Topic: how much energy to 19 servo from Indonesia (Read 2406 times) previous topic - next topic
ifhan_dp
I've finished assembling my hexapod robot uses 19 micro servo, how much power do I need to move the servo 19?
I need your help, I used the Arduino Mega 2650,
thanks for the help
robtillaart
Depends on the spec of the servo. Do you have a datasheet?
From my experience you need a separate power for the servo's
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
newbie15
hitung aja minimal arus tiap servo, kalikan jumlah servo. siapkan baterai dengan kemampuan segitu.
calculate current each servo then multiply with number of servo. prepare enough battery.
cr0sh
Pretty much this; though you want to calculate using the "stall current" of the servo, not the "no load" current. This will give you the "worst case" scenario you are likely to encounter (that is, all servos activated, attempting to move, and can't), and is best to target for this if you can. Otherwise, in the case where the battery for the worst case is not feasible for the robot, then figure out how many servos may be running and potentially stalled at -any one moment-, and use that to figure out the amp-hour needs for the battery (so you can figure your run-time); note that amp-hours is not the same as amps!
I will not respond to Arduino help PM's from random forum users; if you have such a question, start a new topic thread.
Wrend
#4
Apr 18, 2012, 12:16 pm Last Edit: Apr 18, 2012, 12:18 pm by Wrend Reason: 1
Just a basic related question: How much current usually runs through the signal lead for a standard servo, and is it typically safe to run these directly to the Arduino boards while having the power leads on a separate power bus that shares power in parallel with the Arduino, even in a case like this where many servos are used?
AWOL
Quote
Probably a few hundred microamps.
Quote
Quite safe.
"Pete, it's a fool looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
