Topic: NEW Core for ATTINY 26 (Read 4740 times) previous topic - next topic
spycatcher2k
Nov 30, 2011, 03:35 pm Last Edit: Dec 09, 2011, 05:58 pm by spycatcher2k Reason: 1
Hi, I've got my hands on a quite a few ATTiny26(l) chips. Anyone got the boards.txt settings and core files for this? Any help would be appreciated.
Thanks all.
Drew
http://www.uk-pcb.co.uk - UK Based PCB Fab & Assembly Company
Design & Assembly work undertaken - Arduino repairs & testing - PM for details. Arduino & C# PC programming.
pwillard
I have some of these as well...   it would be nice to know this is a possible addition.
spycatcher2k
Hi - Managed to find this : http://www.avr-developers.com/corefiles/index.html.
Hope this helps others.
Coding Badly
For what it's worth, the 26 is on the list of processors the Tiny Core will eventually support.  Unfortunately, at this point in time, it's last on the list.
I'm curious ... how did each of you end up with 26s?
KirAsh4
The AVR Developers link that spycatcher2k posted has a core for the tiny26 ...
spycatcher2k
#Coding Badly - I got mine from our local college - They miss ordered them, got 40 of them for 10p each. At that price I was not going to turn them down.
#KirAsh4 - The core they have is so incomplete it is unusable on the 26s - I am using BASCOM at the moment to write firmware with, but I'd rather use the Arduino IDE.
I looked at modifying the tiny45_85 core, but don't know where to start, I have a VB programming background. A lot of 'C' is still beyond my knowledge.  If someone could give me some ideas on what to modify, I would be willing to try and modify a core to work.
KirAsh4
Ah. I've never actually tried that core. I've only used the tiny84v so far.
Coding Badly
Are they in a PDIP-20 package?
Quote
It's really a question of what features you want.  If all you want is basic digital functions than modifying any existing core is easy.  If you want PWM, time functions, analog-to-digital conversion, etcetera, it can become difficult.
spycatcher2k
#Coding Badly - For the main, Digital I/O & Timer Would be sufficient for most projects I have in mind - PWM I can pseudo emulate or use Digital Pots. I THINK I can work out the pin mapping -> port names from the other Core files I have, A Timer for delay and delayMicroseconds would be a BIG advantage, but I don't even know where to start!!
Coding Badly
Start with an entry in boards.txt.  If you need help, let me know.
spycatcher2k
Done - I managed that one quite easily :
Code: [Select]
arduino_tiny26.name=Arduino-ATtiny26 @ 8Mhz exp
arduino_tiny26.upload.using=arduino:usbtinyisp
arduino_tiny26.upload.maximum_size=2048
arduino_tiny26.bootloader.low_fuses=0xdf
arduino_tiny26.bootloader.high_fuses=0xca
arduino_tiny26.bootloader.path=attiny26
arduino_tiny26.bootloader.file=attinyblank.hex
arduino_tiny26.bootloader.unlock_bits=0x3F
arduino_tiny26.bootloader.lock_bits=0x0F
arduino_tiny26.build.mcu=attiny26
arduino_tiny26.build.f_cpu=8000000L
arduino_tiny26.build.core=tiny26
When I try to verify code i get :
Code: [Select]
In file included from C:\Users\Drew\Documents\Arduino\hardware\attiny26\cores\tiny\wiring.c:31:
C:\Users\Drew\Documents\Arduino\hardware\attiny26\cores\tiny\/core_timers.h: In function 'Timer0_SetToPowerup':
C:\Users\Drew\Documents\Arduino\hardware\attiny26\cores\tiny\/core_timers.h:72: error: 'TCCR0B' undeclared (first use in this function)
C:\Users\Drew\Documents\Arduino\hardware\attiny26\cores\tiny\/core_timers.h:72: error: (Each undeclared identifier is reported only once
C:\Users\Drew\Documents\Arduino\hardware\attiny26\cores\tiny\/core_timers.h:72: error: for each function it appears in.)
C:\Users\Drew\Documents\Arduino\hardware\attiny26\cores\tiny\/core_timers.h:72: error: 'FOC0A' undeclared (first use in this function)
C:\Users\Drew\Documents\Arduino\hardware\attiny26\cores\tiny\/core_timers.h:72: error: 'FOC0B' undeclared (first use in this function)
C:\Users\Drew\Documents\Arduino\hardware\attiny26\cores\tiny\/core_timers.h:72: error: 'WGM02' undeclared (first use in this function)
C:\Users\Drew\Documents\Arduino\hardware\attiny26\cores\tiny\/core_timers.h:73: error: 'TCCR0A' undeclared (first use in this function)
C:\Users\Drew\Documents\Arduino\hardware\attiny26\cores\tiny\/core_timers.h:73: error: 'COM0A1' undeclared (first use in this function)
C:\Users\Drew\Documents\Arduino\hardware\attiny26\cores\tiny\/core_timers.h:73: error: 'COM0A0' undeclared (first use in this function)
C:\Users\Drew\Documents\Arduino\hardware\attiny26\cores\tiny\/core_timers.h:73: error: 'COM0B1' undeclared (first use in this function)
/snip
snip/
C:\Users\Drew\Documents\Arduino\hardware\attiny26\cores\tiny\/core_timers.h: In function 'Timer0_ClockSelect':
C:\Users\Drew\Documents\Arduino\hardware\attiny26\cores\tiny\/core_timers.h:120: error: 'TCCR0B' undeclared (first use in this function)
C:\Users\Drew\Documents\Arduino\hardware\attiny26\cores\tiny\/core_timers.h: In function 'Timer0_SetWaveformGenerationMode':
C:\Users\Drew\Documents\Arduino\hardware\attiny26\cores\tiny\/core_timers.h:138: error: 'TCCR0A' undeclared (first use in this function)
C:\Users\Drew\Documents\Arduino\hardware\attiny26\cores\tiny\/core_timers.h:138: error: 'WGM01' undeclared (first use in this function)
C:\Users\Drew\Documents\Arduino\hardware\attiny26\cores\tiny\/core_timers.h:138: error: 'WGM00' undeclared (first use in this function)
C:\Users\Drew\Documents\Arduino\hardware\attiny26\cores\tiny\/core_timers.h:139: error: 'TCCR0B' undeclared (first use in this function)
C:\Users\Drew\Documents\Arduino\hardware\attiny26\cores\tiny\/core_timers.h:139: error: 'WGM02' undeclared (first use in this function)
C:\Users\Drew\Documents\Arduino\hardware\attiny26\cores\tiny\/core_timers.h: In function 'Timer0_SetCompareOutputModeA':
C:\Users\Drew\Documents\Arduino\hardware\attiny26\cores\tiny\/core_timers.h:153: error: 'TCCR0A' undeclared (first use in this function)
C:\Users\Drew\Documents\Arduino\hardware\attiny26\cores\tiny\/core_timers.h:153: error: 'COM0A1' undeclared (first use in this function)
C:\Users\Drew\Documents\Arduino\hardware\attiny26\cores\tiny\/core_timers.h:153: error: 'COM0A0' undeclared (first use in this function)
C:\Users\Drew\Documents\Arduino\hardware\attiny26\cores\tiny\/core_timers.h: In function 'Timer0_SetCompareOutputModeB':
C:\Users\Drew\Documents\Arduino\hardware\attiny26\cores\tiny\/core_timers.h:158: error: 'TCCR0A' undeclared (first use in this function)
C:\Users\Drew\Documents\Arduino\hardware\attiny26\cores\tiny\/core_timers.h:158: error: 'COM0B1' undeclared (first use in this function)
C:\Users\Drew\Documents\Arduino\hardware\attiny26\cores\tiny\/core_timers.h:158: error: 'COM0B0' undeclared (first use in this function)
C:\Users\Drew\Documents\Arduino\hardware\attiny26\cores\tiny\/core_timers.h: In function 'Timer0_DisconnectOutputs':
C:\Users\Drew\Documents\Arduino\hardware\attiny26\cores\tiny\/core_timers.h:163: error: 'TCCR0A' undeclared (first use in this function)
C:\Users\Drew\Documents\Arduino\hardware\attiny26\cores\tiny\/core_timers.h:163: error: 'COM0A1' undeclared (first use in this function)
C:\Users\Drew\Documents\Arduino\hardware\attiny26\cores\tiny\/core_timers.h:163: error: 'COM0A0' undeclared (first use in this function)
C:\Users\Drew\Documents\Arduino\hardware\attiny26\cores\tiny\/core_timers.h:163: error: 'COM0B1' undeclared (first use in this function)
C:\Users\Drew\Documents\Arduino\hardware\attiny26\cores\tiny\/core_timers.h:163: error: 'COM0B0' undeclared (first use in this function)
C:\Users\Drew\Documents\Arduino\hardware\attiny26\cores\tiny\/core_timers.h: In function 'Timer0_SetOutputCompareMatchAndClear':
C:\Users\Drew\Documents\Arduino\hardware\attiny26\cores\tiny\/core_timers.h:174: error: 'OCR0A' undeclared (first use in this function)
C:\Users\Drew\Documents\Arduino\hardware\attiny26\cores\tiny\/core_timers.h: In function 'Timer0_SetOutputCompareMatchA':
C:\Users\Drew\Documents\Arduino\hardware\attiny26\cores\tiny\/core_timers.h:179: error: 'OCR0A' undeclared (first use in this function)
C:\Users\Drew\Documents\Arduino\hardware\attiny26\cores\tiny\/core_timers.h: In function 'Timer0_SetOutputCompareMatchB':
C:\Users\Drew\Documents\Arduino\hardware\attiny26\cores\tiny\/core_timers.h:184: error: 'OCR0B' undeclared (first use in this function)
C:\Users\Drew\Documents\Arduino\hardware\attiny26\cores\tiny\/core_timers.h: In function 'Timer0_EnableOutputCompareInterruptA':
C:\Users\Drew\Documents\Arduino\hardware\attiny26\cores\tiny\/core_timers.h:189: error: 'OCIE0A' undeclared (first use in this function)
C:\Users\Drew\Documents\Arduino\hardware\attiny26\cores\tiny\/core_timers.h: In function 'Timer1_SetToPowerup':
C:\Users\Drew\Documents\Arduino\hardware\attiny26\cores\tiny\/core_timers.h:221: error: 'ICNC1' undeclared (first use in this function)
C:\Users\Drew\Documents\Arduino\hardware\attiny26\cores\tiny\/core_timers.h:221: error: 'ICES1' undeclared (first use in this function)
C:\Users\Drew\Documents\Arduino\hardware\attiny26\cores\tiny\/core_timers.h:221: error: 'WGM13' undeclared (first use in this function)
C:\Users\Drew\Documents\Arduino\hardware\attiny26\cores\tiny\/core_timers.h:221: error: 'WGM12' undeclared (first use in this function)
C:\Users\Drew\Documents\Arduino\hardware\attiny26\cores\tiny\/core_timers.h:223: error: 'WGM11' undeclared (first use in this function)
C:\Users\Drew\Documents\Arduino\hardware\attiny26\cores\tiny\/core_timers.h:223: error: 'WGM10' undeclared (first use in this function)
C:\Users\Drew\Documents\Arduino\hardware\attiny26\cores\tiny\/core_timers.h:232: error: 'ICIE1' undeclared (first use in this function)
C:\Users\Drew\Documents\Arduino\hardware\attiny26\cores\tiny\/core_timers.h:234: error: 'ICF1' undeclared (first use in this function)
C:\Users\Drew\Documents\Arduino\hardware\attiny26\cores\tiny\/core_timers.h: In function 'Timer1_InterruptsOff':
C:\Users\Drew\Documents\Arduino\hardware\attiny26\cores\tiny\/core_timers.h:239: error: 'ICIE1' undeclared (first use in this function)
C:\Users\Drew\Documents\Arduino\hardware\attiny26\cores\tiny\/core_timers.h: In function 'Timer1_SetWaveformGenerationMode':
C:\Users\Drew\Documents\Arduino\hardware\attiny26\cores\tiny\/core_timers.h:298: error: 'WGM11' undeclared (first use in this function)
C:\Users\Drew\Documents\Arduino\hardware\attiny26\cores\tiny\/core_timers.h:298: error: 'WGM10' undeclared (first use in this function)
C:\Users\Drew\Documents\Arduino\hardware\attiny26\cores\tiny\/core_timers.h:299: error: 'WGM13' undeclared (first use in this function)
C:\Users\Drew\Documents\Arduino\hardware\attiny26\cores\tiny\/core_timers.h:299: error: 'WGM12' undeclared (first use in this function)
All to do with the timer(s) - I have the data sheet,if you can point me in the right direction, I'll TRY to modify the core.
spycatcher2k
I've found a core (sort of) - its called arduino-lite http://www.robopeak.net/blog/?p=185
I've #defined the analogWrite, digitalRead,digitalWrite & pinMode commands, and built up a core with it.
The core looks like it covers most things, Plus brings some extras as well e.g. PWM commands.
Hope you get some use out of this.
Coding Badly
Thanks.  I'll give it a look.
