Topic: Arduino Control Desktop - ACiD (Read 5805 times) previous topic - next topic
spycatcher2k
Apr 25, 2010, 02:31 am Last Edit: Apr 25, 2010, 02:33 am by spycatcher2k Reason: 1
I got bored tonight, so sat down and wrote this to help me read/write to the ports on my Arduino. Its fairly easy to follow, and remarked throughout.
If you download this and use it, please leave a reply to this post (Just so I can keep a count of users ;) ).
Any comments, or critisism are welcome.
Cheers Arduinees
Spycatcher2k
The Code in next posts
http://www.uk-pcb.co.uk - UK Based PCB Fab Company
I will code for you, but I will also charge you (PM me)
If you don't like my answers, realize : I'm not being cheeky, I'm Just trying to prompt you to use your own brain/google etc.
spycatcher2k
//  ACiD
//  Arduino Control Desktop
// Drew Anderson - 2010 (24/5/10)
// Connect with any com program - I use this as a simple
// In/Out Handler for my VB6 programs - Easy protocol to
// implement.
// send x   -  reset to root menu
// send 4   -  Ask for Digital port values 0=LOW 1=HIGH
// Then just parse the string to read port value
// (reads ALL ports 1 - 13)
// send 2   -  select WRITE HIGH menu
// send 3->0 or a,b or c   -  select port to set HIGH
// send 3   -  select WRITE LOW menu
// send 3->0 or a,b or c   -  select port to set LOW
int level=0;
int tmp1=0;
int sinput=0;
int temp1 = 0;
int temp2 = 0;
int temp3 = 0;
int temp4 = 0;
int temp5 = 0;
int temp6 = 0;
int temp7 = 0;
int temp8 = 0;
int temp9 = 0;
int temp10 = 0;
int temp11 = 0;
int temp12 = 0;
int temp13 = 0;
char prts[]="0000000000000";
 Serial.println("#########################################");
 Serial.println("##                                     ##");
 Serial.println("## Welcome to Arduino Control Desktop  ##");
 Serial.println("##              V0.1 Beta              ##");
 Serial.println(" ");
 Serial.println("1. Report Port Status (Digital Only)");
 Serial.println("2. Set port to high");
 Serial.println("3. Set port to low");
 Serial.println("4. Binary string report");
 Serial.println("5. About");
 int x=0;
 for(x=2;x<14;x++)
   pinMode(x, OUTPUT);
// If you need to set any port to input then do it here
// If you can be bothered, you can make further menus
// to give you the option of setting from the interface.
// pinMode(2, INPUT);
// pinMode(3, INPUT);
// pinMode(4, INPUT);
// pinMode(5, INPUT);
// pinMode(6, INPUT);
// pinMode(7, INPUT);
// pinMode(8, INPUT);
// pinMode(9, INPUT);
// pinMode(10, INPUT);
// pinMode(11, INPUT);
// pinMode(12, INPUT);
// pinMode(13, INPUT);
 if (Serial.available() > 0)
   sinput = Serial.read();
//    Serial.print("sinput = ");
//    Serial.println(sinput);
   // x - Reset to start Screen
   if (sinput=='x')
     level=0;
   // Level 0 - 1 - 4 Choose from root menu
       if ((sinput=='1') & (level==0))
     level=1;
       if ((sinput=='2') & (level==0))
     level=2;
       if ((sinput=='3') & (level==0))
     level=3;
       if ((sinput=='4') & (level==0))
     level=4;
       if ((sinput=='5') & (level==0))
     level=5;
   // Level 2 - 3-9 Zero, and a,b or c  Select port to update HIGH
           if ((sinput=='2') & (level==3))
     //level=4;
     digitalWrite(3, HIGH);
           if ((sinput=='3') & (level==2))
     //level=4;
           if ((sinput=='4') & (level==2))
     //level=4;
     digitalWrite(4, HIGH);
           if ((sinput=='5') & (level==2))
     //level=4;
     digitalWrite(5, HIGH);
           if ((sinput=='6') & (level==2))
     //level=4;
     digitalWrite(6, HIGH);
           if ((sinput=='7') & (level==2))
     //level=4;
     digitalWrite(7, HIGH);
           if ((sinput=='8') & (level==2))
     //level=4;
     digitalWrite(8, HIGH);
           if ((sinput=='9') & (level==2))
     //level=4;
     digitalWrite(9, HIGH);
           if ((sinput=='0') & (level==2))
     //level=4;
     digitalWrite(10, HIGH);
           if ((sinput=='a') & (level==2))
     //level=4;
     digitalWrite(11, HIGH);
           if ((sinput=='b') & (level==2))
     //level=4;
     digitalWrite(12, HIGH);
           if ((sinput=='c') & (level==2))
     //level=4;
     digitalWrite(13, HIGH);
   // Level 2 - 3-9 Zero, and a,b or c  Select port to update LOW
     //level=4;
     digitalWrite(2, LOW);
           if ((sinput=='3') & (level==3))
     //level=4;
     digitalWrite(3, LOW);
           if ((sinput=='4') & (level==3))
     //level=4;
     digitalWrite(4, LOW);
           if ((sinput=='5') & (level==3))
     //level=4;
     digitalWrite(5, LOW);
           if ((sinput=='6') & (level==3))
     //level=4;
     digitalWrite(6, LOW);
           if ((sinput=='7') & (level==3))
     //level=4;
     digitalWrite(7, LOW);
           if ((sinput=='8') & (level==3))
     //level=4;
     digitalWrite(8, LOW);
           if ((sinput=='9') & (level==3))
     //level=4;
     digitalWrite(9, LOW);
           if ((sinput=='0') & (level==3))
     //level=4;
     digitalWrite(10, LOW);
           if ((sinput=='a') & (level==3))
     //level=4;
     digitalWrite(11, LOW);
           if ((sinput=='b') & (level==3))
     //level=4;
     digitalWrite(12, LOW);
           if ((sinput=='c') & (level==3))
     //level=4;
     digitalWrite(13, LOW);
//Lets print the menus to the serial port
if (level==0)
//  Serial.print("Level = ");
//  Serial.println(level);
if(level==1)
 Serial.println("##       Arduino Control Desktop       ##");
 Serial.println("##         Digital port status         ##");
 for(tmp1=2;tmp1<14;tmp1++)
 if (digitalRead(tmp1)==1)
   Serial.print("Pin ");
   if(tmp1<10)
     Serial.print("0");
  Serial.print(tmp1);
 Serial.println(" is currently High.");
      if(tmp1<10)
     Serial.print("0");
   Serial.print(tmp1);
   Serial.println(" is currently Low.");
 Serial.println("x. Return to First Screen");
if (level==2)
 Serial.println("##         Digital port update         ##");
 Serial.println("##            SET PORT HIGH            ##");
 Serial.println("Enter 2-9, for ports 2 -> 9");
 Serial.println("or 0 for 10 - a for 11 - b for 12");
 Serial.println("or finaly c for 13");
 Serial.println("x. Back to main Screen");
if (level==3)
 Serial.println("##             SET PORT LOW            ##");
spycatcher2k
Next part :
if (level==4)
 temp13 = digitalRead(13);
     temp12 = digitalRead(12);
     temp11 = digitalRead(11);
     temp10 = digitalRead(10);
     temp9 = digitalRead(9);
     temp8 = digitalRead(8);
     temp7 = digitalRead(7);
     temp6 = digitalRead(6);
     temp5 = digitalRead(5);
     temp4 = digitalRead(4);
     temp3 = digitalRead(3);
     if (temp13 == 1)
     prts[12]='1';
     prts[12]='0';
     if (temp12 == 1)
     prts[11]='1';
     prts[11]='0';
     if (temp11 == 1)
     prts[10]='1';
     prts[10]='0';
     if (temp10 == 1)
     prts[9]='1';
     prts[9]='0';
     if (temp9 == 1)
     prts[8]='1';
     prts[8]='0';
     if (temp8 == 1)
     prts[7]='1';
     prts[7]='0';
     if (temp7 == 1)
     prts[6]='1';
     prts[6]='0';
     if (temp6 == 1)
     prts[5]='1';
     prts[5]='0';
     if (temp5 == 1)
     prts[4]='1';
     prts[4]='0';
     if (temp4 == 1)
     prts[3]='1';
     prts[3]='0';
     if (temp3 == 1)
     prts[2]='1';
     prts[2]='0';
     delay(10);
     Serial.println(prts);
     delay(10);
level=0;
if (level==5)
 Serial.println("##                About                ##");
 Serial.println("   Very Basic Control Program for the Arduino");
 Serial.println("-=############################################=-");
 Serial.println("Feel free to use, update, cut, copy, paste, mutilate");
 Serial.println("or delete this code. Its given to the world totaly");
 Serial.println("without reservation.");
spycatcher2k
#3
Apr 25, 2010, 02:59 am Last Edit: Apr 25, 2010, 04:13 am by spycatcher2k Reason: 1
I'm using this with serproxy, and telnet accross my network. Turning on and off relays at the moment. Gonna hook up my lamps, tv, amp, projector, and media center to these. Full control of power for my media room from anywhere in my house, now thats just cool.
I'm gonna build three stand alone Arduinos - one for the media room, and two for the workshop/server room. Turn on and off my external hard-drive cluster, drive by drive  :) , and the other to turn on/off the multitude of psu's I got here (seven at last count - maybe time to invest in a vairable psu).
[size=14]
Just a side note, to speedup the interface if using from VB6, I set the baud rate to 57600, and I will Remark out the print menu Serial.println commands. If its working blind, we dont need these.
[/b][/size]
Spycatcher2k
spycatcher2k
#4
Apr 25, 2010, 03:31 pm Last Edit: Apr 25, 2010, 08:19 pm by spycatcher2k Reason: 1
Update of code to Beta 0.2
Main update is to syntax, as well as adding port selection for input/output.
Info at end of code - or send h from serial monitor.
Code part 1 :
//  ACiD V0.3 (Beta)
// Drew Anderson - 2010 (24/4/10)
// Update 25/4/10
// implement.
// send S   -  Ask for Digital port values 0=LOW 1=HIGH
// (reads ALL ports 2 - 13)
// send H   -  select WRITE HIGH menu
// send L   -  select WRITE LOW menu
// send M   -  select MODE for PIN
// send N0. -  Pin number (2 - 0 a,b,c)
// send the letter 'o' or 'i' for output or input
int level=0;
int tmp1=0;
int sinput=0;
int sinput2=0;
int sinput3=0;
int temp1 = 0;
int temp2 = 0;
int temp3 = 0;
int temp4 = 0;
int temp5 = 0;
int temp6 = 0;
int temp7 = 0;
int temp8 = 0;
int temp9 = 0;
int temp10 = 0;
int temp11 = 0;
int temp12 = 0;
int temp13 = 0;
int pm2 = 0 ;
int pm3 = 0 ;
int pm4 = 0 ;
int pm5 = 0 ;
int pm6 = 0 ;
int pm7 = 0 ;
int pm8 = 0 ;
int pm9 = 0 ;
int pm10 = 0 ;
int pm11 = 0 ;
int pm12 = 0 ;
int pm13 = 0 ;
 Serial.begin(57600);
 int x=0;
 for(x=2;x<14;x++)
   pinMode(x, OUTPUT);
sinput=Serial.read();
   if (sinput=='x')
     level=0;
   // M - Set the pinMode of the digital pin
   if (sinput=='M')
     level=7;
   if (sinput=='L')
     level=3;
   if (sinput=='R')
     level=1;
   if (sinput=='H')
     level=2;
   if (sinput=='S')
     level=4;
   if (sinput=='h')
   level=5;
  if (sinput=='P')
  level=6;
  if (level==2)
  if (sinput=='2')
    digitalWrite(2, HIGH);
     if (sinput=='3')
     if (sinput=='4')
     if (sinput=='5')
     if (sinput=='6')
     if (sinput=='7')
  }   if (sinput=='8')
  }   if (sinput=='9')
     if (sinput=='0')
  }   if (sinput=='a')
  }   if (sinput=='b')
  }   if (sinput=='c')
  if (level==3)
  if (sinput=='2')
     if (sinput=='3')
     if (sinput=='4')
     if (sinput=='5')
     if (sinput=='6')
     if (sinput=='7')
  }   if (sinput=='8')
  }   if (sinput=='9')
     if (sinput=='0')
  }   if (sinput=='a')
  }   if (sinput=='b')
  }   if (sinput=='c')
if (level==7)
       if (sinput=='2')
     sinput2='2';
       if (sinput=='3')
     sinput2='3';
       if (sinput=='4')
     sinput2='4';
       if (sinput=='5')
     sinput2='5';
       if (sinput=='6')
     sinput2='6';
       if (sinput=='7')
     sinput2='7';
       if (sinput=='8')
     sinput2='8';
       if (sinput=='9')
     sinput2='9';
       if (sinput=='0')
     sinput2='0';
       if (sinput=='a')
     sinput2='a';
       if (sinput=='b')
     sinput2='b';
       if (sinput=='c')
     sinput2='c';
   if (sinput=='o')
     sinput3='o';
   if(sinput=='i')
     sinput3='i';
   if (sinput2=='2')
   if (sinput3=='o')
   pinMode(2, OUTPUT);
   pm2 = 0;
 if (sinput3=='i')
   pinMode(2, INPUT);
 pm2 = 1;
   if (sinput2=='3')
   if (sinput3=='o')
   pinMode(3, OUTPUT);
   pm3 = 0;
 if (sinput3=='i')
   pinMode(3, INPUT);
 pm3 = 1;
   if (sinput2=='4')
   if (sinput3=='o')
   pinMode(4, OUTPUT);
   pm4 = 0;
 if (sinput3=='i')
   pinMode(4, INPUT);
 pm4 = 1;
   if (sinput2=='5')
   if (sinput3=='o')
   pinMode(5, OUTPUT);
   pm5 = 0;
 if (sinput3=='i')
   pinMode(5, INPUT);
 pm5 = 1;
       if (sinput2=='6')
   if (sinput3=='o')
   pinMode(6, OUTPUT);
   pm6 = 0;
 if (sinput3=='i')
   pinMode(6, INPUT);
 pm6 = 1;
   if (sinput2=='7')
   if (sinput3=='o')
   pinMode(7, OUTPUT);
   pm7 = 0;
 if (sinput3=='i')
   pinMode(7, INPUT);
 pm7 = 1;
   if (sinput2=='8')
   if (sinput3=='o')
   pinMode(8, OUTPUT);
   pm8 = 0;
 if (sinput3=='i')
   pinMode(8, INPUT);
 pm8 = 1;
   if (sinput2=='9')
   if (sinput3=='o')
   pinMode(9, OUTPUT);
   pm9 = 0;
 if (sinput3=='i')
   pinMode(9, INPUT);
 pm9 = 1;
   if (sinput2=='0')
   if (sinput3=='o')
   pinMode(10, OUTPUT);
   pm10 = 0;
 if (sinput3=='i')
   pinMode(10, INPUT);
 pm10 = 1;
   if (sinput2=='a')
   if (sinput3=='o')
   pinMode(11, OUTPUT);
   pm11 = 0;
 if (sinput3=='i')
   pinMode(11, INPUT);
 pm11 = 1;
   if (sinput2=='b')
   if (sinput3=='o')
   pinMode(12, OUTPUT);
   pm12 = 0;
 if (sinput3=='i')
   pinMode(12, INPUT);
 pm12 = 1;
   if (sinput2=='c')
   if (sinput3=='o')
   pinMode(13, OUTPUT);
   pm13 = 0;
 if (sinput3=='i')
   pinMode(13, INPUT);
 pm13 = 1;
if (level==6)
     if (pm13 == 1)
     prts[12]='1';
     prts[12]='0';
     if (pm12 == 1)
     prts[11]='1';
     prts[11]='0';
     if (pm11 == 1)
     prts[10]='1';
     prts[10]='0';
     if (pm10 == 1)
     prts[9]='1';
     prts[9]='0';
     if (pm9 == 1)
     prts[8]='1';
     prts[8]='0';
     if (pm8 == 1)
     prts[7]='1';
     prts[7]='0';
     if (pm7 == 1)
     prts[6]='1';
     prts[6]='0';
     if (pm6 == 1)
     prts[5]='1';
     prts[5]='0';
     if (pm5 == 1)
     prts[4]='1';
     prts[4]='0';
     if (pm4 == 1)
     prts[3]='1';
     prts[3]='0';
     if (pm3 == 1)
     prts[2]='1';
     prts[2]='0';
     if(pm2 ==1)
       prts[1]='1';
       prts[1]='0';
     delay(10);
     delay(10);
if(level==1)
   if(tmp1<10)
     Serial.print("0");
  Serial.print(tmp1);
      if(tmp1<10)
     Serial.print("0");
   Serial.print(tmp1);
if (level==2)
if (level==3)
spycatcher2k
#5
Apr 25, 2010, 03:33 pm Last Edit: Apr 25, 2010, 08:21 pm by spycatcher2k Reason: 1
Code part 2:
  if (level==4)
     if (temp13 == 1)
     prts[12]='1';
     prts[12]='0';
     if (temp12 == 1)
     prts[11]='1';
     prts[11]='0';
     if (temp11 == 1)
     prts[10]='1';
     prts[10]='0';
     if (temp10 == 1)
     prts[9]='1';
     prts[9]='0';
     if (temp9 == 1)
     prts[8]='1';
     prts[8]='0';
     if (temp8 == 1)
     prts[7]='1';
     prts[7]='0';
     if (temp7 == 1)
     prts[6]='1';
     prts[6]='0';
     if (temp6 == 1)
     prts[5]='1';
     prts[5]='0';
     if (temp5 == 1)
     prts[4]='1';
     prts[4]='0';
     if (temp4 == 1)
     prts[3]='1';
     prts[3]='0';
     if (temp3 == 1)
     prts[2]='1';
     prts[2]='0';
     delay(10);
     delay(10);
if (level==5)
 Serial.println("##              V0.2 Beta              ##");
 Serial.println("Commands Available :");
 Serial.println("Mxy - pinMode");
 Serial.println("      x=pin number 2-9, 0=10, a=11, b=12, c=13");
 Serial.println("      y=0 for output, y=1 for input");
 Serial.println("R   - Long port status report 0=LOW, 1=High");
 Serial.println("S   - Report port use in binary style");
 Serial.println("P   - Report pinMode in binary style");
 Serial.println("Hx  - Set port HIGH (pins as M)");
 Serial.println("Lx  - Set port LOW (pins as M)");
 Serial.println("affix command with x e.g : ");
 Serial.println("xH2  - will set pin 2 HIGH ");
 Serial.println("xLa  - will set pin 11 LOW ");
 Serial.println("xM2i - will set pin 2 to INPUT");
spycatcher2k
#6
Apr 25, 2010, 05:40 pm Last Edit: Apr 25, 2010, 08:22 pm by spycatcher2k Reason: 1
Had to edit the above code - It just didn't work properly. Should be OK now.
Spycatcher2k
And again
Still a work on progress though.
Any ideas to enhance this project then leave a reply.
cr0sh
#7
Apr 26, 2010, 12:09 am Last Edit: Apr 26, 2010, 12:10 am by keeper63@cox.net Reason: 1
First off, this looks like a very useful project, most likely as a debugging tool - I think it is something that should be submitted to the playground once you have it past the beta stage.
What I would suggest improving, though, is removing the redundant code; you have many areas that could be simplified into singular functions (such as the banner output), as well as where loop constructs or other constructs could be applied. Doing these things would vastly simplify the sketch, and likely reduce its footprint (size) on the Arduino.
spycatcher2k
#8
Apr 26, 2010, 01:55 am Last Edit: Apr 26, 2010, 02:01 am by spycatcher2k Reason: 1
Updated - Smaller, and Some logic errors fixed.
//  ACiD V1.0
// implement.
int level=0;
int tmp1=0;
int sinput=0;
void bannertop()
void bannerbase()
void bannerinst()
{  Serial.println(" ");
 bannertop();
 bannerbase();
 int x=0;
 for(x=2;x<14;x++)
   pinMode(x, OUTPUT);
   if (sinput=='x')
     level=0;
   if (level==0)
       if (sinput=='1')
     level=1;
       if (sinput=='2')
     level=2;
       if (sinput=='3')
     level=3;
       if (sinput=='4')
     level=4;
   if(level==2)
           if (sinput=='2')
           if (sinput=='3')
           if (sinput=='4')
           if (sinput=='5')
           if (sinput=='6')
           if (sinput=='7')
           if (sinput=='8')
           if (sinput=='9')
           if (sinput=='0')
           if (sinput=='a')
           if (sinput=='b')
           if (sinput=='c')
    if(level==3);
           if (sinput=='2')
           if (sinput=='3')
           if (sinput=='4')
           if (sinput=='5')
           if (sinput=='6')
           if (sinput=='7')
           if (sinput=='8')
           if (sinput=='9')
           if (sinput=='0')
           if (sinput=='a')
           if (sinput=='b')
           if (sinput=='c')
if (level==0)
 bannertop();
 bannerbase();
if(level==1)
 bannertop();
 bannerbase();
   if(tmp1<10)
     Serial.print("0");
  Serial.print(tmp1);
      if(tmp1<10)
     Serial.print("0");
   Serial.print(tmp1);
if (level==2)
 bannertop();
 bannerbase();
 bannerinst();
if (level==3)
 bannertop();
 bannerbase();
 bannerinst();
if (level==4)
     for(int x=2;x<13;x++)
     Serial.print(digitalRead(x));
     Serial.println(digitalRead(13));
level=0;
spycatcher2k
Just a minor note - the About (function 5) has been removed. But is still on the main menu :-[. Cheers to my youngest son for spotting that, I will sort this on the next update.
