Topic: Windows/Linux/Mac Eclipse plugin to compile and upload arduino sketches (Read 360554 times) previous topic - next topic
AndreK
hi.
First I installed from Eclipase market.  It sayd V2 , I did not see "2.2" anywhere, si I uninstalled and installed 2.2 from
baeyens.it
Whenever i click verify (the least I can expect to work)  I get :
Conflicting handlers for it.baeyens.arduino.actions.ArduinoBuildAction: {it.baeyens.arduino.actions.BuildHandler@4d8491ec} vs {it.baeyens.arduino.actions.BuildHandler}
Not sure if this can be blamed on "arduino-1.5.6-r2" - I had to take a chance on it, as I failed to find the approved versions.
eclipse.buildId=4.3.2.M20140221-1700
java.version=1.7.0_51
java.vendor=Oracle Corporation
BootLoader constants: OS=linux, ARCH=x86_64, WS=gtk, NL=en_US
Framework arguments:  -product org.eclipse.epp.package.cpp.product
Command-line arguments:  -os linux -ws gtk -arch x86_64 -product org.eclipse.epp.package.cpp.product
Jantje
If I understand you correctly you are talking about a logging in the error log which has no functional influence on the working of the plugin.
If so it has been fixed as you can see here. https://travis-ci.org/jantje/arduino-eclipse-plugin/builds/19222196
The market place installs the latest officially released version (which is V2.2). To have this fix you need the latest and greatest which is only available as nightly build. easiest is to upgrade using the nightly update site http://www.baeyens.it/eclipse/nightly
Can you please confirm that the issue is only an logging in the error log and if not can you please explain what goes wrong?
Best regards
Jantje
Do not PM me a question unless you are prepared to pay for consultancy.
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
AndreK
I guess the correct nightly path is something like: http://www.baeyens.it/eclipse/download/product/linux64.2014-03-10_02-06-10.tar.gz
Installed, and used it - works much better - did not had chance to test with actual hardware, but it looks promising.
AndreK
Jantje - Today, wanted to test the daily build , downloaded whole package from your site, (not only plugin)
Created a new sketch, imported (copied) a projetcs files.
On compile I get:
Code: [Select]
Building file: ../Functions.ino
Starting C++ compile
"/home/andre/prog/arduino-1.5.6-r2/hardware/tools/avr/bin/avr-g++" -c -g -Os -fno-exceptions -ffunction-sections -fdata-sections -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=156-r2 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR    -I"/home/andre/prog/arduino-1.5.6-r2/hardware/arduino/avr/cores/arduino" -I"/home/andre/prog/arduino-1.5.6-r2/hardware/arduino/avr/variants/eightanaloginputs" -MMD -MP -MF"Functions.ino.d" -MT"Functions.ino.d" -D__IN_ECLIPSE__=1 -x c++ "../Functions.ino"  -o  "Functions.ino.o"   -w
../Functions.ino: In function 'void timerEvent()':
../Functions.ino:4: error: 'hottV4_state' was not declared in this scope
And the final line is the start of a lot of problems.
Instead of start by compiling [projectname].ino  - it starts with apparently a random .ino
I guess there's something I missed ?
Jantje
I guess you have not read the section Before continuing Note that : on http://eclipse.baeyens.it/
More specifically
Quote
The current version works with cpp files only (no pde or ino out of the box).
Therefore the plugin is not compatible with the IDE out of the box. (read a sketch may not compile in the plugin)
Below is a link to instructions on how to keep your plugin developed code Arduino IDE compatible. (read your eclipse project compiles in Arduino)
I use those and I can compile the code between the Arduino IDE and eclipse without changes and defines.
Best regards
Jantje
AndreK
Thanks.
Will wait will test a little more in spare time, and wait till it and Arduino cooperates a bit smoother.
Please consider adding serial port selection in toolbar, I often choose between ttyUSB0 and 1 depending on other connected devices.
AndreK
donation sent, keep up the good work, I'd like to see this become the "pro" IDE for arduino.
Jantje
mweissboeck
Great Plugin, I love it :-)
But I have one problem. I like to share my Arduino projects with my Git repository. Sharing works (Team > Share Project...)
The files all show up in the Git repo. But after sharing, the Team menu item does not show all this nice Git commands, its still only shows Share Project... Also in the Project Properties, Git does not show up.
On plain C Projects this works just fine. Any ideas what is going on?
Environment:
- Eclipse Kepler Service Release 2 (includes EGit)
-  Arduino eclipse extensions   2.2.0.1
Jantje
No idea.
I use RTC as version control tool in eclipse and that works fine. I'm sure other people use other version control tools without problems. As the plugin itself  is not version control tool aware I think you have some problem in your workspace which may or may not be related to the plugin.
Check your error log to see whether anything pops up there and/or try with a new work-space.
Best regards
Jantje
ENSTAR
Hello, thank you very much for your plugin which I am curently using.
Is there any way to setup a dev environment for libraries ? Or to set another project as a library to the current project ?
Thank you very much for your work.
Jantje
That is why you can specify your private library path.
I have a project called libraries which is referenced in private libraries path. This way I can have my libraries in version control as well.
Best regards
Jantje
naggelaar
#432
Apr 01, 2014, 03:20 pm Last Edit: Apr 01, 2014, 04:00 pm by naggelaar Reason: 1
***nevermind this question, "problem" solved! ***
***still  buying you the beer though :-) ***
Hello Jantje,
firts of all, thanks for bulding this plugin, and all the time and effort you spent helping people out, waanzinnig man!. As soon as i have everything up and running i buy you a beer (or 2  ) !  ...it's a promise  XD
As a smalle reference/introduction: I am just starting with arduino, but i am a reasonable experienced (oop) developer, although not in C++ (yet). So after playing around with the ArduinoIDE for a while i soon thought i wouldn't mind a decent development environment.
I am currently running the eclipseArduino IDE v2.2 with arduinoIDE 1.5.6r2 . Started with 64bit kepler and plugin, got a lot of noob issues, did a lot of searching and reading, changed to your 32bit intergrated version, some more noob issues, but by now, except for the everlasting "make: *** No rule to make target `clean" error (can it be solved?), i can upload the sketches to my Uno and Mega.
One real problem remains: the serial monitor doesn't work as it should.
Couldn't find an answer/solution anywhere , am i missing something very basic here or....?
using this code:
Code: [Select]
#include "tester.h"
#include "Arduino.h"
int ledPin = 13;
pinMode(ledPin, OUTPUT);
digitalWrite(ledPin, HIGH);
digitalWrite(ledPin, LOW);
Serial.println("test");
results in:
"[]àààà[][]àààà[][]àààà[][]àààà[][]àààà[][]àààà[][]àààà[][]àààà[][]àààà[][]àààà[][]àààà[][]àààà[]",
which makes debugging quit hard  :) ...sometimes i have to close the serial monitor or restart to be able to upload changes in the sketch.
Anyone who got this as well?
O , 1 more thing,: in your video you made changes in the Indexer, but that option is different in this version. I could not find it, so couldn't test if it would help. Is it hidden somewhere else?
Thanks!
Jantje
naggelaar
Thanks for the nice words.
The serial monitor problem is probably a baud rate issue. Which baud rate do you use in the monitor?
V2.2 no longer needs the indexer changes. It should work fine out of the box (after the first compilation).
The nothing to clean error is actually not really a bug/error. The compilation starts with a clean due to configuration changes but nothing has been build so the makefile does not yet exist.
You should only get this message when there is no makefile when starting a build.
Best regards
Jantje
naggelaar
...that's a quick reply! :-)  I was just editing my post , it was indeed the baudrate, completely overlooked that one  :smiley-red:
Thanks!
