Loading...
Pages: [1]   Go Down
Author Topic: Using Potentiometer to Control LED Blink Speed  (Read 1375 times)
Somewhere in Arizona
Offline Offline
God Member
Arduino must be a drug, because I'm addicted!
View Profile
First off, I must thank sciguy for helping me on the code.
This is a cimple bit of code that allows a pot to control an led's flash speed. Here is the code for it:
Code:
int potpin = 0;  // analog pin used to connect the potentiometer
int ledpin = 13;
int val;    // variable to read the value from the analog pin
pinMode(ledpin, OUTPUT);
  val = analogRead(potpin);            // reads the value of the potentiometer (value between 0 and 1023)
  val = map(val, 0, 1023, 500, 5);     // scale it to use it with the servo (value between 0 and 180)
  digitalWrite(ledpin, HIGH);
  delay(val);                           // waits for the servo to get there
  digitalWrite(ledpin, LOW);
  delay(val);
And if you couldnt tell, the code is a modified copy of the knob servo code. That is the reason for the random describing side notes... i was to lazy to finish or delete them.
There is also a making/using vid coming soon....
« Last Edit: April 18, 2010, 07:36:40 pm by Jeremy1998 » Logged
Offline Offline
God Member
View Profile
The only issue I had with the code is that it has to finish the on / off cycle before the speed change is applied. Any help on finxing it?
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
You could throw in another val = analogRead(potpin) and val = map(val, 0,1023, 500, 5); right after it sets the LED pin high, that way the delay is now based on the new value. I guess you could add it in again after the LED pin is set low if you wanted even more precision.
Logged
Siepraw, PL
Offline Offline
Newbie
No time, stroking Cat...
View Profile
WWW
Try reading the actual value of potentiometer in a loop. Something like this:
Code:
int potpin = 0;
int ledpin = 13;
int val;
int lastChange; // the time of changing pin state
  val = map(analogRead(potpin), 0, 1023, 500, 5);  // actual value
  lastChange = millis();  // ledpin state changed NOW
  while(lastChange + val <= millis())  // loop while there's time for it :)
    val = map(analogRead(potpin), 0, 1023, 500, 5);  // read the value every time
  // the same here:
I didn't check it, I don't have the access to IDE right now, but maybe it will work smiley
« Last Edit: April 21, 2010, 07:30:40 am by WRonX » Logged
Finland
Offline Offline
Sr. Member
Arduino rocks
View Profile
This is a slightly simplified version of  WRonX's example.  I haven't actually tested it.
Code:
int potpin = 0;
int ledpin = 13;
int val;
int state = HIGH;
  digitalWrite(ledpin, state);
  if (lastChange + val <= millis())
       state = !state; // invert led's state
  // you can add other functionality here ...
Logged
Siepraw, PL
Offline Offline
Newbie
View Profile
WWW
Stupid me! But yes, it should work and it takes less space smiley
Logged
Offline Offline
God Member
View Profile
it works, but it freezes ALOT
Logged
Siepraw, PL
Offline Offline
Newbie
View Profile
WWW
Can you explain, when and where it freezes?
Logged
Offline Offline
God Member
View Profile
Just when I turn it quick.
Logged
Pages: [1]   Go Up
Print
Jump to:
