Loading...
Pages: [1]   Go Down
Author Topic: ATX power supply to power arduino  (Read 418 times)
Offline Offline
Newbie
View Profile
I want to convert a pc power supply to power my DFRduino mega 2560, but is the 12 volt rail is too high for the arduino as the upper limit it is rated to is 12V. If it is could I use a circuit like the following to reduce the voltage?
http://powersupply88.com/simple-12-volt-to-9-volt-dc-dc-converter.html
I'm assuming as a power supply is used in a pc all its outputs would be regulated, is that right?
Last question: The 12volt rail is rated as having an 8amp output is that the maximum it can output?
My arduino is arriving tomorrow so the last thing I want to do is blow it on its first use smiley-razz
Logged
Leighton Buzzard, UK
Offline Offline
Edison Member
View Profile
why not use the 5v output?
Logged
there are only 10 types of people
them that understands binary
and them that doesn't
Manchester (England England)
Offline Offline
Brattain Member
Solder is electric glue
View Profile
WWW
Quote
Why do you think that. The limit says 12V and your power supply gives 12V, it will be fine.
Logged
Topsham, Vermont USA
Offline Offline
Edison Member
... in The Woods In Vermont
View Profile
WWW
Especially if you are not drawing very much 5V current, the limit is not critical.. If it was 12.8V I do not think there's a problem...
At the relatively small current you are drawing you could put a typical rectifier silicon diode (like 1N4002 thru 1N4008 ) in series with the 12V lead which will drop about .7 volts..
Logged
Regards, Terry King terry@yourduino.com  - Check great prices, devices and Arduino-related boards at http://YourDuino.com
HOW-TO: http://ArduinoInfo.Info
Offline Offline
Newbie
View Profile
Too low
@Grumpy_Mike
I thought if the supply spiked it might be a problem
Logged
Offline Offline
Brattain Member
View Profile
WWW
No.
1) regulated power supplies don't spike.
2) The 12V limit is only based on the regulator heat dissipation issue see http://www.thebox.myzen.co.uk/Tutorial/Power_Examples.html the true upper limit is likely to be 16V or 25V depending on the rating of the input capacitors.
Logged
Offline Offline
Newbie
View Profile
Thanks that answered my other question about regulation. Thanks for the fast responses  smiley
Logged
Austin, TX
Offline Offline
Faraday Member
CMiYC
View Profile
WWW
Keep in mind that ATX Power Supplies generally need a minimum load for regulation.  The one I have sitting on my desk says each rail (except standby and -12) needs a minimum load of 1 amp.  Without the min load, the voltage varies quite a bit.
Logged
www.cmiyc.com - A guide to being an Enginerd
Offline Offline
Brattain Member
View Profile
WWW
Quote
Quote from: mmcp42 on November 20, 2011, 07:32:05 PM
Too low
No it's not, all you need to do is to connect it to the +5V pin not the Vin or power jack.
Logged
Humboldt, CA
Offline Offline
Full Member
Arduino BBB
View Profile
If it is an older PSU you will likely need a load on it to keep the voltages stable.  Plug some old HDD into it, that ought to do it.  Be aware that you may need an oscilloscope to see the voltage variations, they're often too fast to see with a multimeter.
Some modern units don't need a load on them, but they're all >$100 units and slightly excessive for Arduino use.
Logged
Pages: [1]   Go Up
Print
Jump to:
