Topic: (Port forwarding done) now ipcam and enc28j60 (Read 10783 times) previous topic - next topic
Hanrun
Nov 30, 2011, 12:02 am Last Edit: Dec 02, 2011, 04:25 am by Hanrun Reason: 1
Hi, i'm new in arduino's WORLD. I create a web switch with a enc28j60 but i don't know the reason when i try to control the board over the internet, it doesn't work. I only see the ''web page'' and can't control  any led from the 3 i set. In lan it works perfectly !
i open the port 85
check this sketch :
#include "etherShield.h"
// please modify the following two lines. mac and ip have to be unique
// in your local area network. You can not have the same numbers in
// two devices:
static uint8_t mymac[6] = {0x54,0x55,0x58,0x10,0x00,0x24};
static uint8_t myip[4] = {192,168,1,15};
static char baseurl[]="http://192.168.1.15/";
static uint16_t mywwwport =85; // listen port for tcp/www (max range 1-254)
#define BUFFER_SIZE 1500
static uint8_t buf[BUFFER_SIZE+1];
#define STR_BUFFER_SIZE 200
static char strbuf[STR_BUFFER_SIZE+1];
EtherShield es=EtherShield();
// prepare the webpage by writing the data to the tcp send buffer
uint16_t print_webpage(uint8_t *buf, byte on_off1, byte on_off2, byte on_off3);
int8_t analyse_cmd(char *str);
// LED cathode connects the Pin4, anode to 5V through 1K resistor
#define LED_PIN4  4
#define LED_PIN5  5
#define LED_PIN6  6
    uint16_t plen, dat_p;
  int8_t cmd;
  byte on_off1 = 0;
  byte on_off2 = 0;
  byte on_off3 = 0;
void setup(){
   /*initialize enc28j60*/
es.ES_enc28j60Init(mymac);
   es.ES_enc28j60clkout(2); // change clkout from 6.25MHz to 12.5MHz
   delay(10);
/* Magjack leds configuration, see enc28j60 datasheet, page 11 */
// LEDA=greed LEDB=yellow
// 0x880 is PHLCON LEDB=on, LEDA=on
// enc28j60PhyWrite(PHLCON,0b0000 1000 1000 00 00);
es.ES_enc28j60PhyWrite(PHLCON,0x880);
// 0x990 is PHLCON LEDB=off, LEDA=off
// enc28j60PhyWrite(PHLCON,0b0000 1001 1001 00 00);
es.ES_enc28j60PhyWrite(PHLCON,0x990);
  // 0x476 is PHLCON LEDA=links status, LEDB=receive/transmit
  // enc28j60PhyWrite(PHLCON,0b0000 0100 0111 01 10);
  es.ES_enc28j60PhyWrite(PHLCON,0x476);
delay(100);
  //init the ethernet/ip layer:
  es.ES_init_ip_arp_udp_tcp(mymac,myip,85);
Thx in advance
Hanrun
SRY In lan, when i open the port 85 it doesn't work. When I set default seting (port and ip) it works
toaspantenix
Did you assign a static IP and open the ports both through you wireless router and your ISP router? I forgot the ISP once, drove me insane.
Hanrun
there is no isp router but Modem. And yeah in my router the port is open. As i said, i can see the web page over the internet, but i can't do any action.
nickgammon
You haven't exactly posted the whole sketch, so it's all guesswork really. But I doubt this is right:
If you are generating forms, and that form is designed to respond to baseurl, then it will go back to the wrong address.
Also, what Arduino board are you using?
More info:
Hanrun
I use ENC28J60 the cheapest version of a real ethernet shield w5100 haha!
I try 192.168.1.15:85 but it do not work
The sketch I posted is only the ''ethernet'' part, the rest is to control ledpins. If you realy want i can show all my sketch.
nickgammon
Which Arduino are you using? Uno? Mega2560?
Yes, show the whole sketch.
More info:
jwatte
192.168.1.15 is not an address that is routable on the internet. Your router/firewall will have a different IP address when seen from the outside internet. Thus, any form that references that address simply won't work from the outside.
Luckily, HTTP already defaults the base URL to whatever you used to get to the form in the first place. Thus, you can try changing the baseurl to simply "/" and it might have some chance of working, if I read that sketch right.
That is -- assuming you can get to the page in the first place, then posting the form should work if you set the baseurl to "/" rather than a specific protocol and address.
Hanrun
static char baseurl[]="http://mydomain.no-ip.com/";
OR
static char baseurl[]="/";
Hanrun
Duemilanove
Hanrun
#10
Dec 01, 2011, 12:36 am Last Edit: Dec 01, 2011, 01:25 am by Hanrun Reason: 1
// two devices:
#define LED_PIN4  4
#define LED_PIN5  5
#define LED_PIN6  6
  int8_t cmd;
  byte on_off1 = 0;
  byte on_off2 = 0;
  byte on_off3 = 0;
void setup(){
   delay(10);
delay(100);
pinMode(LED_PIN4, OUTPUT);
digitalWrite(LED_PIN4, HIGH);  // switch off LED
        pinMode(LED_PIN5, OUTPUT);
digitalWrite(LED_PIN5, HIGH);  // switch off LED
        pinMode(LED_PIN6, OUTPUT);
digitalWrite(LED_PIN6, HIGH);  // switch off LED
void loop(){
  plen = es.ES_enc28j60PacketReceive(BUFFER_SIZE, buf);
/*plen will ne unequal to zero if there is a valid packet (without crc error) */
  if(plen!=0){
    // arp is broadcast if unknown but a host may also verify the mac address by sending it to a unicast address.
    if(es.ES_eth_type_is_arp_and_my_ip(buf,plen)){
      es.ES_make_arp_answer_from_request(buf);
      return;
    // check if ip packets are for us:
    if(es.ES_eth_type_is_ip_and_my_ip(buf,plen)==0){
      return;
    if(buf[IP_PROTO_P]==IP_PROTO_ICMP_V && buf[ICMP_TYPE_P]==ICMP_TYPE_ECHOREQUEST_V){
      es.ES_make_echo_reply_from_request(buf,plen);
      return;
    // tcp port www start, compare only the lower byte
    if (buf[IP_PROTO_P]==IP_PROTO_TCP_V&&buf[TCP_DST_PORT_H_P]==0&&buf[TCP_DST_PORT_L_P]==mywwwport){
      if (buf[TCP_FLAGS_P] & TCP_FLAGS_SYN_V){
         es.ES_make_tcp_synack_from_syn(buf); // make_tcp_synack_from_syn does already send the syn,ack
         return;
      if (buf[TCP_FLAGS_P] & TCP_FLAGS_ACK_V){
        es.ES_init_len_info(buf); // init some data structures
        dat_p=es.ES_get_tcp_data_pointer();
        if (dat_p==0){ // we can possibly have no data, just ack:
          if (buf[TCP_FLAGS_P] & TCP_FLAGS_FIN_V){
            es.ES_make_tcp_ack_from_any(buf);
          return;
        if (strncmp("GET ",(char *)&(buf[dat_p]),4)!=0){
          // head, post and other methods for possible status codes see:
            // http://www.w3.org/Protocols/rfc2616/rfc2616-sec10.html
            plen=es.ES_fill_tcp_data_p(buf,0,PSTR("HTTP/1.0 200 OK\r\nContent-Type: text/html\r\n\r\n<h1>200 OK</h1>"));
            goto SENDTCP;
if (strncmp("/ ",(char *)&(buf[dat_p+4]),2)==0){
                plen=print_webpage(buf, on_off1, on_off2, on_off3);
            goto SENDTCP;
        cmd=analyse_cmd((char *)&(buf[dat_p+5]));
        if (cmd==2){
                on_off1=1;
        digitalWrite(LED_PIN4, LOW);  // switch on LED
        else if (cmd==3){
                on_off1=0;
        else if (cmd==4){
                on_off2=1;
        digitalWrite(LED_PIN5, LOW);  // switch on LED
        else if (cmd==5){
                on_off2=0;
        else if (cmd==6){
                on_off3=1;
        digitalWrite(LED_PIN6, LOW);  // switch on LED
        else if (cmd==7){
                on_off3=0;
Hanrun
#11
Dec 01, 2011, 12:37 am Last Edit: Dec 01, 2011, 01:25 am by Hanrun Reason: 1
Next:
SENDTCP:  es.ES_make_tcp_ack_from_any(buf); // send ack for http get
           es.ES_make_tcp_ack_with_data(buf,plen); // send data
// The returned value is stored in the global var strbuf
uint8_t find_key_val(char *str,char *key)
        uint8_t found=0;
        uint8_t i=0;
        char *kp;
        kp=key;
        while(*str &&  *str!=' ' && found==0){
                if (*str == *kp){
                        kp++;
                        if (*kp == '\0'){
                                str++;
                                kp=key;
                                if (*str == '='){
                                        found=1;
                }else{
                        kp=key;
                str++;
        if (found==1){
                // copy the value to a buffer and terminate it with '\0'
                while(*str &&  *str!=' ' && *str!='&' && i<STR_BUFFER_SIZE){
                        strbuf[i]=*str;
                        i++;
                        str++;
                strbuf[i]='\0';
        return(found);
        int8_t r=-1;
        if (find_key_val(str,"cmd")){
                if (*strbuf < 0x3a && *strbuf > 0x2f){
                        // is a ASCII number, return it
                        r=(*strbuf-0x30);
        return r;
       int i=0;
        uint16_t plen;
        plen=es.ES_fill_tcp_data_p(buf,0,PSTR("HTTP/1.0 200 OK\r\nContent-Type: text/html\r\n\r\n"));
    plen=es.ES_fill_tcp_data_p(buf,plen,PSTR("<left>Arduino web server test</LEFT> "));
        plen=es.ES_fill_tcp_data_p(buf,plen,PSTR("<body bgcolor=\"#000000\"> "));
        plen=es.ES_fill_tcp_data_p(buf,plen,PSTR("<font color=\"#FFFFFF\"><FONT FACE=\"arial\"><RIGHT><I><FONT SIZE=1>BTCAD.<U> V1.0 beta</U></h1></FONT></FONT></I> </RIGHT> "));
        plen=es.ES_fill_tcp_data_p(buf,plen,PSTR("<FONT SIZE=3> <font color=\"#00FF00\"></h1><a href=\"http://192.168.1.1\">192.168.1.1<a></FONT></FONT>"));
        plen=es.ES_fill_tcp_data_p(buf,plen,PSTR("<hr><br><form METHOD=get action=\""));
        plen=es.ES_fill_tcp_data(buf,plen,baseurl);
        plen=es.ES_fill_tcp_data_p(buf,plen,PSTR("\">"));
        plen=es.ES_fill_tcp_data_p(buf,plen,PSTR("<h2><font color=\"#FFFFFF\"> selection  </h2> "));
plen=es.ES_fill_tcp_data_p(buf,plen,PSTR("<h1><font color=\"#FFFFFF\"> "));
            if(on_off1)
        plen=es.ES_fill_tcp_data_p(buf,plen,PSTR("<img src=\"http://i915.photobucket.com/albums/ac357/mistermpss/test2on.gif\" >"));
        plen=es.ES_fill_tcp_data_p(buf,plen,PSTR("<img src=\"http://i915.photobucket.com/albums/ac357/mistermpss/test2off-1.gif\" >"));
        if(on_off1){
        plen=es.ES_fill_tcp_data_p(buf,plen,PSTR("<input type=hidden name=cmd value=3>"));
        plen=es.ES_fill_tcp_data_p(buf,plen,PSTR("<input type=submit value=\" #1 ON \"></form>"));
        else {
        plen=es.ES_fill_tcp_data_p(buf,plen,PSTR("<input type=hidden name=cmd value=2>"));
        plen=es.ES_fill_tcp_data_p(buf,plen,PSTR("<input type=submit value=\" #1 OFF\"></form>"));
        plen=es.ES_fill_tcp_data_p(buf,plen,PSTR("<br><form METHOD=get action=\""));
            if(on_off2)
        if(on_off2){
        plen=es.ES_fill_tcp_data_p(buf,plen,PSTR("<input type=hidden name=cmd value=5>"));
        plen=es.ES_fill_tcp_data_p(buf,plen,PSTR("<input type=submit value=\" #2 ON\"></form>"));
        else {
        plen=es.ES_fill_tcp_data_p(buf,plen,PSTR("<input type=hidden name=cmd value=4>"));
        plen=es.ES_fill_tcp_data_p(buf,plen,PSTR("<input type=submit value=\" #2 OFF\"></form>"));
                if(on_off3)
        if(on_off3){
        plen=es.ES_fill_tcp_data_p(buf,plen,PSTR("<input type=hidden name=cmd value=7>"));
        plen=es.ES_fill_tcp_data_p(buf,plen,PSTR("<input type=submit value=\" #3 ON\"></form>"));
        else  {
        plen=es.ES_fill_tcp_data_p(buf,plen,PSTR("<input type=hidden name=cmd value=6>"));
        plen=es.ES_fill_tcp_data_p(buf,plen,PSTR("<input type=submit value=\" #3 OFF \"></form>"));
                plen=es.ES_fill_tcp_data_p(buf,plen,PSTR("  </font></h1><br> ") );
        plen=es.ES_fill_tcp_data_p(buf,plen,PSTR("</CENTER><hr><hr><FONT FACE=\"arial\"><FONT SIZE=1>link:</font><FONT SIZE=5> <p> Testing <a href=\"http://www.google.com\">www.google.com<a></font></FONT>"));
        return(plen);
Hanrun
#12
Dec 01, 2011, 12:45 am Last Edit: Dec 01, 2011, 12:48 am by Hanrun Reason: 1
okay take a look on :
// two devices:
with this change, i can control trough the lan, not over internet.
Hanrun
I creat a DNS with my dhcp IP   ex:
71.112.345.3 is now Mydomain.no-ip.com
I opened the port 85 both udp & tcp
I can acces my router from anywhere with : Mydomain.no-ip.com
but nothing work with  http://mydomain.no-ip.com:85/
nickgammon
In "code" tags, not "quote" tags thanks. It makes it (almost) impossible to read. Edit those posts and change [ quote ] to [ code ] (leaving out the spaces).
More info:
