Topic: Windows/Linux/Mac Eclipse plugin to compile and upload arduino sketches (Read 366109 times) previous topic - next topic
Jantje
Superman
This setting is only available for indigo. In my experience; juno (after a compile) does not show Serial as a bug.
Best regards
Jantje
Do not PM me a question unless you are prepared to pay for consultancy.
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
rbid
Have problems in setting the plugin with the new Arduino IDE 1.5.1r2,
After installing the plugin, when I configure the Arduino IDE Path, the tool does not accept it. :(
Also, I'm planning to use Eclipse with the Arduino Due which is an ARM and not an AVR processor...
Any hint?
Jantje
Any hint?
Yes
1.5.X rZ are beta versions that do not support all boards. It is majorly different in setup and has not yet stabilized.
So in other words I don't support it.
When the stable version comes out I'll look on how to support it.
Best regards
Jantje
rbid
Any hint?
Yes
Best regards
Jantje
I will see if I can work on it, hope I'm not getting in over my head.. I guess it can be done
- Tailor the compiler and linker
- Use the Arduino framework to get the same Arduino IDE look (hide all the stuff the user does not need to deal with)
- Tailor the programmer and serial console.
--- Ricky
Jantje
Ricky
I don't really understand what you are talking about.
The main difference between Arduino IDE 1.X and 1.5.X is that the hard coded stuff in 1.X is brought to the boards.txt and the programmers.txt and the platform.txt.
I have already done some work on this but the Arduino core team does not share their plans and they tend to do things different from how I do things. For instance I had decided to add platform folders under hardware (like teensy does) which contains board.txt files and Arduino core team decided to have hardware/[make]/[technology]/[configuration files].
[make]=Arduino
[Technology]= avr or sam
[configuration files] = boards.txt or programmers.txt or platform.txt.
As a result I need to change my board.txt reading code. I just hate that. :smiley-zipper:
The core team noted that the whole setup may change. To avoid the frustration of doing more things twice I decided to wait untill an official release is released to see how the core team decided to do it.
Please do; the code is available at github. Fork it and go from there. https://github.com/jantje/arduino-eclipse-plugin
Why would you?
I'm sure it can be done. I think it should even be easier now as the commands are more disclosed and the framework to do it is in-place.
No need to do this. The only thing that needs to be done is decide on the compiler and linker and provide them the good options.
If you are willing to work on a arduino IDE perspective; I'm wiling to have it as part of the IDE.
Note that the Arduino "precompiler" is needed for this to work 100%.
I really don't know what you are referring to here.
Best regards
Jantje
rbid
Ricky
[make]=Arduino
Above you explained exactly what I wanted to understand... therefore indirectly you have understand me :)
Why would you?
Great, now I'm reading about GIT, before I dive into it :)
Hope the work is not over my knowledge.. or that I will have enough time to deal with it :)
The idea is to use Eclipse to program the Arduino board and then use the Serial Monitor inside Eclipse as a terminal in the older days.
Jimmy60
Hey, thanks for this plugin. I was able to get it up and working, uploading a sketch, fairly easily. Had a little problem getting the serial monitor to work. I'm using Ubuntu 12.04 and Eclipse Indigo and had the issue with not having the right port. A quick edit of eclipse.ini solved it.
Now if only I was skilled enough to really use it. Oh well, can't learn it by avoiding it.
Jantje
Jimmy60
Thanks for the feedback.
That is the right spirit.
I live with the rule: "Do something that scares you; every day".
Best regards.
Jantje
rockwallaby
Hello Jantje,
I thought I would pop along to say hi and again a huge thanks for your fantastic plugin to allow us to program our Arduino's using Eclipse.
I couldn't imagine having to use the Arduino IDE again, scary.
I have version 1.2.5.5 of your plugin running on OSX, but a question,
I am still using Arduino 1.0.1, can I move to 1.0.2 or preferably 1.0.3?
Met vriendelijke groet  :)
Paul
Paul - VK7KPA
Jantje
Paul
Thanks for the nice words.
I havn't done any real testing with 1.0.2 and 1.0.3 but I have done quick testing and havn't seen any problems.
So it should be ok.
Best regards
Jantje
yoda2nd
Thank you for all the hard work on this plugin!  I was able to get up and compiling in about 15 min thanks this plugin.
I have been having one issue however.  The only way I can upload to my Arduino Micro, is to do the following:
1.  Goto Window> Preferences >Arduino>Arduino and check Disable RXTX
2.  Unplug the Arduino Micro and plug it back in
3.  Press the AVR upload button. <--Must be done within a few seconds of plugging the Arduino back in.
If I do not do the above, all that happens is I get a message box showing eclipse is running AVRDude.  I can not cancel and there are no messages in the console view, it just hangs there indefinitely.
I am running Linux Mint and Eclipse Indigo.
Jantje
yoda2nd
Thanks for the nice words on the plugin. I do not own a micro nor do I own Linux mint so I can't say I have tested this setup.
Are you using the 64 or 32 bit version of eclipse indigo?
Which version of the Arduino IDE are you using?
Are you using the serial monitor of the plugin?
In your boards.txt file do you have the following line?
Code: [Select]
micro.upload.disable_flushing=true
If so and you are not using the serial monitor than the plugin ignores the com port completely.
I also wonder why you have to select
Quote
For every upload. This is a global setting. Setting it only set a global flag.
Can you post an image of eclipse when you see the "message box showing eclipse is running AVRDude"
Best regards
Jantje
spatula
Hi yoda2nd,
perhaps you already did, but you may look at this page for further info: http://arduino.cc/en/Guide/ArduinoLeonardoMicro#toc4. I don't have a micro, but I understand that before uploading the sketch the Arduino IDE resets the micro, which creates a new virtual port (the micro has no separate controller for serial communication). I understand that in the IDE the timing between the reset and the launch of avrdude is based on some previous trial and error, not "exact science".
This explains why disconnecting the micro works for you (a reset should produce the same effect), and the fact that you have to find a timing that works for you before pressing upload, allowing for the new virtual port to be recognized by your OS, but with the micro still running the bootloader. The most likely reason why avrdude hangs is that it's trying to communicate with a micro that is already past the bootloader stage.
I take this opportunity to thank Jantje for his excellent plugin. Nice to know he's still monitoring this thread.
Jantje
@spatula
Thanks for pointing to the link.
@all
I indeed have special code for the leonardo upload (I do own a Leonardo). As the micro like the leonardo has no dedicated usb chip it probably needs this code as well.
The easiest way to test this hypothesis is as follows:
Change in your boards.txt
Code: [Select]
leonardo.name=Arduino Leonardo
to
Code: [Select]
leonardo.name=Real Arduino Leonardo
and
Code: [Select]
micro.name=Arduino Micro
to
Code: [Select]
micro.name=Arduino Leonardo
Then select the board "Arduino Leonardo" as your board in the project properties (it is actually the micro)
And try again.
If this works it proves the hypothesis because I actually test on the name of the board.
Looking at the 1.5.2 boads.txt file I would think the esplora and the lilipad USB have the same issue.
Best regards
Jantje
yoda2nd
Thanks for such a quick response.
Quote
I am using:
64bit Eclipse Indigo
Arduino  1.0.1
And I am not using the serial monitor.
Linux Mint is a fork of Ubuntu with no Unity, it should work just the same as if it were run on Ubuntu.
Quote
Code:
I have been using the default boards.txt file from 1.0.1, so there is no Micro listed.  I have been using the Leonardo configuration from the boards.txt file and it works fine in the IDE.  The micro was not added to the boards.txt file until 1.0.2, so I could try giving 1.0.2 whirl if you want.
I have checked the Leonardo settings and upload.disable_flush is set to true and setting it to false has no effect.
I wonder if perhaps the timing between opening and closing the serial port and running ARVDude is different for the Leonardo than the Micro ?
Quote
Quote
When Disable RXTX is selected, does the plugin not try and reset the arduino?
Quote
