Loading...
Pages: 1 2 3 [4] 5 6 ... 39   Go Down
Author Topic: ATmega1284P: End to End using 1.0 IDE  (Read 29002 times)
Leighton Buzzard, UK
Offline Offline
Edison Member
View Profile
I used size .024
may be a tad small for some?
Logged
there are only 10 types of people
them that understands binary
and them that doesn't
Smithfield, Rhode Island
Offline Offline
God Member
View Profile
I used size .024
That's the smallest size I ever use. It's pretty tiny.
Logged
Seattle, WA
Offline Offline
God Member
View Profile
WWW
This is a really nice board.  The FTDI part you found is great because it's cheap and has extra fun pins too.  Problem is, it's not compatible with the usual FTDI cable.  The cable and the Sparkfun 'basic' boards all use a common pinout, like the Sparkfun Arduino Pro and friends.  I would say more people are going to have the Sparkfun units (adafruit sells them too).  So I'd recommend a simple 6-pin header using the FTDI cable pinout.  https://www.adafruit.com/products/284
Definitely needs the pin labels, good to see those come in.
How about mounting holes on the corners now that adding up labels created more white space?
Logged
Global Moderator
Boston area, metrowest
Offline Offline
Brattain Member
Available for Design & Build services
View Profile
WWW
"Problem is, it's not compatible with the usual FTDI cable."
It's not meant to be - this part will plug in instead. Then a standard USB cable can plug in.
And if your application doesn't need permanent connectivity, don't install it.
I suppose I could put holes in parallel to plug a FTDI-Basic onto also for another option.
« Last Edit: January 16, 2012, 07:45:41 pm by CrossRoads » Logged
Designing & building electrical circuits for over 25 years. Check out the ATMega1284P based Bobuino and other '328P & '1284P creations & offerings at  www.crossroadsfencing.com/BobuinoRev17
Seattle, WA
Offline Offline
God Member
View Profile
WWW
Nono, what I am saying is that many of us have an FTDI cable, or other compatible product, around.  If there were headers for connecting that then we wouldn't NEED to buy this additional $10 part.
Logged
Global Moderator
Offline Offline
Brattain Member
View Profile
WWW
I think we are in agreement then - a 2nd row of holes compatible with the existing cables. Plenty of room for it.
Going to make the 100nF caps and the resistors 3/10s wide instead of 2/10s wide.
Logged
Global Moderator
Offline Offline
Brattain Member
View Profile
WWW
Okay, I am calling it done pending any review comments - just waiting on FTDI module delivery to confirm fit (has already left Mouser).
Also added  FTDI-Basic/FTDI Cable holes if someone prefers to use one of those for downloading sketches & then removing it.
Added extra labelling also to make it easier to find "the good pins", those with the extra features.
Think all parts sizes selected should be pretty easy to hand solder without hot air & reflow techniques.
Gotta go find a protoboard I have somewhere & confirm the headers are correctly placed. I copied the positions from the Duemilanove file and made everything else fit around them so shields should fit. Also added the new SCL/SDA and power header pins.
Files here if anyone cares to download & review.
http://www.crossroadsfencing.com/BobuinoRev17/atmega1284_DIP_thruhole_RCs.sch
http://www.crossroadsfencing.com/BobuinoRev17/atmega1284_DIP_thruhole_RCs.brd
« Last Edit: January 17, 2012, 02:00:00 am by CrossRoads » Logged
Offline Offline
Newbie
View Profile
WWW
I'm not sure the ICSP header is in the correct place to work with the Ethernet/SD card.
Logged
Global Moderator
Offline Offline
Brattain Member
View Profile
WWW
Well, I took the position numbers from the duemilanove and put them into this card. The whole groupw was then selected & moved so doing a one to one comparison  requires a little math now.
I think it may look funny due to the big chip being there and the analog header being 2 pins longer.
I am pretty sure the end pin of the D0, the end analog pin (3rd pin now) and the inner row of the ICSP pins line up, so its just a question of spacing between the headers.  I am looking for a prototype shield I have that I can lay over a printout to confirm.
Hmm, that's not what I have now is it - rats, something got moved unintentionally.  Looks like the reset button ended up where the ICSP header was supposed to be.
Back to the drawing board!
Logged
Ontario, Canada
Offline Offline
Jr. Member
Love OpenSource...
View Profile
WWW
Here are some pictures of the new board that arrived in the mail today....
I have a few details on my *uino-1284p page. The source files are on Github. Now I am waiting for some parts in the mail to see if this puppy will work.
« Last Edit: January 17, 2012, 08:46:06 pm by adilinden » Logged
Global Moderator
Offline Offline
Brattain Member
View Profile
WWW
Looking good.
Logged
Ontario, Canada
Offline Offline
Jr. Member
Love OpenSource...
View Profile
WWW
Had those made by iTead. Interesting that the box from iTead is identical to the box from Seeed. But the little flyer that came with it is different. About 2 weeks from paying and emailing files to receiving the boards. I'd say that turnaround time is outstanding.
Logged
Global Moderator
Offline Offline
Brattain Member
View Profile
WWW
Not bad. US Customs must be a little slower, mine have taken a few days longer.
They accepted the Leonardino design on the 9th, boards shipped the 13th, waiting on delivery.
Status is it left Hong Kong on 17th, so its moving along.
Logged
nr Bundaberg, Australia
Offline Offline
Tesla Member
Scattered showers my arse -- Noah, 2348BC.
View Profile
WWW
I'm sure that ISP header is in the wrong place, the inner 3 pins should be in line with the end of the standard headers (ie the standard A5 and D0 although your pinout on the A header seems to be different).
______
Rob
Logged
Rob Gray aka the GRAYnomad http://www.robgray.com
Global Moderator
Offline Offline
Brattain Member
View Profile
WWW
I need to move ICSP for sure.
I think the other I can just rename and fix with pins_arduino.c change.
Logged
Pages: 1 2 3 [4] 5 6 ... 39   Go Up
Print
Jump to:
