Melbourne
« on: December 02, 2011, 11:45:18 pm » |
HI all,
Apologies if this has been covered elsewhere but couldn't seem to find something specific about consensus for migrating libraries to 1.0.
I have several libraries that I'm now looking to move to 1.0 given the official release recently. Given that there will probably be a lag on people upgrading (eg currently no binary upgrades in Debian or Ubuntu for auto-upgrading) I want to ensure I have a version that will work in Auduino 0023 (and similar) for at least a period of time.
My current thinking is to simply take my current code, move working versions across to a pre-1.0 folder or preface the files with that and then the default code will work in 1.0
EG:
Old lib was:
/header.h /code.cpp /examples/
This would change to:
/header.pre-1.0.h /header.h /code.pre-1.0.cpp /code.cpp /examples-pre-1.0/ /examples
This code can then be retired at a later stage in a few months etc.
Other options include branches in git but it's probably not wise to assume familiarity with git to understand what's going on.
Has there been much consensus on the right way to approach this for best compatibility and maintainability whilst the population upgrades.
Cheers ajfisher
Seattle, WA
« Reply #1 on: December 04, 2011, 09:31:53 pm » |
No, I wouldn't do that. You will have compile errors all over the place if you do that. The general approach seems to be to keep a single library that compiles under BOTH 0023 and 1.0. You'll see something like this at the top: #if ARDUINO < 100 #include <WProgram.h> #else #include <Arduino.h> #endif
And then in other places where the behaviour is different under 0023, you can have some more "#if ARDUINO < 100" The other reasonable approach would be to have two separate libraries, like this... ~/Source/Arduino/ SuperLib/ SuperLib.h SuperLib.cpp helpers.cpp SuperLib-1.0/ SuperLib-1.0.h SuperLib.cpp helpers.cpp You could conceivably make them branches in git, but that sure makes it harder for people to find if they're not used to git branches. You could prepare two separate downloads of course, SuperLib.zip and SuperLib-1.0.zip.
Melbourne
« Reply #2 on: December 04, 2011, 10:10:48 pm » |
Thanks for that.
I was sort of leaning towards the #if arduino < 100 option however the readability suffers a lot when you have code that is making use of the changes (eg .write instead of .print changes etc).
I think as there appears to be no real "correct" method that a combination of the below is probably the way to do it with the git branches + downloads being the way to deal with the most "messy" of cases where there's a lot of changes.
Cheers ajfisher
nr Bundaberg, Australia
« Reply #3 on: December 04, 2011, 11:25:29 pm » |
The #if option can produce unreadable code. I suggest if you have two many in a given function (ie > 2-3 probably) that you have two versions of the function and wrap them in an #if. That way each one is readable.
______ Rob
Seattle, WA
« Reply #4 on: December 05, 2011, 12:38:54 am » |
Yah. For my fork of RTClib I did this... #if ARDUINO < 100 #define SEND(x) send(x) #define RECEIVE(x) receive(x) #else #define SEND(x) write(static_cast<uint8_t>(x)) #define RECEIVE(x) read(x) #endif
Wire.SEND(0); Wire.SEND(bin2bcd(dt.second())); Wire.SEND(bin2bcd(dt.minute())); Wire.SEND(bin2bcd(dt.hour())); Wire.SEND(bin2bcd(0));
There are more elegant ways, but that did the job fast
North Queensland, Australia
« Reply #5 on: December 08, 2011, 04:52:02 am » |
or create a file 'WProgram.h' in the 1.0 core directory 'D:\PathToArduino\hardware\arduino\cores\arduino' and put inside it #include "Arduino.h"
and just for gcc compiler optimisation you could also put #ifndef HEADER_WPROGRAM #define HEADER_WPROGRAM #include "Arduino.h" #endif
this will fix most libraries.
Central MN, USA
« Reply #6 on: December 19, 2011, 05:28:32 pm » |
I am having some trouble with the lcd.write method. I had no problem with this method and now with 1.0
Error: " candidates are: virtual size_t LiquidCrystal::write(uint8_t)"
So what should I do? Change all write to print?
Seattle, WA USA
Seattle, WA USA
« Reply #7 on: December 19, 2011, 07:26:53 pm » |
So what should I do? Change all write to print? Altogether now: "Post the code that generates the error!"
Central MN, USA
« Reply #8 on: December 20, 2011, 12:51:30 am » |
So what should I do? Change all write to print? Altogether now: "Post the code that generates the error!" #include <LiquidCrystal.h>
LiquidCrystal LCD(2,3,4,5,6,7); void setup() { LCD.begin(16,2); LCD.write((uint8_t)'\0'); } void loop() {} The above code, when compiled in 1.0, only works with the type case (uint8_t) but works without it in 0022. I traced the library code to the following: arduino 0022 LiquidCrystal.cpp: inline void LiquidCrystal::write(uint8_t value) { send(value, HIGH); }
arduino 1.0 LiquidCrystal.cpp: inline size_t LiquidCrystal::write(uint8_t value) { send(value, HIGH); return 1; // assume sucess <- TYPO Anyone proofread the library??? } I'm stuck on why using write('\0') won't work in 1.0 The LiquidCrystal.h is fine but 0022 and 1.0 There must be a type cast in 0022 that casts all (const char) into uint8_t in some place that the 1.0 is missing, right?
Seattle, WA
« Reply #9 on: December 20, 2011, 01:37:36 am » |
The cause here is something SUPER subtle. It really should never have worked. The full text of the error message is listed below. Indeed, it tells the truth. It cannot tell if you mean to call 'write' with '0' as a uint8_t or 'write' with '0' as a null pointer. something.pde:66: error: call of overloaded ‘write(int)’ is ambiguous /opt/Arduino/master/libraries/LiquidCrystal/LiquidCrystal.h:82: note: candidates are: virtual size_t LiquidCrystal::write(uint8_t) /opt/Arduino/master/hardware/arduino/cores/arduino/Print.h:49: note: size_t Print::write(const char*)
This is going on my list of interview questions  The super subtle difference is that in 1.0, Print::write(const char *str) is no longer virtual. In 0022, it's virtual. So in 0022, the compiler is trying to resolve what you mean by LiquidCrystal::write(0). As there is only one method actually declared as a LiquidCrystal member, it can pick write(uint8_t). It can de-prioritize the virtual write(const char*) that is only in the base class. However, in 1.0, it's more confusing, because write(const char*) is a first-class member of LiquidCrystal due to it not being virtual. So the compiler's choice is no longer obvious. Anyway, you're in the clear for library compat. Just use (uint8_t)0 and you'll be safe in both cases.
« Last Edit: December 20, 2011, 01:41:33 am by maniacbug »
Central MN, USA
« Reply #10 on: December 20, 2011, 10:57:43 am » |
Quite a bit subtle here. I guess this is the actual difference:
Print.h in 0022 virtual void write(const char *str); // Not defined in LiquidCrystal.cpp so unusable by compiler
Print.h in 1.0 size_t write(const char *str) { return write((const uint8_t *)str, strlen(str)); } // Defined in base class so useable by compiler
So the write method with a pointer as parameter is actually NOT a virtual method and has its code, ALTHOUGH, it calls a virtual method (write(const uint8_t *buffer, size_t size)) that is not defined in LiquidCrystal.cpp of either version.
So this little bug is making the compiler ponder whether to call write (const char *) or write (uint8_t), only when a zero is supplied, because other numbers would only be valid when converted into uint8_t, not a pointer but zero is OK for both types?! Just checked with other numbers and it compiles in 1.0 without (uint8_t). Am I passing your interview-round 1? BTW, what is the meaning of _t? I can understand the unsigned 8-bit integer part but not the _t. Thanks!
Guildford, UK
« Reply #11 on: December 20, 2011, 12:02:05 pm » |
I've always assumed the _t bit in C/C++ was for type.
Iain
Seattle, WA
« Reply #12 on: December 20, 2011, 12:29:13 pm » |
Not quite. When the compiler is working on your sketch file, the one with "LCD.write(0)" in it, it doesn't know about LiquidCrystal.cpp or Print.cpp for that matter. It only knows what the headers tell it. Print::write(const char*) is definitely a virtual function. It says so right there in the header  BTW, what is the meaning of _t? I can understand the unsigned 8-bit integer part but not the _t. Thanks!
C99 defined standard fixed-size types, including uint8_t. The suffix "_t" has long been taken to designate a symbol which represents a type. I've never actually seen a written standard which said so, but that's the convention. The idea behind it, and any naming convention really, is so that you can look at a symbol and KNOW what kind of symbol it is. The extreme of this is Hungarian notation, which seems to have fallen out of favor a bit. Anyway you could do something like this: typedef unsigned long something_t; something_t something;
... to define variable 'something' to be an instance of 'something_t'.
Central MN, USA
« Reply #13 on: December 21, 2011, 11:41:37 am » |
Thanks! I think I got this part sorted out. Any other stuff that we should be watching out while migrating the libraries?
Forum Administrator
Cambridge, MA
« Reply #14 on: December 21, 2011, 05:22:41 pm » |
BTW, Serial.write(byte) (and other Print sub-classes) should work in 0022 /0023 as well as 1.0. So if you have code that currently does Serial.print(n, BYTE), you should be able to change it to Serial.write() and maintain compatibility.
