Loading...
Pages: [1]   Go Down
Author Topic: Need Help Programming Multiple Continuous Rotation Servos  (Read 807 times)
Offline Offline
Newbie
View Profile
So I have 3 continuous rotation Parallax servos, 3 pushbutton switches, and a motor, hooked up to my breadboard/arduino duemilanove on the digital pins. The servos are each attached to a pinion in a rack and pinion system, so that each one will descend a piston of sorts. Whenever a pushbutton is depressed, it needs to cause the corresponding servo to rotate slowly in one direction as long as it is being pushed, and when released, the single servo will stop. What I am getting from the code I have is that whenever I push a button, the corresponding servo will rotate, but the other two will either twitch or rotate as well. I looked this up and what ive gotten is that theres a delay from the arduino having to read multiple inputs at once, and the servos are updating too fast without response from the arduino, and thus twitch or spin. Please help me out. Its my first code Ive ever written for the arduino, and its for a class project thats due soon.
Quote
#include <SoftwareSerial.h>
#include <Servo.h>
Servo servo;
Servo servo2;
Servo servo3;
int switchone = 2;
int switchtwo = 3;
int switchthree = 4;
int val;
int val2;
int val3;
void setup ()
pinMode(switchone, INPUT);
pinMode(switchtwo, INPUT);
pinMode(switchthree, INPUT);
servo.attach(5);
servo2.attach(6);
servo3.attach(7);
void loop (){
  val = digitalRead(switchone); //Value from switch one
  val2 = digitalRead(switchtwo); //Value from switch two
  val3 = digitalRead(switchthree); //Value from switch three
  if (val == HIGH) //If switch one is on, then run servo
    servo.attach(5);
    servo.write(90);
  else //If switch one is off, then turn off servo
    servo.detach();
  if (val2 == HIGH) //If swtich two is on, then run servo2
    servo2.attach(6);
    servo2.write(90);
  else //If switch two is off, the turn off servo2
    servo2.detach();
  if (val3 == HIGH) //If switch three is on, run servo3
  servo3.attach(7);
  servo3.write(90);
  else //If switch three is off, turn off servo3
   servo3.detach();
« Last Edit: November 27, 2011, 04:41:23 pm by abrodech » Logged
0
Offline Offline
Tesla Member
Arduino rocks
View Profile
I've had continous rotation servos connected to my arduino that priodically twitched while resting at the neutral value (but not detached). If you don't have your buttons kept low with a resistor, you may be getting some floating high inputs. The code below puts the button between the pin and ground such that button press pulls the pin low. Otherwise the pin is kept high internally in the arduino.
Code:
//zoomkat servo button test 7-30-2011
#include <Servo.h>
int button1 = 4; //button pin, connect to ground to move servo
int press1 = 0;
Servo servo1;
  pinMode(button1, INPUT);
  servo1.attach(7);
  digitalWrite(4, HIGH); //enable pullups to make pin high
  press1 = digitalRead(button1);
  if (press1 == LOW)
    servo1.write(160);
  else {
    servo1.write(20);
Logged
Why I like my 2005 rio yellow Honda S2000 with the top down, and more!
GOOGLE ADVANCED FORUM SEARCH BELOW!
Go to:  http://www.google.com/advanced_search?hl=en
put in key search words,
use site or domain:  http://arduino.cc/forum
or in a google search box put key words site:http://arduino.cc/forum
Pages: [1]   Go Up
Print
Jump to:
