Topic: avrsh: make program (Read 1 time) previous topic - next topic
jippie
I am trying to figure out http://www.battledroids.net/downloads/avrsh.html
I can compile it on my Linux box and the next step is 'make program' to send the .hex file to my Arduino from the command line. Now because I'm not using the standard dev tools, I am afraid I will kill the standard bootloader with uploading the .hex file. If Avrsh isn't what I was looking for I want to be able to use my Arduino in the 'normal' way.
Is my fear of killing the bootloader by programming Avrsh from the command line realistic? Can I safely upload and reuse my Arduino if I change my mind? I have no ICSP AVR tools.
Any help is welcomed. Thnx!
johnwasser
If you have a second Arduino you can use it to re-load the bootloader if it gets damaged by the process.
I looked at the makefile and it looks like it doesn't do a Chip Erase or change the flag/lock bytes so it should be safe for your bootloader.
Send Bitcoin tips to: 1L3CTDoTgrXNA5WyF77uWqt4gUdye9mezN
Send Litecoin tips to : LVtpaq6JgJAZwvnVq3ftVeHafWkcpmuR1e
jippie
Thanks for your quick reply!
No I haven't, but I like the concept. Any smart keywords to Google for?
Ah that sounds good!
Just for me to learn a bit more from this, are these simple keywords I can check for myself too in Makefiles or are there pitfalls and do I need a lot of experience?
johnwasser
ArduinoISP
First link is http://arduino.cc/en/Tutorial/ArduinoISP
One step they forget to mention is disabling auto-reset on the Arduino being used as an ISP.
Also: optiLoader is a sketch that contains several versions of the optiboot bootloader (like on the UNO) which will program a fresh bootloader onto another Arduino without needing a PC.
It's not very easy to see.  What you are looking for is the 'avrdude' command line options for Chip Erase (-e) or fuse setting (-U efuse, hfuse, lfuse, lock).  If none appear it is likely that the makefile is NOT asking avrdude to do anything but write the application (non-boot) FLASH.
jippie
Thnx for your clear elaboration. I can Google a bit more from here.
jippie
I switched to an Arduino Mega and http://bitlash.net/ because I have the impression it has a bit more support for scripting.
I did use the ArduinoISP idea though, be it to program an ATtiny for my mouseWiggler :)
Thanks for helping me discover the world of Arduino a little further!
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
