Loading...
Pages: [1]   Go Down
Author Topic: 2560 at 3.3v  (Read 290 times)
Ipswich UK
Offline Offline
Newbie
View Profile
I am putting together a couple of projects with my own board design, I originally intended to use a atmega328 however I have decided instead to go with the atmega2560, the 328 actually gives me all the digital and analogue pins that I need however I need at least 2 proper uart ports for my projects so although the majority of the 2560 IO pins will be unused it will give me the most flexibility for my serial devices.
I need to run my projects at 3.3v and so therefore 8Mhz, I understand this will be fine for the 2560.  I am currently designing my board and will include an external 8Mhz resonator and programming header.  Is there anything I need to consider for burning the bootloader onto a blank chip when it is on my completed board? in the past I have found with the 328 DIP chip that I have had to hook up a 16Mhz clock to be able to burn the 8Mhz bootloader, obviously my board will be smd so it will not be possible to swap resonators just to program the chip.
I also need some guidance on how to prepare a 8Mhz bootloader and board config for the 2560 at 8Mhz, to be honest I don't fully understand the ins and outs of bootloader and programmer config yet, I am still trying to find a good all-round guide.
Will I be able to use an arduino as ISP for burning the bootloader to the 2560?
Logged
Pages: [1]   Go Up
Print
Jump to:
