Loading...
Pages: [1] 2   Go Down
Author Topic: "An error occurred while starting the application"... Arduino acts weird! HELP!  (Read 1652 times)
0
Offline Offline
Newbie
Arduino rocks
View Profile
Arduino IDE was working properly in my pc. Today while starting IDE, it took looong time and gave me the error "An error occurred while starting the application", error box had title "Launch4j". After that the application started, compiled my program without effort... but while uploading to board, it gave lots of java exception and stopped. smiley-cry It also hangs frequently.
A thing to notice, yesterday I ported to 0023 from 0022.
Pease Help! smiley-neutral
Logged
Offline Offline
Newbie
View Profile
Regarding error measage 'Launch4j'.
I got the same error when I was trying to run after upgrade to 1.0  smiley-mad
I traced it to preferences file located in C:\Documents and Settings\'me as user'\Application Data\Arduino preference.txt
I just deleted it - and system the runs  smiley-grin
Logged
Offline Offline
Newbie
View Profile
I'm getting the same error with my Arduino Uno. What should I do?
Logged
Offline Offline
Newbie
View Profile
I get the same error on my Win 7 Enterprise 64 bit machine.Lenovo laptop. WHy  ???? Tried other version including the older 22 version but still error.
Logged
Tucson, AZ
Offline Offline
Sr. Member
View Profile
Delete the preferences file:  Windows XP: C:\Documents and Settings\USER_NAME\Application Data\Arduino preferences.txt
Windows 7: C:\Users\USER_NAME\AppData\Roaming\Arduino\preferences.txt
« Last Edit: July 11, 2012, 07:45:38 pm by kd7eir » Logged
Offline Offline
Newbie
View Profile
My Windows 7 operating system does not go:
That's Windows XP
Windows 7 goes:
C:\Users\USER_NAME\
« Last Edit: July 11, 2012, 06:29:17 pm by tpirman1982 » Logged
Tucson, AZ
Offline Offline
Sr. Member
View Profile
That's Windows XP
Windows 7 goes:
C:\Users\USER_NAME\
Then:
Windows 7: C:\Users\USER_NAME\AppData\Roaming\Arduino\Preferences.txt
Logged
Offline Offline
Newbie
View Profile
Then:
Uh, nope, nope. That did not work either. Nope, nope.
The preferences.txt file keeps coming back every time I try to start it up.
« Last Edit: July 12, 2012, 07:23:58 am by tpirman1982 » Logged
Offline Offline
Newbie
View Profile
Try to use older versions of the Arduino software, this worked for me.
2 out of 3 laptops that I own running windows 7 didn't work for me - looks like windows 7 compatibility is  piss poor but then perhaps it's my Lenovo machines??? Of course this wouldn't happen on Macs or linux machines smiley  but you gotta remember most of the world is sill stuck on Windoze.
Logged
Offline Offline
Newbie
View Profile
In this video...
...I was told:
int Pin = 13;
 //initialize pins as outputs
 pinMode(ledPin, OUTPUT);
 digitalWrite(ledPin, HIGH);
 digitalWrite(ledPin, LOW);
 When I tried to upload that to my Arduino, I got an error which as follows:
 In function `loop':
 error: `ledPin' undeclared (first use in this function)
 What should I do to correct this?
« Last Edit: July 14, 2012, 12:18:05 pm by tpirman1982 » Logged
Tucson, AZ
Offline Offline
Sr. Member
View Profile
At the top of the sketch, change   int Pin = 13;  to  int ledPin = 13;
Logged
Offline Offline
Newbie
View Profile
Ok. I've corrected that, but another error I've found is:
  ledPin(pinMode, OUTPUT);
In function `setup':
error: called object is not a function
What'd I write incorrectly there?
Logged
Tucson, AZ
Offline Offline
Sr. Member
View Profile
This is the sketch as it runs for me, using Arduino 1.0.1:
Code:
int ledPin = 13;
Logged
Offline Offline
Newbie
View Profile
Well, it's not accepting it on mine when I click upload.
Code:
int ledPin = 13;
Logged
Tucson, AZ
Offline Offline
Sr. Member
View Profile
Please post the entire error message that you are getting.
Logged
Pages: [1] 2   Go Up
Print
Jump to:
