Topic: Binary / Hex counter. (Read 1 time) previous topic - next topic
saramakos
Hi all.  Picked up my board 5 days ago and enjoyed playing with LED chasers and LCD library.  Here is a little test I put together over the weekend for a bit of fun.  All it does is repeatedly count from 0 to 255 in either binary or hex and swaps display mode when the button is pressed.
Hardware setup is jut the LCD example from this site with a button wired onto pin 10.
Feel free to critique (constrictively! :) ) and provide ideas of how this can be cleaned up.  My next step is to move the conversion functions into a library for re-use in future projects.
Code: [Select]
*  Binary/Hex count with mode button.
*  Some code courtesy of arduino.cc, rest is my own!
/* include the library code: */
#include <string.h>
#include <LiquidCrystal.h>
/* Constants */
#define BIN 0
#define HEX 1
#define BUTTONPIN   10
#define MAXVAL      256
#define BOUNCEDELAY 50
#define COUNTDELAY  1000
/* Initialize the library with the numbers of the interface pins */
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
byte countmode;
byte buttonstate;
byte prevstate;
byte current;
long int lastupdate;
long int currenttime;
   /* set up the LCD's number of rows and columns */
   lcd.begin(16, 2);
   /* Configure the pushbutton pin */
   pinMode(BUTTONPIN, INPUT);
   /* Initialise variable values */
   lastupdate = 0;
   prevstate = LOW;
   countmode = BIN;
   current = 0;
   /* Print a message to the LCD */
   printheader(countmode);
   /* Handle the button */
   buttonstate = digitalRead(BUTTONPIN);
   if (buttonstate != prevstate)
       /* Pause to allow noise to pass */
       delay(BOUNCEDELAY);
       if (buttonstate == HIGH)
           /* Switch modes */
           lcd.clear();
           countmode = !countmode;
           prevstate = HIGH;
           prevstate = LOW;
   printval(current, countmode);
   currenttime = millis();
   if (currenttime - lastupdate > COUNTDELAY)
     lastupdate = currenttime;
     current = (current + 1) % MAXVAL;
void tobin(int dec, char *bin)
   byte bitval = 128;
   for (byte count = 0; count < 8; count++)
       if (dec & bitval)
           bin[count] = '1';
           bin[count] = '0';
       bitval >>= 1;
   bin[8] = '\0';
void tohex(int toprint, char *hex)
   hex[0] = hexchar(toprint >> 4);
   hex[1] = hexchar(toprint & 0x0f);
   hex[2] = 0;
char hexchar(char inval)
   if (inval <= 9)
       return inval + 48;
       return inval + 55;
void printheader(byte mode)
   if (mode == BIN)
       lcd.print("Binary Counter");
       lcd.print("Hex Counter   ");
void printval(int val, byte mode)
   char bitstring[9];
   lcd.setCursor(0, 1);
   if (mode == BIN)
       tobin(val, bitstring);
       tohex(val, bitstring);
   lcd.print(bitstring);
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
