Loading...
Pages: [1]   Go Down
Author Topic: Arduino 1.0 with Sparkfun Serial LCD  (Read 986 times)
Cwmbran, UK
Offline Offline
Newbie
View Profile
Hi
In upgrading to Arduino 1.0 I have ammended the LCD.print commands to Serial.write as follows:
Code:
#include <SoftwareSerial.h>
#define txPin 2
SoftwareSerial LCD = SoftwareSerial(0, txPin);
// since the LCD does not send data back to the Arduino, we should only define the txPin
const int LCDdelay=10;  // conservative, 2 actually works
// wbp: goto with row & column
void goTo(int row, int col) {
  Serial.write(0xFE);   //command flag
  Serial.write(col + row*64 + 128);    //position
  delay(LCDdelay);
void clearLCD(){
  Serial.write(0x01);   //clear command.
  delay(LCDdelay);
void backlightOn() {  //turns on the backlight
  Serial.write(0x7C);   //command flag for backlight stuff
  Serial.write(157);    //light level.
  delay(LCDdelay);
void backlightOff(){  //turns off the backlight
  Serial.write(128);     //light level for off.
  delay(LCDdelay);
void serCommand(){   //a general function to call the command flag for issuing all other commands
  Serial.write(0xFE);
  pinMode(txPin, OUTPUT);
  LCD.begin(9600);
  clearLCD();
  goTo(0,0);
  LCD.print("Test String");
This now compiles and uploads, but theres clearly something wrong with my changes because it doesn't clear the display and goTo(0,0); doesnt work, however the "Test String" text is displayed.
Any ideas please?
Thanks in advice smiley
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Why are you writing to the serial port, and expecting the LCD to react, when it is not connected to the serial port?
Logged
Cwmbran, UK
Offline Offline
Newbie
View Profile
I modified this code:
Code:
#define txPin 2
  LCD.print(0xFE, BYTE);   //command flag
  LCD.print((col + row*64 + 128), BYTE);    //position
  delay(LCDdelay);
void clearLCD(){
  LCD.print(0x01, BYTE);   //clear command.
  delay(LCDdelay);
  LCD.print(0x7C, BYTE);   //command flag for backlight stuff
  LCD.print(157, BYTE);    //light level.
  delay(LCDdelay);
  LCD.print(128, BYTE);     //light level for off.
   delay(LCDdelay);
  LCD.begin(9600);
  clearLCD();
  goTo(0,0);
  LCD.print("Hello world!");
Which I found on this page: http://www.arduino.cc/playground/Learning/SparkFunSerLCD
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
So, all the Serial.write()s should be LCD.write()s.
Logged
Cwmbran, UK
Offline Offline
Newbie
View Profile
That just produces an "'LCD' was not declared in this scope." error.
Before changing that the code was making the screen display the text but the "control codes" for the LCD weren't working correctly.
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Code:
This is a global variable.
Quote
Show the code and the exact error message, specifically, the line number.
Logged
Cwmbran, UK
Offline Offline
Newbie
View Profile
My code following your changes reads:
Code:
#define txPin 2
  lcd.write(0xFE);   //command flag
  lcd.write(col + row*64 + 128);    //position
  delay(LCDdelay);
void clearLCD(){
  lcd.write(0x01);   //clear command.
  delay(LCDdelay);
  lcd.write(0x7C);   //command flag for backlight stuff
  lcd.write(157);    //light level.
  delay(LCDdelay);
  lcd.write(128);     //light level for off.
  delay(LCDdelay);
  Serial.write(0xFE);
  LCD.begin(9600);
  clearLCD();
  goTo(0,0);
  LCD.print("Mrs Janet Long!");
And the error messages created are:
Code:
serLCD_Test.cpp: In function 'void goTo(int, int)':
serLCD_Test:10: error: 'lcd' was not declared in this scope
serLCD_Test.cpp: In function 'void clearLCD()':
serLCD_Test:15: error: 'lcd' was not declared in this scope
serLCD_Test.cpp: In function 'void backlightOn()':
serLCD_Test:20: error: 'lcd' was not declared in this scope
serLCD_Test.cpp: In function 'void backlightOff()':
serLCD_Test:25: error: 'lcd' was not declared in this scope
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Quote
So, you made them lcd.write()s, instead. Why?
Case matters!
Logged
Cwmbran, UK
Offline Offline
Newbie
View Profile
Ok thanks for the help smiley
Working fine now smiley
Logged
Pages: [1]   Go Up
Print
Jump to:
