Loading...
Pages: 1 [2] 3 4 5   Go Down
Author Topic: Increase Stepper Motor Speed  (Read 3672 times)
florida
Offline Offline
Newbie
View Profile
yeah i looked at that im not clever enough to swap out 8,9,10,11 pins with steppin and directionpin with out it saying stepper not ....whatever
Logged
Manchester (England England)
Offline Offline
Brattain Member
Solder is electric glue
View Profile
WWW
So post the code as you have changed it, along with the error message and some one will tell you where you have gone wrong.
When posting code, select it and then hit the # icon in the reply box before posting.
Logged
florida
Offline Offline
Newbie
View Profile
ok thanks alot
Logged
florida
Offline Offline
Newbie
View Profile
Code:
#include <Stepper.h>
// change this to the number of steps on your motor
#define STEPS 200
#define directionPin 22
#define stepPin 24
// create an instance of the stepper class, specifying
// the number of steps of the motor and the pins it's
// attached to
// the previous reading from the analog input
int previous = 0;
  // set the speed of the motor to 30 RPMs
  stepper.setSpeed(30);
  // get the sensor value
  int val = analogRead(0);
  // move a number of steps equal to the change in the
  // sensor reading
  stepper.step(val - previous);
  // remember the previous value of the sensor
  previous = val;
there it is I told you I am simple the error code it gives me is stepper was not declared in this scope motorknob.cpp: in function void loop
etc. it gets very angry at me
Logged
Offline Offline
Brattain Member
View Profile
WWW
You need this line:-
Code:
Stepper stepper(STEPS, 8, 9, 10, 11);
In order to tell the software what pins to use. Change the numbers to match the pins your hardware is using.
Without this line the software doesn't know what the word 'stepper' means and so it tells you it doesn't know with the error message "not declared in scope" which means "WTF no on told be about this word stepper, I don't know what to do with it.
Logged
florida
Offline Offline
Newbie
View Profile
ok now we're getting somewhere i have a pololu a4988 with the direction pin and step pin when i assigned those 2 pins numbers and gave it a go the motor wont move. i have everything set up right because it works with the code that goes forward then backward
Logged
Offline Offline
Brattain Member
View Profile
WWW
No it won't. This is because that code uses the stepping motor library and this is designed to produce the on / off pattern for powering the coils.
The code is totally unsuitable for the hardware you have.
Try this code, I have just written it for you so I haven't tested it but it compiles:-
Code:
#define dirPin 10
#define stepPin 11
int previous = 0;
int val =0;
int dir = 0; // direction of movement
int steps = 0; // number of steps to take
  pinMode(stepPin, OUTPUT);
 digitalWrite(stepPin, LOW);
 pinMode(dirPin, OUTPUT);
  // sensor reading
   steps = (val - previous);
  if(steps > 0){
    dir = 0;
  else {
    dir = 1;
    steps = -steps;
  digitalWrite(dirPin, dir); // set up the direction
  for(int i = 0; i< steps; i++){
    digitalWrite(stepPin, HIGH); // pulse the step pin
  previous = val;
Be sure to change the first two lines to match what you have.
Logged
Berks, UK
Offline Offline
Full Member
View Profile
Code:
LOL, spoken like a true Brit.
Logged
florida
Offline Offline
Newbie
View Profile
first thank you grumpy mike. good karma for you smiley when i try the code and move the pot the motor does nothing. sorry it took so long to get back i have an 11 month old and work. my projects always get put on the back burner
Logged
Offline Offline
Brattain Member
View Profile
WWW
Try adding a
Code:
delay(100);
after the
Code:
Logged
Pittsburgh, PA, USA
Offline Offline
Faraday Member
I only know some basic electricity....
View Profile
Hehe, hehe! He said
delay
hehe, hehe, hehehehehe.
j/k!
Logged
Examples can be found at Learning in the Main Site and at the Playground
Offline Offline
Brattain Member
View Profile
WWW
Well in a post where I said WTF I thought WTF I will say delay.
Logged
Pittsburgh, PA, USA
Offline Offline
Faraday Member
View Profile
Just the thought of going through how not to use delay has me agreeing, show him something quicker than it would take to explain why not.
Logged
florida
Offline Offline
Newbie
View Profile
do i need to turn on the a0 pin for the pot to work thanks again for being patient and helpful
Logged
Offline Offline
Brattain Member
View Profile
WWW
Quote
No.
Logged
Pages: 1 [2] 3 4 5   Go Up
Print
Jump to:
