Topic: led multiplexing (Read 1 time) previous topic - next topic
ze3one
Hi, I'm multiplexing some led, so I started with 4 * 4, anode in \\ cathode in \\ with 1k resistor and I'm using an 74hc164n chip, so I use only 2 pin to control each one but between each shift out all led light up (very low intensity but I still can see them lighten).
Code: [Select]
int dataPin=11;
int clockPin=12;
int del = 350;
int aA = B00010001;
int aB = B00010010;
int aC = B00010100;
int aD = B00011000;
int bA = B00100001;
int bB = B00100010;
int bC = B00100100;
int bD = B00101000;
int cA = B01000001;
int cB = B01000010;
int cC = B01000100;
int cD = B01001000;
int dA = B10000001;
int dB = B10000010;
int dC = B10000100;
int dD = B10001000;
void setup(){
  pinMode(clockPin, OUTPUT);
  pinMode(dataPin, OUTPUT);
void loop(){
shiftOut(dataPin, clockPin, LSBFIRST, aA);
delay(del);
shiftOut(dataPin, clockPin, LSBFIRST, aB);
delay(del);
shiftOut(dataPin, clockPin, LSBFIRST, aC);
delay(del);
shiftOut(dataPin, clockPin, LSBFIRST, aD);
delay(del);
shiftOut(dataPin, clockPin, LSBFIRST, bA);
delay(del);
shiftOut(dataPin, clockPin, LSBFIRST, bB);
delay(del);
shiftOut(dataPin, clockPin, LSBFIRST, bC);
delay(del);
shiftOut(dataPin, clockPin, LSBFIRST, bD);
delay(del);
shiftOut(dataPin, clockPin, LSBFIRST, cA);
delay(del);
shiftOut(dataPin, clockPin, LSBFIRST, cB);
delay(del);
shiftOut(dataPin, clockPin, LSBFIRST, cC);
delay(del);
shiftOut(dataPin, clockPin, LSBFIRST, cD);
delay(del);
shiftOut(dataPin, clockPin, LSBFIRST, dA);
delay(del);
shiftOut(dataPin, clockPin, LSBFIRST, dB);
delay(del);
shiftOut(dataPin, clockPin, LSBFIRST, dC);
delay(del);
shiftOut(dataPin, clockPin, LSBFIRST, dD);
delay(del);
johnwasser
I think the problem is that the shift register has no latch signal so the data being clocked through gets displayed.  Perhaps it would get better if you pulled the Clear pin low between displays.  That would clear all the data but any 1 bit you clock in will appear on each pin in turn until it reaches its final position.  If you use a latched shift register the data only appears on the outputs when you set the latch HIGH.
Send Bitcoin tips to: 1G2qoGwMRXx8az71DVP1E81jShxtbSh5Hp
Grumpy_Mike
