Topic: Windows/Linux/Mac Eclipse plugin to compile and upload arduino sketches (Read 360866 times) previous topic - next topic
Jantje
The easiest way to investigate is by compiling in Arduino IDE with verbose compile and compiling in eclipse and compare the 2 consoles.
Normally the c build, c++ build, archiver, and linking commands should be the same (except for full path versus relative path and the order and some additional tags for eclipse )
If there is a difference please share it here so I can find out what is causing the problem.
Best regards
Jantje
Do not PM me a question unless you are prepared to pay for consultancy.
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
Scott216
I'm trying to install the plugin v2 on my Mac (10.7.5).  I have Arduino IDE 1.04.  I downloaded platform.txt from github and put it in the same directory as board.txt (/Applications/Arduino.app/Contents/Resources/Java/hardware/arduino/).
I don't know what you mean in your instructions: "Do not forget to configure (windows->preferences->arduino) or nothing will work. "
I opened eclipse and went to Help > Install New Software and entered the URL: http://www.baeyens.it/eclipse/V2.
What is supposed to happen next?  I'm stuck in the Eclipse Install window.  The next button is disabled.  See screenshot.
rockwallaby
ScottG wrote:
Quote
Scott, yes, we who use OSX or linux have it slightly different.
What Jantje is referring to is to make sure you check and set preferences, and on OSX, yuo can do this by going to your menu bar and selecting 'Eclipse | Preferences' and the Eclipse pop up should appear.
From there, look at the section for Arduino in the left pane list.
_____
Paul
Paul - VK7KPA
rockwallaby
Scott, un-check the 'Group items by category' and thou will see all  :)
Paul - VK7KPA
Jantje
@scottG
V2 does not work "out of the box" with Arduino 1.0.4. If you copy platform.txt next to boards.txt it might work but I never tried.
Can you share your experiences in getting this to work?
Best regards
Jantje
Scott216
@scottG
I didn't get too far.  When I double clicked on test1.cpp to edit it, I get an error.  See screenshot.
Jantje
ScottG
The problem you have is with CDT and not with the arduino eclipse plugin.
I think you installed juno and added CDT later. Apparently the C/C++ editor is not properly installed.
Best regards
Jantje
Scott216
Best regards
Jantje
I do have Juno.  I don't know what CDT is.  This is what I installed:
http://www.eclipse.org/downloads/download.php?file=/technology/epp/downloads/release/juno/SR2/eclipse-cpp-juno-SR2-macosx-cocoa.tar.gz
I did have an earlier version of Eclipse that I never used and moved it to the trash before installing the above.   I guess I could just try to reinstall eclipse.
Jantje
ScottG
I googled the error string you got.
I found this link http://www.eclipse.org/forums/index.php/t/375550/
I'm not sure it also applies for mac.
The advice is purge tzdata-java and reinstall.
I hope this helps.
Best regards
Jantje
rockwallaby
Scott, in Eclipse, go to install software and in that dialog there is a link in the bottom right corner 'What is already installed'
Can you see the installed software, on that dialog, you have a number of tabs that will give you much information.
CDT is the C/C++ Development Tools.
You only really need the Eclipse IDE and the CDP addon and then Jan's extension for it to work.
The link you provided was for the CDT 32 bit package for OSX, so as far as I understand that is correct.
I did this within Eclipse though, selecting from the available package list and letting it install it.
I run on Eclipse on OSX 10.6.8
Eclipse version 4.3.0, Build id 120120810-1300 from Eclipse preference, where you can also see a button for 'Installation Details'
C/C++ Development Tools 8.1.2.x
Jan's Eclipse Arduino extension 2.0.0.18
_____
Paul
Paul - VK7KPA
aquadat0r
Hi all, I'm struggling to get Eclipse Juno 32-bit and Arduibo IDE 1.52 to work together.
Actually, I sucessfully installed the plugin in Eclipse and did the setup. But my eclipse does not want to compile. It constantly complains with red underlining. Also, code completion does not work. Any idea?
Jantje
As you are using Arduino IDE 1.5.2 .... Have you installed version 2 beta?
Best regards
Jantje
neuweiler
Jantje, one more thing:
When I try to upload a new program to my Due, the bossac often reports "No device found on COMx". According to http://arduino.cc/forum/index.php/topic,141628.0.html this is an issue with performing a hard reset in the bossac on the due. It would be fixable by opening the COM port with 1200 baud for a second. This triggers a hard erase on the Due. Could this behaviour be amended to your plugin before calling bossac?
Jantje
neuweiler
This behavior is already implemented.
I have not seen this behavior on my system. Which OS are you using? Are you using 64 bit eclipse? Can you provide me the output of the menu->window->preferences->arduino->test dll
Best regards
Jantje
