Author Topic: A stand alone programmer flashing using sd card  (Read 279 times)
Hi
I'm new to the arduino platform however am feeling particularly adventurous.
I was wondering would it be possible / practical to use the arduino isp firmware and hack it to read from sd card
so that I can flash bootloader onto virgin chips without a plugging it into my pc. Ideally I also need to change
the fuses as virgin chips run at the default 1MHZ.
Massachusetts, USA
There is a sketch called optiLoader that will burn the Arduino optiboot loader on a bare chip without a PC:
https://github.com/WestfW/OptiLoader
You could build a shield with a ZIF programming socket and burn bootloaders almost as fast as you can press the reset button.
Boston area, metrowest
So the part being programmed does not need a xtal at all?
Massachusetts, USA
If the chip is fresh it is already set to use the internal RC clock.  If you are re-using a chip you are supposed to supply a clock signal.  You can set an
Arduino timer to toggle a data pin at 8MHz and connect that to the XTAL1 pin of the target chip.
The SPI interface is supposed to be run at no faster than half the processor clock (assuming a processor clock <12MHz).  I'm not sure if the default clock counts as 8MHz (the raw speed) or 1MHz (the speed after the pre-scaler).  Probably best to assume 1 MHz.  An SPI speed of 512 KHz (SPI_CLOCK_DIV32) should be safe but for extra margin, try 256 KHz (SPI_CLOCK_DIV84) ,
