Loading...
Pages: [1]   Go Down
Author Topic: Open source and hardware pulseoximeter  (Read 1620 times)
Ukraine
Offline Offline
Newbie
View Profile
I'm building another one (many prototypes shown on youtube, and other places) pulseoximeter.
But I'd like to make it's source and hardware open, to make it easy for everyone to use it with arduino or other devices.
The goal is to build a separate digital/analog sensor
(both digital and analog outputs are possible) for arduino and other devices (like andriod smartphones) with possibility to log data for future reference.
As for now I have working prototype that graphs pulses on computer based on data from serial port.
In a day or two I plan to complete code for detecting pulses (maybe with comparator).
Device built with low-cost, widely used components, processing with arduino and processing (http://processing.org/) for displaying data on PC for testing purposes.
I'm working on signal processing now to output data in digital form.
I have no any project page, hope to do some pictures and videos this weekend.
I'd like to know, if it's interesting to someone and maybe some suggestions on the right direction to move further.
Thank you
Logged
Netherlands
Offline Offline
Tesla Member
In theory there is no difference between theory and practice, however in practice there are many...
View Profile
what is a pulseoximeter?
please provide more links to get more/better help.
Logged
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
Ukraine
Offline Offline
Newbie
View Profile
http://en.wikipedia.org/wiki/Pulse_oximeter
http://en.wikipedia.org/wiki/Pulse_oximetry
Here's some similar project, but seems like was never finished and sources not published.
Logged
Ukraine
Offline Offline
Newbie
View Profile
First steps  smiley
Here will be code and schematic in a day or two: (will update this post later)
http://code.google.com/p/pulsometer/
Logged
India
Offline Offline
Jr. Member
OS Developer, ASIC and FPGA designer
View Profile
WWW
I am working on this project :
pulse oximeter <------->Jeenode(1)<-------->Jeenode(2)<-->Sim300(GSM GPRS)
http://www.nskelectronics.com/heart_beat.html
Jeenode is smaller version of Arduino having with wireless module, and this can be operate through battery 6 V mini I called this node as Jeenode(1) now this node will wirelessly connect to remote Jeenode(2) which is having Sim300 Module.
Logged
Offline Offline
Newbie
View Profile
I did something similar with a schoolproject, picking up pulses using a phototransistor and output it to a sound card. For amplification I just used a single npn transistor as the pulse signals were too weak. I also found a lot of noise came along, so if it helps I found one of the best ways of removing noise was to use either a shield at the back of the thumb and reduce the sample rate to about 8-10 samples per second, that way you do away withthe need of a low pass filter.
Logged
Paris, FRANCE
Offline Offline
Newbie
View Profile
Hello !
i also did something similar in a school project  smiley-eek For this projet i use a light-to-frequency converter (like TSL220) and two LEDs : a RED one and an infrared one alternatively powered with a 555 timer circuit.
The frequency signal was connected to a PC sound-card and the signal analysed with Labview. I don't know if it could help you, but i also made a plastic piece (by machining) which supports the light sensor and the two LEDs and a hole to put your finger in it, in order to avoid perturbation of ambient room light.
I'll search in my old PC folders to find this project files and if i find something interresting i will inform you smiley-wink
Your project is very interresting, good luck smiley-wink
Logged
Bon sang ! mais c'est bien sur !
Pages: [1]   Go Up
Print
Jump to:
