Topic: Reading a Script from Memory (Read 1 time) previous topic - next topic
thespaceman
Hello All,
I would like to use my arduino without my computer, something I have not done with the arduino as of yet.
This is my goal:
1) Power arduino + other devices
2) Arduino reads script from memory
3) Functions are performed
What hardware other than arduino do I need to accomplish this? And, how do I include this in my script?
johnwasser
This can be done with a battery or a power supply that runs off house current.
That's what a 'sketch' is: A script, in memory.
That's what a sketch is:  A script, in memory, that performs functions.
The afore-mentioned battery or power supply.
It's not clear what you mean by 'this'.  It will probably require programming.
Send Bitcoin tips to: 1G2qoGwMRXx8az71DVP1E81jShxtbSh5Hp
thespaceman
AWESOME!
What I meant by that last part is that if it was necessary to save the script on an external memory card, what would I need to include in my script in order to access the card. But I suppose that does not make any sense because I would have already had to of accessed the script in the first place. I just don't know much about the inner workings..
Really, Really helpful thank you.  :D
graynomad
The term "script" generally refers to ASCII human-readable text that is handled by an interpreter or compiler to produce code that the processor understands.
The "stuff" that's running on your Arduino is the result of this compiling, ie binary executable code not "script".
In that light you can store script on an SD card and have a program running on the Arduino that will read that script and interpret it, that's exactly what the Duinomite does and it allows you to use the board with no computer at all if you have a keyboard and a display.
______
Rob
Rob Gray aka the GRAYnomad www.robgray.com
thespaceman
I may not have been totally clear. I'd like to write a script from my computer, send it to the arduino, then with the use of an external power supply have the arduino perform the functions from the script.
It sounds like the duinomite is used to write scripts when a computer is not accessible, which is not my case.
Therefore I need nothing more than my cute little arduino..
Is this all correct?
graynomad
That's correct, once the program is downloaded the Arduino runs by itself.
______
Rob
johnwasser
I may not have been totally clear.  I'd like to write a script from my computer, send it to the Arduino, then with the use of an external power supply have the Arduino perform the functions from the script.
This sounds remarkably like writing a sketch, uploading it to the FLASH memory of the Arduino, and executing it whenever the Arduino is provided power.  That's what an Arduino does.  Any Arduino will do that.  Provide power and it runs the last sketch you uploaded.
