Loading...
Pages: [1]   Go Down
Author Topic: ask: communication arduino with tcp winsock!!!!!!!!  (Read 999 times)
Offline Offline
Newbie
View Profile
all my dear friends
help me
i get code
Code:
// Arduino firmware for Andriod Robot Project
// Command:   X  F  B  L  R  FR    FL    BR   BL    H
// PORT_map:  -  1  2  4  8   9     5    10   6     16 (PORTB HEX)
// Received:  0  1  2  3  4   5     6    7    8     9  (from router)
// Pin        -  8  9  10 11  811   810  911  910   12
unsigned char port_map[10]={0,1,2,4,8,9,5,10,6,16};
unsigned int in_char;
unsigned long counter=0;
unsigned char in_byte=0;
unsigned int test=0;
DDRB=B11111111; //PORTB as OUTPUT
Serial.begin(9600); //Start Serial
} char recv_char()
while (counter < 15000) //Pulse of command
counter++;
if (Serial.available() > 0)
in_byte = Serial.read();
test=(int)in_byte-48;
Serial.print(test);
counter = 0;
return test;
counter=0;
return 0;
} void loop()
in_char=recv_char();
PORTB=port_map[in_char]; //Port map
my goal to communication arduino and tcp socket linksys ddwrt to control motor dc
looks like well .. but i can control device correct...
what is that corrcetlly code ... or .. i have some missing code .. to communication well drive motor dc
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
That code looks like something a bunch of monkeys playing with typewriters might have come up with.
While the compiler doesn't care about white space, people do. I don't think you are asking a compiler to read and comment on your code. Before you ask people to, you need to make it presentable. Each { goes on its own line. Functions do not go on the same line as }. Random indenting is a pain the derriere to read.
Logged
Offline Offline
Newbie
View Profile
Code:
// Arduino firmware for Android Robot Project
char recv_char()
    counter++;
      Serial.print(test);
      counter = 0;
      return test;
  counter=0;
  return 0;
just read the algoritme brother
i think it was clearly
Logged
0
Online Online
Tesla Member
Arduino rocks
View Profile
Quote
english please
Logged
Why I like my 2005 rio yellow Honda S2000 with the top down, and more!
GOOGLE ADVANCED FORUM SEARCH BELOW!
Go to:  http://www.google.com/advanced_search?hl=en
put in key search words,
use site or domain:  http://arduino.cc/forum
or in a google search box put key words site:http://arduino.cc/forum
Offline Offline
Newbie
View Profile
I think he is trying to do the same thing i am. He is trying to control dc motors using an arduino interfaced with a router running dd-wrt via serial.
@Rhenfri - Follow these links. They will help
Serial communication with DD-wrt:
http://www.andrewhazelden.com/blog/2010/01/how-to-use-the-serial-ports-on-a-linksys-wrt54gs-with-dd-wrt-v24/
Jon Bennett's RC car setup:
http://www.jbprojects.net/projects/wifirobot/
The post I literally just did asking for help with the same thing (includes the code i am currently using)
http://arduino.cc/forum/index.php/topic,80474.0.html
Logged
Pages: [1]   Go Up
Print
Jump to:
