Loading...
Pages: 1 2 [3] 4 5   Go Down
Author Topic: Increase Stepper Motor Speed  (Read 3484 times)
Pittsburgh, PA, USA
Offline Offline
Faraday Member
I only know some basic electricity....
View Profile
Is the pot output connected to A0, maybe through a 1K resistor? And in that connect, a 10k or so resistor to ground as well? If you don't have that resistor to ground then you will always get saturated reads and wonder what's wrong.
Then analog read A0 and you have your turn pot sensed.
Logged
Examples can be found at Learning in the Main Site and at the Playground
florida
Offline Offline
Newbie
View Profile
the delay got mad and said it expected a ; . maybe its the pot i have one wire to a ground middle wire to the a0 pin one wire to a 5 volt spot the green light lights up when i move it one way
Logged
Manchester (England England)
Offline Offline
Brattain Member
Solder is electric glue
View Profile
WWW
All statements in C need to end in a semicolon ;
What is the green light? Is it the direction?
Logged
Pittsburgh, PA, USA
Offline Offline
Faraday Member
View Profile
You want to attach to the middle wire, another wire with 10+k resistor to ground.
You want some resistors in there to limit current flow. One pin can handle 40 mA but you don't want to push the pins like that, 20 mA per pin is a nice 'limit' but you don't need that much current.
I have input pins being fed 0 - 5V through 2.2k resistors, 2.27 mA, works fine. Those same input pins connect to ground through 22k resistors, that's where the 2.27 mA goes. Maybe I should try 4.7k instead of 2.2k to use 1.06 mA.
Logged
florida
Offline Offline
Newbie
View Profile
ok i am back on this project life and frustration got in the way. now i am ready to try again. i also need to start from the point of what resistors do i need to install for the pot to work. i would like to have the pot control a stepper motor to move 200 steps forward and 200 backward. if pot stops so does the motor. thanks for helping everyone
Logged
Offline Offline
Brattain Member
View Profile
WWW
OK so, as it has been a time and there has been several software versions used, can you post a schematic of what you have wired up along with the code you are trying to use.
Logged
florida
Offline Offline
Newbie
View Profile
been busy thanks for patients in advance i am using the simple program from before a polou a4988 driver and a 3 prong pot from radio shack  i just bought a volt meter my power supply has an output of 24v and 6.5a i have the driver in the easiest setting with 1a and 2a connected and 1b and 2b connected no microstepping.i just need the motor to follow what the pot does 200 steps one way 200 steps the other
Logged
Offline Offline
Brattain Member
View Profile
WWW
Logged
florida
Offline Offline
Newbie
View Profile
i attached a quick pencil sketch if it comes out to small i will make a bigger one. i hope someone can help i feel it is so simple to make this work but i just dont get it
Logged
florida
Offline Offline
Newbie
View Profile
maybe we can try this code again
// change this to the number of steps on your motor
#define dirPin 10
#define stepPin 11
// the previous reading from the analog input
int previous = 0;
int val =0;
int dir = 0; // direction of movement
int steps = 0; // number of steps to take
  pinMode(stepPin, OUTPUT);
 digitalWrite(stepPin, LOW);
 pinMode(dirPin, OUTPUT);
  // get the sensor value
   val = analogRead(0);
  // move a number of steps equal to the change in the
  // sensor reading
   steps = (val - previous);
  if(steps > 0){
    dir = 0;
  else {
    dir = 1;
    steps = -steps;
  digitalWrite(dirPin, dir); // set up the direction
  for(int i = 0; i< steps; i++){
    digitalWrite(stepPin, HIGH); // pulse the step pin
  // remember the previous value of the sensor
  previous = val;
Logged
Southern California
Offline Offline
Sr. Member
I like blinky lights
View Profile
WWW
Between these two lines:
Code:
add the delay:
Code:
delay(100);
You will probably be able to use lower #s than 100...
Logged
http://en.wiktionary.org/wiki/magagna <-- My last name.  Pretty apt.
Offline Offline
Brattain Member
View Profile
WWW
Quote
But it is not a schematic is it, it does not show the circuit you are using.
Logged
florida
Offline Offline
Newbie
View Profile
im not sure what you are talking about do you want a picture of the way i have it set up?
Logged
Offline Offline
Brattain Member
View Profile
WWW
Quote
No I want a schematic.
http://blog.makezine.com/archive/2011/01/reading-circuit-diagrams.html
Logged
florida
Offline Offline
Newbie
View Profile
is this right? and thanks for helping. it means alot
Logged
Pages: 1 2 [3] 4 5   Go Up
Print
Jump to:
