Loading...
Pages: [1]   Go Down
Author Topic: Type 2 numbers in serial mon. and it should give me the multiplication of both  (Read 340 times)
Offline Offline
Newbie
View Profile
Hi i have to make this programm for school but i dont get how to do it.my code looks like this
Code:
int a=0;
int b=0;
int erg=0;
void setup(){
  void loop(){
      if (Serial.available() > 0 && a==0){
      a=Serial.read()-48;
      Serial.print("1.number:");
      Serial.println(a,DEC);
  if(Serial.available() > 0 && a!=0);{
      b=Serial.read()-48;
      Serial.print("2.number:");
      Serial.println(b,DEC);
      if(a!=0 && b!=0){
        erg=a*b;
        Serial.print("answer:");
        Serial.println(erg,DEC);
but if i start the serial monitor now it only repeats 2.number:-49
Logged
Online Online
Sr. Member
View Profile
The semicolon in this line is wrong, it causes the if to be ignored and the block always executes.
Code:
Remove the ; and see if it works.
Logged
Offline Offline
Newbie
View Profile
now it works if i write the 2. number very fast after the first one but if i wait a little bit it says i have typed the 1. again
Code:
1.number:4
1.number:2
1.number:1
1.number:1
1.number:2
2.number:3
answer:6
1.number:5
1.number:2
1.number:2
Logged
Gosport, UK
Offline Offline
Faraday Member
View Profile
Strange. That doesn't happen to me. Did you change anything other than removing the ';' from the second if?
Logged
Netherlands
Offline Offline
Tesla Member
In theory there is no difference between theory and practice, however in practice there are many...
View Profile
Why do you check if a or b == 0 ?
That are valid integers so the challenge is to write code that could multiply those values too!
hint: use a non digit char e.g. space as separator
Logged
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
Pages: [1]   Go Up
Print
Jump to:
