Topic: Windows/Linux/Mac Eclipse plugin to compile and upload arduino sketches (Read 401997 times) previous topic - next topic
Jantje
#30
Dec 23, 2011, 03:18 pm Last Edit: Dec 23, 2011, 03:30 pm by Jantje Reason: 1
turdusmerula
txs for the update.
I'll add your comment on cancel to the FAQ.
As to your request. Have you tried it. I mean the latest version "Should" support this (the 1.0 compatible one). I haven't tried though. To make it work just change the project preferences->arduino->arduino for the 2 projects (not the libraries) to point to the correct com port.
I have read numerous posts on debugging. as far as I understand it states: pay money or expect very low level support.
Let me know if it works.
Best regards
Jantje
Do not PM me a question unless you are prepared to pay for consultancy.
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
turdusmerula
I've updated to your latest 1.1 and tested it again. I got the same behavior than previously, when I select a serial port it is set for all projects not just for one.
I also tried to use a specific programmer configuration (preferences->arduino->AVRDude) for each project with an overrided serial port but the serial port used at the end is the one in preferences->arduino->arduino.
This parameter seems to be at the workspace level even if we can set it at the project level isn't it?
Jantje
turdusmerula
I checked this in the code and indeed I use the last used upload port and not the upload port set in the project.
I'll fix this.
Best regards
Jantje
Jantje
All
The comport issue is fixed in 1.1.3
In newly created project there will be a define ARDUINO that is equal to 0023 for version 23 and 100 for version 1.0 the version info is based on the content of the versions.txt file in the lib folder of arduino.
This allows to do things like
#if (ARDUINO >= 100)
#include "Arduino.h"
#else
#include "WProgram.h"
#endif
Best regards
Jantje
scarlsen
#34
Dec 31, 2011, 04:30 pm Last Edit: Dec 31, 2011, 04:32 pm by scarlsen Reason: 1
Hi, and thanks for the guide..
I have followed the installations steps, and that works fine.
When I try to make a new project with my hardware  >> Arduino Mage (AT mega1280) << I get an error messages : Failed to create project xxxxx , Path variable name cannot contain character: (.
After that it is not possibly to compile correct or uploade.
If I try to make a another project with a >> Arduino Uni << Hardware (I don't have that board) , the project are created without any problems, and I can compile correct ?
What can I do ?
Happy new year.
Per
Jantje
Hi per
This is indeed an issue.
I'll fix it in the next release but this may take a while.
You can work around the problem by modifying the string "Arduino Mage (AT mega1280)" in the board.txt to "Arduino Mage _AT mega1280_".
Best regards
Jantje
scarlsen
Super, that works , but only for hit the next wall  :smiley-roll-sweat:
When I try to download, I get this error:  >> avrdude: ser_open(): can't open device "COM17": The system cannot find the file specified. <<
I know that my COM port are COM17, and I am able to download via the "original" IDE
Any ideas ?
/Per
PaulS
Quote
Have you tried using the verbose output from the IDE to see how it formats the name of the com port? There are issues with com port names when the numeric portion is greater than 9. Some sill combination of dots and slashes are needed to make windoze recognize com port names with 2 digit numbers. Bunch of morons in Redmond haven't bother fixing the problem they have caused.
avenue33
On Mac OS X 10.7.2, with Eclipse Indigo Service Release 1 (Build id: 20110916-0149) and Arduino Eclipse plug-in 1.1.3, the following error message pops up every time:
What's wrong?
Jantje
All
Sorry for the long delay. I have been on a holiday and there was no network access.
Scarlsen
Paul is right. I thought this was an AVRdude issue and as 1.0 contained a new avrdude; I assumed the prefix was no longer needed. Therefore the prefix was removed in 1.1.3. I reintroduced the prefix in 1.1.4. However this is not yet released. You have 2 options
1) You can create a link to my prerelease update site "http://www.baeyens.it/eclipse/prerelease" and get version 1.1.5 there. I'll release 1.1.6 somewhere next week. (undo this link in eclipse if you do not want to get my test versions ;-) )
2) Add the prefix to your com port name. Change COM17 to \\\\.\\COM17. You will have to undo this when you get a new version of the plugin.
avenue33
MAC OS is officially not supported in 1.1.3. See the end of the discussion at http://arduino.cc/forum/index.php/topic,70547.45.html.
In short fixed in 1.1.5 prerelease.
Best regards
Jantje
krsnsk
Hi;
Every time i get this error.
Description   Resource   Path   Location   Type
Arduino.h: No such file or directory   lcdTest.h   /lcdTest   line 9   C/C++ Problem
What can i do for fix it?
Jantje
krsnsk
Can you be a bit more precise?
Which os are you using
Which Arduino version are you using
What have you been doing?
Is this project including a library?
Have you already been able to compile and upload?
Have you gone through the faq?
Jantje
krsnsk
#42
Jan 20, 2012, 08:00 pm Last Edit: Jan 20, 2012, 08:08 pm by krsnsk Reason: 1
Sorry :)
Windows 7 x64
Eclipse IDE for C/C++ Developers
Version: Indigo Service Release 1
Arduino 1.0 ide
plugin v1.1.7
when i try to compile i get this error.
i get same error at library and main program.
no this is my first try.
And errors;
Jantje
krsnsk
First of all: You do not have to compile the arduino library. Eclipse takes care of that. It doesn't matter if you do ant it should compile.
However:
Secondly: You claim that the arduino library doesn't compile and you give me an image that shows a file "liquidcrystal.cpp" which is not part of your project nor part of the arduino library. Where does this file come from?
Are you trying to waist my time?
sixeyes
LiquidCrystal is one of the standard libraries supplied with Arduino v1.0 (and earlier I believe).
Iain
