Dubai , UAE
Offline
Newbie
« on: November 23, 2011, 04:50:36 am » |
Hi there,  I am beginner in Arduino Uno. In addition I have basic knowledge about electronics and programing. I am planning to do airship ((blimp)) for UAE National Day. Everything’s perfect from mechanical side except the programing. I don’t how to program the arduino uno codes. Please help me with the prepared codes and how I can I fix the input and output (where I put the signal wires) in my arduino uno. The tools which I have are: 3 servos 2 motors with speed control 2 LED with resister 1 FM receiver - 8channel (Futaba -R168DF) 1 remote control (Futaba - T6EXP) - (PCM 1024) 1 battery 7.25 V Please Help me  with it thanks
Logged
Seattle, WA USA
Offline
Brattain Member
Seattle, WA USA
« Reply #1 on: November 23, 2011, 04:54:02 am » |
1 FM receiver - 8channel (Futaba -R168DF) 1 remote control (Futaba - T6EXP) - (PCM 1024) So, connect the 3 servos and 2 motors to the receiver. Connect the battery to the servo power wires and grounds. Duct tape the Arduino and LEDs on the outside. It doesn't seem to have a purpose.
Logged
Dubai , UAE
Offline
Newbie
« Reply #2 on: November 23, 2011, 05:27:45 am » |
thinks PaulS  I have done this before. Now I want to do it with Arduino  thinks
Logged
Global Moderator
UK
Online
Brattain Member
I don't think you connected the grounds, Dave.
« Reply #3 on: November 23, 2011, 05:33:52 am » |
Now I want to do it with Arduino If only we knew what "it" was, maybe we could help you.
Logged
Pete, it's a fool looks for logic in the chambers of the human heart.
Dubai , UAE
Offline
Newbie
« Reply #4 on: November 23, 2011, 05:50:53 am » |
 I controlled the servo and motors direct from the receiver  Now I want to control them throw Arduino  ]  using remote control  thanks
Logged
Global Moderator
UK
Online
Brattain Member
« Reply #5 on: November 23, 2011, 05:51:54 am » |
Why do you want to make an aerial vehicle less reliable?
Logged
Seattle, WA USA
Offline
Brattain Member
Seattle, WA USA
« Reply #6 on: November 23, 2011, 06:16:54 am » |
Now I want to control them throw Arduino You want the servos to throw the Arduino? I don't get it.
Logged
Dubai , UAE
Offline
Newbie
« Reply #7 on: November 23, 2011, 06:56:49 am » |
this what i men  i don't how i program the arduino and wear to put the input and the output in my arduino
Logged
Leighton Buzzard, UK
Offline
Edison Member
« Reply #8 on: November 23, 2011, 07:02:21 am » |
what do you want the arduino to do ?
Logged
there are only 10 types of people them that understands binary and them that doesn't
Dubai , UAE
Offline
Newbie
« Reply #9 on: November 23, 2011, 07:29:10 am » |
Basic things
To take command from FM Receiver convert to the contacted servos and motors
Motor for speed
2 Servo in different degree both start with 90 degree if I posh the remote gear up servo goes to 180 degree if I pull down servo go to 0 degree
Logged
Global Moderator
UK
Online
Brattain Member
« Reply #10 on: November 23, 2011, 07:33:27 am » |
But you can do that more effectively and with less risk with just a length of wire.
Logged
Seattle, WA USA
Offline
Brattain Member
Seattle, WA USA
« Reply #11 on: November 23, 2011, 07:47:05 am » |
Connect the things that make sense (the motors and servos) directly to the receiver. Connect the unused channels to digital pins, and use pulseIn to collect data from those channels/pins. Use that data for whatever.
You need to define what type of data comes over the unused channels, and what the Arduino should do with it. Then, coding help makes sense.
Having the Arduino read all the channels, and convert the signals to times and back to servo signals doesn't.
Logged
