Loading...
Pages: [1]   Go Down
Author Topic: 74HC595 - psudo PWM - and KITT Scanner  (Read 314 times)
Scotland
Offline Offline
God Member
Have you had your Arduino fix today?
View Profile
WWW
I recieved my 74HC595s 2 days ago, and wanted to make a simple test circuit, so wired up the chip as shown elsewhere on this site, but was informed that PWM fading was not easily possible.  :'(
So I sat down and worked this out - See my code. Its fairly straight forward, if a little 'messy' (I could use bit shifting for the animation, but this works for me just now).
Code:
//  Name    : Kitt_V2
//  Author  : Drew Anderson
//  Date    : 22/04/2010
//  Modified:
//  Version : 2.0
//  Notes   : Code for using a stop Shift Register
//          : with custom bitmaps
//Pin connected to ST_CP of stop
int latchPin = 8;
//Pin connected to SH_CP of stop
int clockPin = 12;
////Pin connected to DS of stop
int dataPin = 11;
  int startdly(150);
  int strobedly(120);
   // Out to 74HC595 (Serial TO Parallel OUT)
    void stopout(int numberToDisplay)
    // take the latchPin low so
    // the LEDs don't change while you're sending in bits:
    // digitalWrite(latchPin, LOW);
    // shift out the bits:
    shiftOut(dataPin, clockPin, MSBFIRST, numberToDisplay);
    //take the latch pin high so the LEDs will light up:
    digitalWrite(latchPin, HIGH);
  //set pins to output so you can control the shift register
  pinMode(latchPin, OUTPUT);
  pinMode(clockPin, OUTPUT);
  pinMode(dataPin, OUTPUT);
  //Startup Animation V1.0
  //Lets Clear the LEDs - just incase the 74HC595 'remembers' its last state after restart.
  stopout(B00000000);
  //Fade up Startup Routine
  for(int x=0;x<20;x++)
    for(int y=0;y<4;y++)
    stopout(B11111111);
    delay(x);
    stopout(B00000000);
    delay(19-x);
  //Fade Down Startup Routine
    for(int x=0;x<10;x++)
    stopout(B11111111);
    delay(9-x);
    stopout(B00000000);
    delay(x);
  //duel fade
  for(int z=0;z<5;z++)
    stopout(B11011011);
    delay(9-x);
    stopout(B00100100);
    delay(x);
    stopout(B00100100);
    delay(9-x);
    stopout(B11011011);
    delay(x);
  //Lets fade middle 4, outer 4 LEDS are static
    stopout(B11000011);
    delay(9-x);
    stopout(B11111111);
    delay(x);
    stopout(B11111111);
    delay(9-x);
    stopout(B11000011);
    delay(x);
  //Binary Number to output
  //stopout(B********);  where ********* is Binary sprite info
  stopout(B00011000);
  delay(startdly);
  stopout(B00111100);
  delay(startdly);
  stopout(B01111110);
  delay(startdly);
  stopout(B11111111);
  delay(startdly);
  stopout(B11100111);
  delay(startdly);
  stopout(B11000011);
  delay(startdly);
  stopout(B10000001);
  delay(startdly);
  stopout(B00000000);
  delay(startdly);
  stopout(B00011000);
  delay(startdly);
  stopout(B00100100);
  delay(startdly);
  stopout(B01000010);
  delay(startdly);
  stopout(B10000001);
  delay(startdly);
  stopout(B01000010);
  delay(startdly);
  stopout(B00100100);
  delay(startdly);
  stopout(B00011000);
  delay(startdly);
  stopout(B00000000);
  delay(startdly);
    stopout(B10000000);
    delay(strobedly);
    stopout(B01000000);
    delay(strobedly);
    stopout(B00100000);
    delay(strobedly);
    stopout(B00010000);
    delay(strobedly);
    stopout(B00001000);
    delay(strobedly);
    stopout(B00000100);
    delay(strobedly);
    stopout(B00000010);
    delay(strobedly);
    stopout(B00000001);
    delay(strobedly);
    stopout(B00000010);
    delay(strobedly);
    stopout(B00000100);
    delay(strobedly);
    stopout(B00001000);
    delay(strobedly);
    stopout(B00010000);
    delay(strobedly);
    stopout(B00100000);
    delay(strobedly);
    stopout(B01000000);
    delay(strobedly);
Please leave a reply if this is of any help to you..
Cheers again Arduinees.
Spycatcher2k
Logged
Drew.
(MyPCB MANUFACTURING SERVICE)
Duemilanove - UNO - Leonardo - Mega 1280 - Mega 2560 - Pro
& Way too many custom boards.
Phoenix, Arizona USA
Offline Offline
Faraday Member
Where's the beer?
View Profile
WWW
Please tell me, regardless of what you've done, that you didn't mount it to your Honda Civic (or whatever vehicle you have)...
/almost as bad as wearing parachute pants in the 80's...
 ;D
Logged
Scotland
Offline Offline
God Member
View Profile
WWW
 ;D
Nope - Never had a honda civic, it's an astra that I drive. . . .
Im doing these projects just for fun, and learning as I go.
but in saying that, if someone wanted one of my projects, then
I would gladly sell them  smiley-wink .
We have a few 'Boy Racers' around here, so
Logged
Drew.
Pages: [1]   Go Up
Print
Jump to:
