Author Topic: Camera Project  (Read 700 times)
Hello everyone,
I was hoping someone could tell me if what I plan to do is possible using Arduino.
A friend of mine is a photographer who was wanting to be able to roll a camera along linear motion bearings (approx length: 1500mm) taking photos at varies instances along its length. The speed at which the camera moves needs to be variable as well as the number of photos taken along its length. For example a photo might want to be taken every 50mm taking 3 seconds to travel that distance.
To do this I was going to use linear motion bearings and rails, belt driven using a stepper motor. The tricky part for me will be the software controlling it. I understand you can control a stepper motor using Arduino hardware. I want the HMI (human machine interface) to be as simplistic as possible. I want the speed to be controlled by a simple knob that can be turned from 0-100%. Likewise for the distance between photos.
I hope that explains it well enough. Is this possible using Arduino as well as for someone that hasn't programmed anything before (other than CNC G-Code).
20 LEDs are enough
Have a look here: http://wiki.openmoko.org/wiki/Main_Page
ca
http://openmoco.org/  smiley-wink
Topsham, Vermont USA
... in The Woods In Vermont
Hi, Search for "Arduino Camera Controller" and you'll find lots.
http://www.arduino.cc/playground/Main/InterfacingWithHardware (search for 'camera')
and see; http://yourduino.com/camera-control.htm
The software for that is here: http://www.mindspring.com/~tom2000/Projects/AI-1_Remote/AI-1_Remote.html
I think the AI-1 software is a great place to start and it has lots of memory space left in an Arduino.
AND to blow your mind about the possibilities of this stuff:
http://timescapes.org/
I plan to add motion control to AI-1 sometime (way too busy now)  smiley-mad
Regards, Terry King terry@yourduino.com  - Check great prices, devices and Arduino-related boards at http://YourDuino.com
HOW-TO: http://ArduinoInfo.Info
If you're not living on the Edge, you're taking up too much space!
I'm using the Bescor MP101 to pan my DSLR.  I wrote a library to slow down the motion so that it takes a video frame every 2 pixels while it's panning in HD.  Another to take a still image every 1/8 degree, with an arbitrary time between shots.  This is only a few pixels at 18mm.  Another to make Gigapixel images like the expensive unit they sell.  With Uno the possibilities are endless!
If you fall... I'll be there for you!
-Floor
Skype Brighteyes3333
(262) 696-9619
