Loading...
Pages: [1]   Go Down
Author Topic: Voltage regulator  (Read 393 times)
Offline Offline
Newbie
View Profile
Hey guys, so I basically need a voltage regulator that can output about 3.75V. I have a 3.3V and 5V voltage regulator http://www.sparkfun.com/products/526 and http://www.sparkfun.com/products/107 as well as a few capacitors. I am inputting voltage with a 7.4V LiPo battery so I basically need to step that down to around 3.75V although I assume 3.3V would be ok. I tried to solder something together using a L4940V5 and two capacitors like the attached image but it did not work very well because the voltage was not constant and I just need some help to make something that works well and is relatively simple. Essentially I need something like this: http://www.dimensionengineering.com/AnyVoltMicro.htm but I don't want to spend the $20 because I already have some components and I sort of need to make this by tomorrow.
Logged
Offline Offline
Newbie
View Profile
Sorry, I forgot to mention that a 100uF capacitor was added between the input terminal and ground and a 10uF capacitor was added between the output terminal and the Arduino.
Logged
Upstate NY
Offline Offline
Full Member
View Profile
LiPo batteries are not something to fool around with.  I have heard of many fires with them.  Buy the correct charger for the batteries you are using.  Read the part about charging in the link below.
http://en.wikipedia.org/wiki/Lithium-ion_polymer_battery
Logged
0
Online Online
Tesla Member
Arduino rocks
View Profile
Maybe a stop at Radio shack.
http://www.radioshack.com/product/index.jsp?productId=2062601
Logged
Why I like my 2005 rio yellow Honda S2000 with the top down, and more!
GOOGLE ADVANCED FORUM SEARCH BELOW!
Go to:  http://www.google.com/advanced_search?hl=en
put in key search words,
use site or domain:  http://arduino.cc/forum
or in a google search box put key words site:http://arduino.cc/forum
Austin, TX
Offline Offline
Faraday Member
CMiYC
View Profile
WWW
Generally regulators have a minimum load requirement before their output is stable.  You might try a load of a 10K resistor just to get some current flowing.  This combined with the relatively large capacitors you are using could be keeping the regulator from stabilizing its output.  (The datasheet only recommends 0.33uF on the input and 0.1uF on the output.)
Of course if your goal is 3.75V then zoomkat's suggestion is best of all.  Just go straight for an adjustable regulator.
Logged
www.cmiyc.com - A guide to being an Enginerd
Offline Offline
Newbie
View Profile
Thanks for the help, I ended up using an LM7805V http://www.sparkfun.com/datasheets/Components/LM7805.pdf without any capacitors and although it gave a higher voltage than I had originally wanted, the servos that I had hooked up to my pro mini were working fine, so I guess the simplest way in this case was the best.
Logged
Cumming, Ga
Offline Offline
Edison Member
Ultimate DIY: Arduino
View Profile
WWW
Simplest is not the best if it's wrong.
Quote
Nowhere in the datasheet does it say that capacitors are OPTIONAL.
Logged
Offline Offline
Newbie
View Profile
I 100% agree with you but after significant testing with the recommended .33uF and .1uF capacitors, I determined that I did not need them. I know that my solution might be somewhat unconventional but it works and thus I am happy, but yes it is "wrong".
Logged
nr Bundaberg, Australia
Offline Offline
Tesla Member
Scattered showers my arse -- Noah, 2348BC.
View Profile
WWW
If you want to make your own get an adjustable regulator, then you can have whatever voltage you like.
_____
Rob
Logged
Rob Gray aka the GRAYnomad http://www.robgray.com
Pages: [1]   Go Up
Print
Jump to:
