other stuff installed. Doesn't work in windows with Arduino IDE.
Select another option for lwip in project properties->arduino
ov10fac
This may not  be the proper place for this question, if so I appologize.  I have installed sloeber and it is running fine so far.  I run linux and want to built the .desktop file so I can access sloeber from the favorites menue.  Everything is going fine, but I can't fine the sloeber icon.  That is needed to make everything work as its supposed to.  I know there is an icon because when I start sloeber the orange and teal gears show up in my favorites bar (gnome desktop).
Many thanks
Jantje
Have you tried the github repository?
https://github.com/Sloeber/arduino-eclipse-plugin/tree/master/io.sloeber.application/icons
ov10fac
Thanks, I never would have found it without that link.  Appreciate the information.
ageurtse
is it possible to upload a sketch through ota, web or arduino style.
i can't get it to work.
i mannaged to upload, it printes out by serial what the upload ipadres is, but where do i put this in sloeber.
Jantje
ageurtse
it sudely poped up in the port selection part.
it took abou 10 minutes to showed up, for now it's working.
Is there a way to set the library version, json library is on sloeber on version 6.x and i need 5.x
how can i change it.
Jantje
The whole bonjour stuff no longer works properly in windows 10.
Downgrade to 5.x in the library manager.
william_ferguson_au
How do you configure Sloeber to embed binary data such as a certificate.
Like listed here
  https://docs.espressif.com/projects/esp-idf/en/latest/api-guides/build-system.html#embedding-binary-data
These are the steps for platformIO
  http://docs.platformio.org/en/latest/platforms/espressif32.html#embedding-binary-data
I thought there must be something similar for Sloeber, but I can't find any doco.
William
