Loading...
Pages: 1 ... 26 27 [28] 29 30 ... 39   Go Down
Author Topic: ATmega1284P: End to End using 1.0 IDE  (Read 29131 times)
Offline Offline
Jr. Member
View Profile
I have tried it with my PCB / smd 1284p and also with my DIP package on a breadboard. They both have the same issue
Logged
Global Moderator
Boston area, metrowest
Offline Offline
Brattain Member
Available for Design & Build services
View Profile
WWW
So that's like physical pin5 on the chip? The SPI default SS pin?
You don't have SPI enabled after you set the pin as an input, do you?
That would set it back to an Output as far as I know, and odd things could happen.
Logged
Designing & building electrical circuits for over 25 years. Check out the ATMega1284P based Bobuino and other '328P & '1284P creations & offerings at  www.crossroadsfencing.com/BobuinoRev17
Offline Offline
Jr. Member
View Profile
Hmm... My setup is running an led strip which the library to control it uses SPI, pins SCK and MOSI...
Logged
Offline Offline
Jr. Member
View Profile
but yes physical pin 5
Logged
Offline Offline
Jr. Member
View Profile
hmm... Ok so it still doesn't work even if I set is as OUTPUT.
If I just dont set it to anything it does work...lol
Logged
Global Moderator
Offline Offline
Brattain Member
View Profile
WWW
Read the data sheet - SS pin has to be set to Output for SPI operations when the device is the Master.
Set it to OUTPUT before SPI.begin() is called.
I've never seen problems when using it that way.
Logged
Offline Offline
Jr. Member
View Profile
Works!!!  smiley-lol Seriously CrossRoads if I could give you a hug I would! lol You have successfully helped me with every issue I have had during this crazy microcontroller roller coaster. For being totally kick ass, when this hoop is done I am giving you one, and I don't care if you hulahoop or not, you are going to have the world sickest most artistic well thought out just awesomenest lol hulahoop in the world.
Thanks for all the help man. And super fast response, I wanted to get this thing ready for a show tonight.
Logged
Offline Offline
Jr. Member
View Profile
https://www.facebook.com/pages/LED-Artistry/389983651023734 You are gonna rock one of these! lol
Logged
Global Moderator
Offline Offline
Brattain Member
View Profile
WWW
I look forward to it!
As for timeliness, sometimes  you get lucky - I just happened to have a couple minutes between meetings and was poking around ...
Logged
Offline Offline
Jr. Member
View Profile
I very much appreciate it, that would have taken me forever to figure out
Logged
Global Moderator
Offline Offline
Brattain Member
View Profile
WWW
You'll have to send me the camera settings you used for pictures too...
Logged
Offline Offline
Jr. Member
View Profile
I used an older SLR cannon, and adjusted the shutter speed to 1.25... I am not sure as to what the 1.25 means.
Logged
Offline Offline
Jr. Member
View Profile
For anyone who ran into this issue, using SPI but need to use SS as input for a button.
You don't have to set is as input, before or after SPI();
Set if LOW before reading: Then set it back HIGH after you read the button state.
  digitalWrite(4, LOW);
  PushTwoR = digitalRead(4); // smiley-wink
  digitalWrite(4, HIGH);
Logged
0
Offline Offline
Edison Member
Arduino rocks
View Profile
WWW
Madhu,
Quote
I am trying to use the Arduino 1.0 IDE's SoftwareSerial library with an ATMEGA1284P; on physical pins 24 and 25 (pins 18 and 19 in pins_arduino.h for the standard variant) and I see that I cannot receive on pin 24(18). However, I can transmit successfully on pin 25(19).
After research, I now understand that I need to use pins that support 'change interrupts' - which pins on the 1284P support that?
Pin 24 and 25 support change interrupts, according to datasheet.
Did you fix the problem with SoftwareSerial on 1284?
Logged
Sweden
Offline Offline
Full Member
View Profile
Got a question: Is the ATmega1284P bootloader (Mighty 16Mhz optiboot) compatible with the Arduino USB Serial Light adapter?
Logged
Pages: 1 ... 26 27 [28] 29 30 ... 39   Go Up
Print
Jump to:
