Topic: Windows/Linux/Mac Eclipse plugin to compile and upload arduino sketches (Read 360303 times) previous topic - next topic
AndreK
How to make a project , and include a working ~/Arduino/projectname  ?
Creating a project starts with nothing.
Headroom
http://trippylighting.com
http://ledshield.wordpress.com/
AndreK
I'm looking for Info on how to import an existing project, all files, already with code.
Jantje
Easiest ways is I know that work for sure
1) drag and drop
Create project from scratch.
Delete the created .cpp and .h files
Drag and drop your files in the project in eclipse (you can select to link or copy the files both work)
Import the libraries needed for your sketch.
2) workspace location
create a workspace in the parent folder of the folder containing the code
Make sure there are no [foldername].* files
Create a project with the name of the folder containing the code.
Adopt files as needed.
What may work is that in the creation wizard you select a sketch different than default and point to your source code.
Best regards
Jantje
Do not PM me a question unless you are prepared to pay for consultancy.
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
AndreK
Thank you - it it best to keep the cope in ~/Arduino/  folder ?     (with) projectname/projectname.ino
and teh workspace would be then in ~/Arduino  ?
or would you recommend to dupliate the folder/ source into nother place ?
To start with, until I see how it works with bigger projects, I'd like to keep it in ~/Arduino with the deafult structure, to quickly compile using Ardiuno if i need to compare results.
AndreK
I took a simple Ardiono project that works, and just imported it to a new folder, to test it with eclipse:
This is the result:
**** Build of configuration Release for project M2h ****
make all
Code: [Select]
Building file: /home/andre/Arduino/libraries/mavlink/pymavlink/generator/C/test/windows/stdafx.cpp
Invoking: AVR C++ Compiler
avr-g++ -I"/home/andre/arduino-1.0.5/hardware/arduino/cores/arduino" -I"/home/andre/arduino-1.0.5/hardware/arduino/variants/standard" -I"/home/andre/Arduino/M2h" -I"/home/andre/arduino-1.0.5/libraries/SPI" -I"/home/andre/Arduino/libraries/SimpleTimer" -I"/home/andre/Arduino/libraries/FastSerial" -I"/home/andre/Arduino/libraries/mavlink" -D__IN_ECLIPSE__=1 -DUSB_VID= -DUSB_PID= -DARDUINO=105 -Wall -Os -ffunction-sections -fdata-sections -fno-exceptions -g -mmcu=atmega328p -DF_CPU=16000000UL -MMD -MP -MF"mavlink/pymavlink/generator/C/test/windows/stdafx.d" -MT"mavlink/pymavlink/generator/C/test/windows/stdafx.d"  -c -o "mavlink/pymavlink/generator/C/test/windows/stdafx.o" -x c++ "/home/andre/Arduino/libraries/mavlink/pymavlink/generator/C/test/windows/stdafx.cpp"
In file included from /home/andre/Arduino/libraries/mavlink/pymavlink/generator/C/test/windows/stdafx.h:8:0,
                 from /home/andre/Arduino/libraries/mavlink/pymavlink/generator/C/test/windows/stdafx.cpp:5:
/home/andre/Arduino/libraries/mavlink/pymavlink/generator/C/test/windows/targetver.h:8:23: fatal error: SDKDDKVer.h: No such file or directory
compilation terminated.
make: *** [mavlink/pymavlink/generator/C/test/windows/stdafx.o] Error 1
**** Build Finished ****
I am not sure if it somehow grabbed too much from the library:  "mavlink/pymavlink/generator/C/test/windows/stdafx.d
anyway - the libraries are the same that work fine with "arduino"
Jantje
I'm not sure what you have done or how you did it but the compilke output states you are trying to compile
Code: [Select]
which looks like you copied to much.
stdafx.cpp is a visual studio compile optimization  solution which is not at all wanted/compatible with arduino ide.
AndreK
exactly, arduino mavlink library comes with other examples as well, of course, I could delete them, for some libraries manually deleting here and there would mess with git.
-Arduino dig too deep into the library folder structure.
-Is if possible to stop Eclipse from doing it ?
Jantje
If you import a library as a library in eclipse the examples folder will be removed from the compilation path.
If you want to exclude sources and/or folders you can right click the file/folder select resouce configurations and select exclude from build. Select the configurations to exclude (there should be only Release)
Once excluded the files/folders are grayed out.
beingobserver
#414
Mar 01, 2014, 08:26 am Last Edit: Mar 01, 2014, 08:41 am by beingobserver Reason: 1
[Installation problem]
Hi. I am relatively new to Arduino and completely new to Jantje's plugin.
I spent all yesterday trying to install it. I don't know if i should go back to page 1.
-I have Os X: 10.9.1.
-Downloaded Eclipse - OS X 32 Bit (It says Kepler)
-I couldn't find the Arduino V1.5.5  and downloaded V1.5.6-r2
-I tried Help > Install New Software > http://www.baeyens.it/eclipse/update (V 1.2.0)
-I also tried dragging & dropping  http://www.baeyens.it/eclipse/download/product/V2.2_mac64.2014-01-19_15-16-30.tar.gz into dropins folder.
I tried several times with different versions of the files and most of the time it doesn't accept Arduino IDE Path.
Couldn't upload the file..
And sometimes "serial port already in use" warning.
I suspect that there might be a version conflict.
Now i removed everything. Where should i start again?
Thank you.
Jantje
Hi beingobserver
It seems to me you are  confused by the different installation options there currently are.
I have written this page to explain http://eclipse.baeyens.it/installAdvice.shtml the options.
please read the page and if something is not clear we can discus so it becomes clear to you and I can modify the page so it becomes clearer.
And here is a link to older arduino versions http://arduino.cc/en/Main/OldSoftwareReleases#.UxHZ0fFl7PE
Best regards
Jantje
rockwallaby
#416
Mar 01, 2014, 01:57 pm Last Edit: Mar 08, 2014, 11:46 am by rockwallaby Reason: 1
Sounds like you have really tried to get it going, hopefully I can give you a few pointers to help you get up and working with this great plugin for Eclipse.
Before you start, you must have the correct version of the Arduino IDE already installed on your Mac. You can check on Jantje's site for the correct version you need for a specific version of the plugin. I do find it confusing how Jantje has detailed this and would like to see his instructions for this laid out differently so it is more clear and understandable. But, basically, only certain versions of the Arduino IDE can be used with the plugin. I believe this is because of changes in the way Arduino do things.
But, to let you know I use and others suggest using Arduino version 1.5.2 beta.
I use this version as I am playing with the DUE as well.
There are two basic approaches to having Eclipse work with Arduino, so that you can program and upload from Eclipse to your connected Arduino.
The first is along the lines of what you have done, and this was Jantje's first method of installation.
For this, you needed to download and install, as you have done the specified version of Eclipse CDT (The C/C++ dev system). After checking that Eclipse was installed and working correctly, you would then proceed to install Jantje's plugin.
Normally this is done from within Eclipse.
You can see this here http://www.baeyens.it/eclipse/Install_plugin.shtml.
From there you will see that you need to run up Eclipse and the select 'Help | Install New Software.
Follow the instructions step by step and you should end up with a system that works.
Also, as you are also on a Mac, this may also interest you, a link from Jantje's site http://trippylighting.com/teensy-arduino-ect/arduino-eclipse-plugin/arduino-eclipse-ide-and-plugin-v2-2-installation/
Right, the second method, is far easier and should have you up and working in a very short time.
That is download one of Jan's prebuilt packages from his download area, http://www.baeyens.it/eclipse/download.php
Go down to see the Mac OSX packages and select a recent version.
You will need to unzip it and then you can install it..
Now, the problem.
I tried a few of these packages last week for you already, but, as you know I had problems with the installation.
I emailed Jan about this, but he is unfortunately unable to test the situation as he doesn't have a Mac.
To further test my research, I downloaded a bete testers package for Mac OSX and that installed fine for me.
Maybe you might like to try to download a prebuilt package from the download area with the link above and try.
That way, if you have problems, you may tell Jan and we will then need to see what the problem there is.
Maybe it was just me and I did something incorrect, but I tried on both my Macbook Pro and Mac Mini with the same results.
Both installs from the download are failed to install correctly,with errors being generated during the unzip process.
Yet on both my Mac's I could use the beta testers prebuilt package just fine.
Ok, I think that should be enough to get you well and truly confused Ersan  :)
____
Paul
Paul - VK7KPA
Headroom
I have written detailed installation instruction for Mac users here:
These are to be followed precisely. If it says Arduino 1.5.2 then don't attempt to use 1.5.6 because it is more convenient ;-)
Also, I would really appreciate feedback on these instructions (there's a Windows version as well). I have anywhere between 40-50 visitors with 2-3 views per visitor on that section of my tiny blog and rarely receive any feedback. Occasionally a user asks question and needs help, but once I provide direction I don't necessarily receive feedback if it actually helped.
rockwallaby
Yes I thought your instructions were quite well explained too.
I could have used them last year or was it the year before that, when I was going through this myself.
Still, I learn much by slogging through the hard way.
Thanks Headroom, I hope this will help Ersan and others with using Eclipse.
P.S. You would have had a few more visits just now so I could get the link in my post  :)
Maybe I should read it again.
____
Paul
Paul - VK7KPA
Jantje
And in the mean time there is a 3th option to install.
This option is basically the same as the first option (install eclipse and add the plugin) but it is done using the eclipse marketplace.
once you installed eclipse go to help->eclipse market place
In the dialog box enter arduino as search word and select go
select install from the arduino eclipse ide.
then configure the plugin as described from step 4 onwards http://eclipse.baeyens.it/Install_plugin.shtml
or from Headroom his link.
Believe me or not but next week you won't understand why it didn't work
Best regards
Jantje
