Topic: Control water pump through sms using a old sony phone interfaced with arduino (Read 2055 times) previous topic - next topic
hbkwant
I want to compare the received message with string "ON" and "OFF"
and if the message contains ON then set a digital pin high for 30 minutes max and
if OFF is received then set that digital pin Low.
  delay(3000);
  Serial.println("AT+CPMS=\"ME\"");  // AT commands for sony T610
  delay(3000);
  Serial.println("ATE=0");  // ECHO off
  delay(3000);
  Serial.println("AT+CMGF=1");    //text format
  delay(3000);
  Serial.println("AT+CMGR=1");   //read text message from the location 1 of the phone
  delay(3000);
  if (Serial.available() > 0) {
    /* Now i cant understand how to assign that
    data string received in the form of text message to a memory
    locaton on arduino and compare with another string and
    then do the appropriate action.*/
   /* I want to compare the received message with string "ON" and "OFF"
    if off is received then set that digital pin Low
PLEASE HELP ME I GOT STUCK...
MarkT
How about using NewSoftSerial to interface to the phone and then the normal Serial library can be used to debug via USB so you can see what's coming from the phone?
