Topic: Control water pump through sms using a old sony phone interfaced with arduino (Read 1 time) previous topic - next topic
hbkwant
  delay(3000);
  Serial.println("AT+CPMS=\"ME\"");  // AT commands for sony T610
  delay(3000);
  Serial.println("ATE=0");  // ECHO off
  delay(3000);
  Serial.println("AT+CMGF=1");    //text format
  delay(3000);
  Serial.println("AT+CMGR=1");   //read text message from the location 1 of the phone
  delay(3000);
  if (Serial.available() > 0) {
    /* Now i cant understand how to assign that
    data string received in the form of text message to a memory
    locaton on arduino and compare with another string and
    then do the appropriate action.*/
   /* I want to compare the received message with string "ON" and "OFF"
    and if the message contains ON then set a digital pin high for 30 minutes max and
    if off is received then set that digital pin Low
PaulS
Embedding your questions in the comments is a good way to get ignored. I'd recommend that you not do that again.
I'd recommend that you learn how to read serial data, how to save it an an array, and how to parse that data, before you worry about what to do with a value received from the phone.
http://jhaskellsblog.blogspot.com/2011/05/serial-comm-fundamentals-on-arduino.html
zoomkat
Below is some simple on/off test code Use the # post tool bar to use the code tags.
// zoomkat 8-6-10 serial I/O string test
// type a string in serial monitor. then send or enter
// for IDE 0019 and later
int ledPin = 13;
String readString;
  pinMode(ledPin, OUTPUT);
  Serial.println("serial on/off test 0021"); // so I can keep track
  while (Serial.available()) {
    delay(1);
    char c = Serial.read();
    readString += c;
  if (readString.length() >0) {
    Serial.println(readString);
    if (readString == "on")
      digitalWrite(ledPin, HIGH);
    if (readString == "off")
      digitalWrite(ledPin, LOW);
    readString="";
power7net
I make this for control led with serial communication with sony ericsson k700....
//Remote control GSM V 1.0
int ledPin=13;
String readString;
char c;
  pinMode(ledPin,OUTPUT);
  delay(12000);
  delay(3000);
  Serial.println("AT+CPMS=\"ME\",\"SM\"");//Set memory phone
  delay(5000);
  Serial.println("ATE=0");//Echo off
  delay(3000);
  readsms:
  Serial.println("AT+CMGR=1");//Read sms
  delay(5000);
     delay(100);
  // read phone reply if available
                c=Serial.read(),BYTE;
                readString+=c;
              if (readString.indexOf("96xxxxxxxx")>0 &&(readString.indexOf("34F670C")>0)//admin and pdu "on"
                 digitalWrite(ledPin,HIGH);
                 goto delsms;
              if (readString.indexOf("96xxxxxxxx")>0 &&(readString.indexOf("44FA33106")>0)
                 digitalWrite(ledPin,LOW);
                 goto delsms;
  delsms:
  Serial.println("AT+CMGD=1");//Delete sms
  delay(120000);
  goto readsms;
Web / sms / bluetooth / arduino / android remote control. Home Automation projects.
http://www.power7.net
hbkwant
i dont understand this ......please clarify...this code line
readString.indexOf("96xxxxxxxx")>0 &&(readString.indexOf("44FA33106")>0)..
may be 96xxxxxxx in the no.
and hex code..... "44fa33106" meant?
hbkwant
okk i got it.....
34F670C meant ON1
and same manner for OFF1..
thanks for the help
s2sobhani
hi
please help me..
i used sony ericsson k810i + arduino uno but thats not work..
at commands work with hyper terminal
please help
my code :
int ledPin=13;
String readString;
char c;
  void delsms(){
    Serial.println("AT+CMGD=1");//Delete sms possition 1
  delay(12000);
  delay(3000);
  delay(5000);
  delay(3000);
  readsms:
  delay(5000);
     delay(100);
                readString+=c;
              if (readString.indexOf("9377404499")>0 &&(readString.indexOf("34F670C")>0))//admin and pdu "on"
                 delsms;
              if (readString.indexOf("9377404499")>0 &&(readString.indexOf("44FA33106")>0))
                 delsms;
PeterH
"Not work" doesn't give us any idea what you want it to do or what it's actually doing.
Your sketch seems to be writing AT commands to the hardware serial port, and reading responses from the same port. Usually this port would be used for communication with the PC so that you can see what is going on. Trying to connect more than one device to a given serial port is asking for trouble. How is the Arduino connected to the modem and to the PC?
I only provide help via the forum - please do not contact me for private consultancy.
s2sobhani
hi thanks for repply
sony ericsson k810i rx tx is connected to pins 0 and 1..i use pin 13 for output..
i wanna switch pin 13 to ON(with ON1) and OFF (with OFF1)..
every thing work correct but when send sms to k810i nothing heppend..
i tested it with usb power and 12V 1.5A power adaptor
arduinu connected to pc with usb and pins 0 1 connected to k810i but when i wanna send sms i plug out usb..
thanks for help
