Topic: Single-sided Arduino-Leonardo board (Read 6629 times) previous topic - next topic
tormentor
  Hello. Here is my attempt to create single-sided Arduino-Leonardo clone, with possibility of DIY-photoresist production. Designed in KiCAD. Dual LDOs (3.3V and 5V), additional connectors for RS232, I2C, SPI/ISP.
  Project repository: https://bitbucket.org/edartuz/ul_arduino_leonardo
tormentor
#1
Nov 29, 2011, 02:07 pm Last Edit: Nov 29, 2011, 02:09 pm by tormentor Reason: 1
Almost done, used 16 jumper wires:
Graynomad
#2
Nov 29, 2011, 03:53 pm Last Edit: Nov 29, 2011, 03:57 pm by Graynomad Reason: 1
Quote
C'mon, you can do better :)
Where did you get a schematic to copy, I thought they weren't released yet.
______
Rob
Rob Gray aka the GRAYnomad www.robgray.com
tormentor
Quote
most info here:
http://arduino.cc/forum/index.php/topic,78781.180.html
http://arduino.cc/forum/index.php?topic=78639.0
I don't think its far from official design, so final changes will be small
Graynomad
OK, no wonder I didn't see it, my Spanish is a little weak so I tend to skip that forum :)
______
Rob
32teeth
westfw
I think you should move your traces further apart.  In most cases (ie the traces going to the digital IO pins), you have plenty of room...
CrossRoads
The 2nd link has built in google translate (click the UK flag)
fm
#9
Dec 01, 2011, 08:53 pm Last Edit: Dec 01, 2011, 08:56 pm by fm Reason: 1
Hi chaps,
since you've been following the Spanish thread I thought I would share with you the last events. The boards have arrived and are going to be beta tested by the vinciDuino team.
The boards look great. Currently waiting for components to arrive.
You can find all the information about the board: https://bitbucket.org/fmalpartida/vinciduino/wiki/Home
Released under CC SA-BY.
I will keep you posted.
CrossRoads
frank26080115
please use thermal pads on the ground plane
Freelance engineer, consultant, contractor. Graduated from UW in 2013.
CrossRoads
??frank ?? Looks like its covered with ground plane on both sides.
Maybe could have used some more around the regulator, IC2.
frank26080115
http://en.wikipedia.org/wiki/Thermal_pad_(electronics)
fm
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
