Topic: Change Led Fade Speed With Potentiometer (Read 983 times) previous topic - next topic
Jeremy1998
Apr 29, 2010, 05:01 am Last Edit: Apr 29, 2010, 05:04 am by Jeremy1998 Reason: 1
I am so happy :) because this is the first semi-complex project that I did all on my own! Hope you like it!
OK, what this does is fade the led on, wait half a second, fade the led on, wait half a sceond, restart, ect....
You turn the potentiometer to vary the fading speed. This is just another part in my upcoming project. I am also trying to improve this code, and I will replace it, or post it in a reply.
int ledPin = 11;    // LED connected to digital pin 11
int potPin = 0;
int val;
void setup()  {
void loop()  {
val = analogRead(potPin);
val = map(val, 0, 1023, 1, 5);
 for(int fadeValue = 0 ; fadeValue <= 255; fadeValue +=val) {
 analogWrite(ledPin, fadeValue);
 delay(5);
 for(int fadeValue = 255 ; fadeValue >= 0; fadeValue -=val) {
 delay(5);
jon_s
For smoother fading you could make the potentiometer control the delay time while keeping the increment at 1 unit. N.B., I've reversed the map function so that this should (i think) work just like your version:
 val = map(val, 0, 1023, 5, 1);
 for(int fadeValue = 0 ; fadeValue <= 255; fadeValue +=1) {
 delay(val);
 for(int fadeValue = 255 ; fadeValue >= 0; fadeValue -=1) {
 delay(val);
Jeremy1998
thank you tons... that makes it much smoother... i will be replacing the code...
Jeremy1998
new code. special thanks to jon_s for makign the update.
int ledPin = 11;
int potPin = 0;
int val;
void setup()  {
void loop()  {
 delay(750);
 delay(val);
 delay(750);
 delay(val);
mroe updates to come to this code, so follow this thread