Cheers again Arduinees
Spycather2k
spycatcher2k
Is anyone downloading and using this ? ? ?
if you are please E-Mail me : arduino01@badnetwork.co.uk
or leave a reply here.
spycatcher2k
In the last code posted above, remove the; at the end of the line with
if(level==3); <--  should not be there - sorry  :o
spycatcher2k
Updated the logic (does not turn on pins 3 when you change menu level). Thanks to REX510 for the feedback.
the updated code :
//  ACiD V1.1
// Drew Anderson - 2010 (01/05/10)
// implement.
int level=0;
int tmp1=0;
int sinput=0;
void bannertop()
 Serial.println("##                V1.0                 ##");
void bannerbase()
void bannerfoot()
 bannertop();
 bannerbase();
 int x=0;
 for(x=2;x<14;x++)
   pinMode(x, OUTPUT);
   if (sinput=='x')
     level=0;
   if (level==0)
       if (sinput=='1')
     level=1;
     sinput=' ';
       if (sinput=='2')
     level=2;
     sinput=' ';
       if (sinput=='3')
     level=3;
     sinput=' ';
       if (sinput=='4')
     level=4;
     sinput=' ';
   if(level==2)
           if (sinput=='2')
           if (sinput=='3')
           if (sinput=='4')
           if (sinput=='5')
           if (sinput=='6')
           if (sinput=='7')
           if (sinput=='8')
           if (sinput=='9')
           if (sinput=='0')
           if (sinput=='a')
           if (sinput=='b')
           if (sinput=='c')
   //level=1;
    if(level==3)
           if (sinput=='2')
           if (sinput=='3')
           if (sinput=='4')
           if (sinput=='5')
           if (sinput=='6')
           if (sinput=='7')
           if (sinput=='8')
           if (sinput=='9')
           if (sinput=='0')
           if (sinput=='a')
           if (sinput=='b')
           if (sinput=='c')
   //level=1;
if (level==0)
 bannertop();
 bannerbase();
if(level==1)
 bannertop();
 bannerbase();
   if(tmp1<10)
     Serial.print("0");
  Serial.print(tmp1);
      if(tmp1<10)
     Serial.print("0");
   Serial.print(tmp1);
if (level==2)
 bannertop();
 bannerbase();
 bannerfoot();
if (level==3)
 bannertop();
 bannerbase();
 bannerfoot();
if (level==4)
level=0;
doublet
#13
May 01, 2010, 06:18 pm Last Edit: May 01, 2010, 06:22 pm by doublet Reason: 1
The first time I was able to upload it to the board. Then I opened up the serial, but the only things I got were:
))))))©JBJÂ
)J-B
JJ)J-))))))      Æ
HJ
R
HFBHB
And so on. I tried resetting the board, but I got the same. Then I tried re-uploading, but I got an 'error compiling'... I closed the IDE, and re-opened it, now I was able to reupload your code, but still the same characters... Has it something to do with the fact I try it with the serial monitor?
EDIT: when I tried to open up a serial example and upload that sketch to verify my serial works, it also had to reopen the IDE and then it worked fine...
ah642403hy
#14
May 01, 2010, 06:25 pm Last Edit: May 01, 2010, 06:25 pm by ah642403hy Reason: 1
doublet are you using 57600 BAUD in the serial monitor?
