Topic: Windows/Linux/Mac Eclipse plugin to compile and upload arduino sketches (Read 235780 times) previous topic - next topic
Jantje
And1G
My plugin is based on the AVR plugin.
It basically puts a layer on top of the AVR plugin to make life easy for arduino people (preconfigure the whole setup, deliver a empty sketch, add import a library, reset the device before upload, in the new to come version a serial monitor).
If you use the AVR plugin directly (via my plugin or by instaling the native product) you can program the dragon.
See AVR plugin for more info http://avr-eclipse.sourceforge.net/wiki/index.php/The_AVR_Eclipse_Plugin
Note that I forked the code so there are differences between my delivered AVR plugin and the original version.
Best regards
Jantje
Do not PM me a question unless you are prepared to pay for consultancy.
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
And1G
Thanks, I have now managed to use the Dragon and it is working.
But is it possible to create a standard AVR proje t with your plugin like in the normal AVR Eclipse? For some small Projects, Arduino is just bloat but I'd really like to stick with your plugin as the Arduino integration is a really nice feature...
Jantje
And1G
Nice to hear it.
It probably is but it is not supported functionality
Best regards
Jantje
Jantje
Hi
I released now Version 1.2.2 of the Arduino eclipse plugin
It has 3 new features.
1) The plugin contains a serial monitor. Currently the only documentation I made on the serial monitor is this video http://eclipse.baeyens.it/serial_demo.wmv
2) You can specify a location for your "personal libraries"
3) The plugin now allows for multiple libraries to be added at once. It lists the personal and the Arduino Libraries in a multiple select list.
The old import still exists but it is better to use the new import.
Please tell me what you think of the new features.
If you are not running on windows 7 tell me whether it works or not.
Best regards
Janje
PS All code has been released to github and is fully open.
PPS The video didn't quite work all the time as planned. I kept it this way not because I'm lazy but because this way you can learn from my mistakes  8)
PeterO
I look forward to trying this out at home tonight.  I watched the video, and it looks very useful :-)
PeterO
ghps
Hi
Anyone who ever tried to setup Eclipse on his own (or with the help of various online descriptions) will see how great this plugin is. It reduces the (in most cases fruitless) work of hours to a 5-minute-task with a few clicks. After using it for a few weeks now the plugin has become indispensable for me and I can say that it does the job without any flaws. Libs, different boards, git? No problem! And even serial monitor now...
Two aspects, however, are missing on the projects main page:
  • Your paypal account.
  • A hint how to easily update from previous versions.
Jantje
Thanks for the appreciation
ROFL
I've been considering adding a "buy me a beer button" which would mean a paypal donation. I've been reading about it and spent to much time on it. So I didn't do it. Maybe one day. Thanks for bringing this up  :D
Upgrading from a previous version should be easy. Use the help->check for updates.
After the update has run check the preferences and change them if needed.
Greetings from Belgium
Jantje
mrburns42
OK,  I am a confused noobie.   I downloaded Eclipse Indigo and installed the plug-in.   I am using Arduino 022.  I created a little test project just like the web pages recommend.   When I try to compile, I get the "method begin could not be resolved"   Some folks have recommended that "extern HardwareSerial Serial;"  must be added to the project's header file.   Other people said the root cause is the plugin or software is not installed correctly.   I rechecked the setup steps and found nothing wrong with my install or configuration.  I tried adding the above extern and it does remove the errors.  A couple of quirks about my system is that I installed everything on an external USB HD.  The system also has other versions of WINAVR installed in the C drive.  The Arduino IDE does run fine though in this setup.
Question:   Should I just include the extern?  Or am I just putting a bandage on a festering wound?
Thanks.
Jantje
You probably do something wrong.
Look at this movie http://eclipse.baeyens.it/serial_demo.wmv
In this movie I create a project and compile it.
Best regards
Jantje
mrburns42
Thank you very much, Jantje.   I followed the steps in the movie and it compiles without "bugs"  now.  I was missing the part about adding the headers to the Indexer list.
For all other noobies, I highly recommend watching the movie.  It will quickly give you a good tour of working with the Arduino in Eclipse.
Thanks again.
mrburns42
FYI,  I seem to be having a problem with the version 1.2.2 of the Plug-In.    That version seems to work for me on Arduino 1.0.  However, I have some stuff on Arduino 022 that I want to use.   When I have 1.2.2 loaded and I try to create a new Project under Arduino 022, I get the following error message.
"Failed to create arduino core project Arduino_Uno
'CoreArduinoPath/arduino' is not a valid location. The location is relative to undefined workspace path variable 'CoreArduinoPath'. "
If I revert to 1.2.0 of the Plugin, the I can create a new Project in Arduino 022 without an error.   If I upgrade to 1.2.2 Plugin, this project still runs fine.   In 1.2.2,  I can create new Projects without errors as long as I target a device that the Core project already exists on.  That is version 1.2.0 Plugin already created the core files directory in the WorkSpace.   The 1.2.2 problem only occurs for me when I either start a new WorkSpace, or I target a different device that I had not previously used.
Jantje
Jantje
Hi
I cant reproduce the problem, but I think I know what is going on.
I assume you have a workspace and you change the Arduino location in the preferences between Arduino 1.0.1 and Arduino 22.
If so: This is not at all supported!! The more I think about it the more I feel it cannot be supported at all.
If you want to have Arduino 022 and Arduino 1.0.1 (or any other Arduino IDE version) projects at the same time you need to create multiple workspaces.
In other words. Once you have filled in the Arduino version in the preferences you should not change it anymore.
If this is not your problem please describe what you do to reproduce the problem.
best regards
Jantje
brownerthanu
#73
Jun 21, 2012, 11:34 pm Last Edit: Jun 22, 2012, 12:02 am by brownerthanu Reason: 1
I had that same error and for me it occurred because I didn't specify the Private Library Path. After I set the path to any old folder and deleted the auto-created Arduino_Uno project (I guess it's called the core project?) it worked for me.
I have a different problem that relates the serial monitor. I'm working with the current version of Eclipse CDT and 1.2.2 Arduino plugin on OS X Lion. For me there is no Arduino Folder under Window > Show View > Other.
Jantje
brownerthanu
Not having a Arduino folder in the dialog box that pops up after you select windows->Show View-> other  when you have eclipse plugin 1.2.2 is at least weird.
Have you watched the movie? http://eclipse.baeyens.it/serial_demo.wmv
Can you make an image of what you do see?
Best regards
Jantje
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
