Topic: arduino + camera + sd memory card (Read 46651 times) previous topic - next topic
f_ametia_p
hello everyone, i'm newbie in this forum..
this is my first time experience using arduino and i'm interesing in this project and this post is very usefull for me..
but i still understand how to interface the sd card with the EEPROM..
I'm using Arduino Deamilanova,
Breakout Board for SD-MMC Cards
and C328 camera module
thank you very much for your help.
PaulS
I think that the 1st question isn't
Quote
. The 1st question is why?
What is it you want to do that involves both EEPROM and the SD card?
f_ametia_p
#17
Dec 08, 2009, 01:14 pm Last Edit: Dec 09, 2009, 05:34 am by f_ametia_p Reason: 1
okay i get it now..
EEPROM and SD/MMC Card both are same memory..
i don't need to us both of them at the same time..
thank you very much for the information..
this is my first project on arduino
I'm already compiling the sketch the code from jarv website http://jarv.org/sdcam.shtml
but i get some errors here (same like posox and stan49) :
/Users/posox2000/Documents/Arduino/libraries/sdc328/sd_raw.c: In function 'sd_raw_init':
/Users/posox2000/Documents/Arduino/libraries/sdc328/sd_raw.c:184: error: 'PB2' undeclared (first use in this function)
/Users/posox2000/Documents/Arduino/libraries/sdc328/sd_raw.c:184: error: (Each undeclared identifier is reported only once
/Users/posox2000/Documents/Arduino/libraries/sdc328/sd_raw.c:184: error: for each function it appears in.)
/Users/posox2000/Documents/Arduino/libraries/sdc328/sd_raw.c: In function 'sd_raw_read':
/Users/posox2000/Documents/Arduino/libraries/sdc328/sd_raw.c:471: error: 'PB2' undeclared (first use in this function)
/Users/posox2000/Documents/Arduino/libraries/sdc328/sd_raw.c: In function 'sd_raw_write':
/Users/posox2000/Documents/Arduino/libraries/sdc328/sd_raw.c:719: error: 'PB2' undeclared (first use in this function)
/Users/posox2000/Documents/Arduino/libraries/sdc328/sd_raw.c: In function 'sd_raw_get_info':
/Users/posox2000/Documents/Arduino/libraries/sdc328/sd_raw.c:864: error: 'PB2' undeclared (first use in this function)
I am using "Adruino Duemilanove" and arduino0017 as compiler
i already read the latest post on this topic but i can't find the answer..
can you guys help me?
thanks
greyskale
Bumping this thread, has there been a resolution to the above issue?
I tried the same thing. Downloaded the package from:
Tried to compile the example code and got the following error:
/home/erik/arduino-0018/libraries/sdc328/sd_raw.c: In function 'sd_raw_init':
/home/erik/arduino-0018/libraries/sdc328/sd_raw.c:184: error: 'PB2' undeclared (first use in this function)
/home/erik/arduino-0018/libraries/sdc328/sd_raw.c:184: error: (Each undeclared identifier is reported only once
/home/erik/arduino-0018/libraries/sdc328/sd_raw.c:184: error: for each function it appears in.)
/home/erik/arduino-0018/libraries/sdc328/sd_raw.c: In function 'sd_raw_read':
/home/erik/arduino-0018/libraries/sdc328/sd_raw.c:471: error: 'PB2' undeclared (first use in this function)
/home/erik/arduino-0018/libraries/sdc328/sd_raw.c: In function 'sd_raw_write':
/home/erik/arduino-0018/libraries/sdc328/sd_raw.c:719: error: 'PB2' undeclared (first use in this function)
/home/erik/arduino-0018/libraries/sdc328/sd_raw.c: In function 'sd_raw_get_info':
/home/erik/arduino-0018/libraries/sdc328/sd_raw.c:864: error: 'PB2' undeclared (first use in this function)
any advice would be appreciated
kokepiola
grayscale: debes entrar a sd_raw_config.h y cambiar:
#define select_card() PORTB &= ~(1 << PINB2)
  #define unselect_card() PORTB |= (1 << PINB2)
#define configure_pin_available() //DDRC &= ~(1 << DDC4)
#define configure_pin_locked() //DDRC &= ~(1 << DDC5)
#define get_pin_available() 0 //((PINC >> PC4) & 0x01)
#define get_pin_locked() 0 //((PINC >> PC5) & 0x01)
luego te vas a sdcamera.cpp y pones en comillas
SDCameraC328R::SDCameraC328R()
   _packageSize = DEFAULT_PACKAGE_SIZE;
   _sd = 0;
   _file_counter = 0;
  /** set_output(DDRD,LED); */
   strcpy(filename, "picture.jpg");
suerte.
HOW READ THE SD CARD..........I CANT READ SD CARD
kokepiola
perdon es
#define get_pin_locked() 1
good luck
greyskale
#21
Mar 31, 2010, 06:31 am Last Edit: Mar 31, 2010, 09:14 pm by greyskale Reason: 1
I don't think thats the fix. PB2 on the AVR is technically digital pin 10 on the arduino. I modified the files suggested, but after trying to compile again I get the following:
/home/erik/arduino-0018/libraries/sdc328/SDCameraC328R.cpp: In member function 'uint8_t SDCameraC328R::update_exif_GPGGA(char*)':
/home/erik/arduino-0018/libraries/sdc328/SDCameraC328R.cpp:195: error: 'strtok' was not declared in this scope
/home/erik/arduino-0018/libraries/sdc328/SDCameraC328R.cpp: In member function 'uint8_t SDCameraC328R::update_exif_GPRMC(char*)':
/home/erik/arduino-0018/libraries/sdc328/SDCameraC328R.cpp:279: error: 'strtok' was not declared in this scope
Because it's also tripping up on strtok (C++ function no?) I'm pretty sure this is a gcc version issue, I'm running avr-gcc 4.3.3 ubuntu 9.10. I can't for the life of me figure out how  to update to an newer version, any advise?
Edit: I spoke with the author jarv. He is running avr-gcc 4.3.4. I'm really suspecting a version issue at this point. If anyone can advise me on how to update my avr-gcc version to 4.3.4 I would appreciate it. I thought I had accomplished it last night, but after a very long compile, I checked my version with avr-gcc --v but still get 4.3.3 as the result.
caps
i just began work with arduino, and i need to set up something like this, but i don't have a GPS. How would i make this without the GPS?
SmokeyNinja
It seems that I will be bumping this thread, again.
I was wondering is anyone has had any success using avr-gcc as opposed to the arduino IDE.  This implementation of these components would be excellent for a project I am working on, but the arduino v00018 returns the same errors for me that other user's have experienced.
Regrettably, I am an utter AVR newb, and I don't have any idea of where to begin in terms of uploading jarv's program to an arduino (deumilonove, atmega328).  I am running win7 and I have installed winarv.  If anyone could provide some direction it would be greatly appreciated.
maxbot
Great work !
My problem is that I want to use the C328R camera together with the S65 Shield from Watterott. (which has a micro sd slot included)
The demo included to write to the card is the following:
Code: [Select]
void write_something(void)
 FIL fdst;     //file objects
 FRESULT res;  //result code
 UINT wr;      //file R/W count
 char data[16];
 res = f_open(&fdst, "xxx.txt", FA_CREATE_ALWAYS | FA_WRITE);
 if(res == FR_OK)
   strcpy(data, "test 123");
   res = f_write(&fdst, data, strlen(data), &wr);
   f_close(&fdst);
How can I implement this code into your one in the first post ?
Thanks for any help  :)
bach_tenor
I'm using some of this code for a project I'm working on, and since the thread isn't THAT old I figure I'll add this in case anyone is still out there having compile problems.
It is an AVR-GCC version issue as far as I can tell, and I installed the latest version of Ubuntu (10.04) and installed the Arduino stuff and everything works fine. Compiling on Windows still yields the PB2 error.
cowjam
That's very cool.
I've found a British supplier of small cameras with onboard JPEG encoding.  I don't know the difference between TTL and RS232 - could someone enlighten me?
http://www.coolcomponents.co.uk/catalog/index.php?cPath=45
