I intend to implement a system that will inform the blind through speaker and the deaf through lcd display in passenger vehicles.The different rfid tags represent different stages and hold the info about what to display through lcd and say through speakers.
Its a school project.
My code was able to display the different stages but not say the differnt stages. Code 1 is the code of the program while code2 is for the speaker through speakjet incase you want to have a look.
* ONBOARD PASSENGER INFORMATION SYSTEM FOR BLIND AND DEAF
* RFID tags initiate display of different towns on lcd.
* Iam unable to make the speakjet say the respective towns please help
* The code compiled without an error in arduino program. Attached find also the working code of speakjet
* http://www.practicalarduino.com/projects/medium/rfid-access-control
// Set up the serial connection to the RFID reader module. In order to
// keep the Arduino TX and RX pins free for communication with a host,
// the sketch uses the SoftwareSerial library to implement serial
// communications on other pins.
#include <SoftwareSerial.h>
#include <LiquidCrystal.h>
LiquidCrystal lcd(2, 4, 5, 6, 7, 8);
// The RFID module's TX pin needs to be connected to the Arduino.
#define rxPin 9
#define txPin 5
#define TxPin 10
#define RxPin 11
// Create a software serial object for the connection to the RFID module
SoftwareSerial rfid = SoftwareSerial( rxPin, txPin );
SoftwareSerial SpeakJetSerial = SoftwareSerial(RxPin, TxPin);
// Set up outputs
#define futureOutput 12
#define ledPin 13
// Specify how long the output should be held.
#define unlockSeconds 2
// The tag database consists of two parts. The first part is an array of
// tag values with each tag taking up 5 bytes. The second is a list of
// names with one name for each tag (ie: group of 5 bytes). You can expand
// or shrink this as you see fit. Tags 2 and 3 are only there for example.
char* allowedTags[] = {
"4500F34653", // Tag 1
"4500F38746", // Tag 2
"ABC123DE45", // Tag 3
// List of names to associate with the matching tag IDs
char* tagName[] = {
"Juja", // Tag 1
"Thika", // Tag 2
"NAME 3", // Tag 3
char* SayIt[] = {
"20, 96, 21, 114, 22, 128, 23, 5, 165, 138, 165, 132",
"191, 129, 195, 135",
"45,556,35,33,56,09",
// Check the number of tags defined
int numberOfTags = sizeof(allowedTags)/sizeof(allowedTags[0]);
int incomingByte = 0; // To store incoming serial data
* Setup
lcd.clear(); //Clears LCD
lcd.setCursor(0, 0);
lcd.print(" Please Swipe");
pinMode(ledPin, OUTPUT);
pinMode(TxPin, OUTPUT);
digitalWrite(ledPin, LOW);
pinMode(futureOutput, OUTPUT);
digitalWrite(futureOutput, LOW);
SpeakJetSerial.begin(9600);
Serial.begin(9600); // Serial port for connection to host
rfid.begin(9600); // Serial port for connection to RFID module
// Serial.println("RFID Reader Initialized");
* Loop
byte i = 0;
byte val = 0;
byte checksum = 0;
byte bytesRead = 0;
byte tempByte = 0;
byte tagBytes[6]; // "Unique" tags are only 5 bytes but we need an extra byte for the checksum
char tagValue[10];
// Read from the RFID module. Because this connection uses SoftwareSerial
// there is no equivalent to the Serial.available() function, so at this
// point the program blocks while waiting for a value from the module
if((val = rfid.read()) == 2) { // Check for header
bytesRead = 0;
while (bytesRead < 12) { // Read 10 digit code + 2 digit checksum
val = rfid.read();
// Append the first 10 bytes (0 to 9) to the raw tag value
if (bytesRead < 10)
tagValue[bytesRead] = val;
// Check if this is a header or stop byte before the 10 digit reading is complete
if((val == 0x0D)||(val == 0x0A)||(val == 0x03)||(val == 0x02)) {
break; // Stop reading
// Ascii/Hex conversion:
if ((val >= '0') && (val <= '9')) {
val = val - '0';
else if ((val >= 'A') && (val <= 'F')) {
val = 10 + val - 'A';
// Every two hex-digits, add a byte to the code:
if (bytesRead & 1 == 1) {
// Make space for this hex-digit by shifting the previous digit 4 bits to the left
tagBytes[bytesRead >> 1] = (val | (tempByte << 4));
if (bytesRead >> 1 != 5) { // If we're at the checksum byte,
checksum ^= tagBytes[bytesRead >> 1]; // Calculate the checksum... (XOR)
tempByte = val; // Store the first hex digit first
bytesRead++; // Ready to read next digit
// Send the result to the host connected via USB
if (bytesRead == 12) { // 12 digit read is complete
tagValue[10] = '\0'; // Null-terminate the string
lcd.setCursor(0, 1);
// lcd.print(" Please Swipe");
lcd.print("Tag read: ");
for (i=0; i<5; i++) {
// Add a leading 0 to pad out values below 16
if (tagBytes[i] < 16) {
lcd.print("0");
lcd.print(tagBytes[i], HEX);
// lcd.println();
// Serial.print("Checksum: ");
//Serial.print(tagBytes[5], HEX);
// Serial.println(tagBytes[5] == checksum ? " -- passed." : " -- error.");
// Show the raw tag value
// Serial.print("VALUE: ");
// Serial.println(tagValue);
// Search the tag database for this particular tag
int tagId = findTag( tagValue );
// Only fire the strike plate if this tag was found in the database
if( tagId > 0 )
// lcd.clear();
lcd.print("Welcome to ");
// Serial.print(tagId);
// Serial.print(": unlocking for ");
lcd.print(tagName[tagId - 1]); // Get the name for this tag from the database
SpeakJetSerial.println(SayIt[tagId - 1]); //say the name of the stage
lcd.print("Tag not authorized");
// Serial.println(); // Blank separator line in output
bytesRead = 0;
* Fire the relay to activate the strike plate for the configured
* number of seconds.
* Search for a specific tag in the database
int findTag( char tagValue[10] ) {
for (int thisCard = 0; thisCard < numberOfTags; thisCard++) {
// Check if the tag value matches this row in the tag database
if(strcmp(tagValue, allowedTags[thisCard]) == 0)
// The row in the database starts at 0, so add 1 to the result so
// that the card ID starts from 1 instead (0 represents "no match")
return(thisCard + 1);
// If we don't find the tag return a tag ID of 0 to show there was no match
return(0);
// letsmakerobots demo
// code to make speaker say letsmakerobots
// set up a new software serial port
//rxPin: the pin on which to receive serial data
//txPin: the pin on which to transmit serial data
#define txPin 2
#define rxPin 3
// set up the SoftwareSerial port to connect to the SpeakJet
SoftwareSerial SpeakJetSerial = SoftwareSerial(rxPin, txPin);
// define pin modes for tx, rx pins:
//pinMode(rxPin, INPUT);
pinMode(txPin, OUTPUT);
// char array holding the 'lets make robots' string we want to speak
char SayIt[] = {20, 96, 21, 114, 22, 88, 23, 5, 145, 131, 193, 6, 140, 154, 196, 6, 148, 7, 137, 7, 164, 18, 171, 136, 193};//codes from phrasealator
SpeakJetSerial.println(SayIt); // send it to the SpeakJet
// infinite do-nothing loop
