Loading...
Pages: 1 [2]   Go Down
Author Topic: Arduino 1.0 upload issue  (Read 3360 times)
Forum Administrator
Cambridge, MA
Offline Offline
Faraday Member
View Profile
WWW
There are lots of different (and unrelated problems) in this thread.  You might want to start separate ones for your own situation.
Vitor2: it sounds like you've installed a version of the SD library in your sketchbook folder (My Documents\Arduino\libraries) that's conflicting with the built-in SD card library in the Arduino software.  Try deleting it (or moving it elsewhere).
The bootloader on each board communicates at a fixed baud rate.  You want to use the proper rate for that board, which is the one specified for it in the boards.txt file.  Other baud rates won't work.
Have you tried resetting the board just before the upload starts (i.e. as the status bar messages changes from "compiling" to "uploading")?
Logged
Rome, New York
Offline Offline
Newbie
64 year old vacuum tube engineer, obviously a n00b but no apologies.
View Profile
I just built a Nanode and it worked with the usual sample code on Ubuntu 10.10 but not on 11.10, which pukes out the below complaint.
It blinks (LED on pin 6, opposite polarity) when I try to upload, then quits and disconnects the serial port (grayed out) until I re-plug it in again, then it finds the next USB port. Then the same happens again. That is, uploading seems to shut off the port and the next time I plug it in, it goes to the next USB port and tries again, uselessly. The serial loopback doesn't work any more either.
Binary sketch size: 998 bytes (of a 30720 byte maximum)
processing.app.SerialException: Error opening serial port '/dev/ttyUSB3'.
   at processing.app.Serial.<init>(Serial.java:146)
   at processing.app.Serial.<init>(Serial.java:76)
   at processing.app.debug.Uploader.flushSerialBuffer(Uploader.java:75)
   at processing.app.debug.AvrdudeUploader.uploadViaBootloader(AvrdudeUploader.java:93)
   at processing.app.debug.AvrdudeUploader.uploadUsingPreferences(AvrdudeUploader.java:56)
   at processing.app.Sketch.upload(Sketch.java:1603)
   at processing.app.Sketch.exportApplet(Sketch.java:1568)
   at processing.app.Sketch.exportApplet(Sketch.java:1524)
   at processing.app.Editor$DefaultExportHandler.run(Editor.java:2293)
   at java.lang.Thread.run(Thread.java:679)
Caused by: gnu.io.UnsupportedCommOperationException: Invalid Parameter
   at gnu.io.RXTXPort.setSerialPortParams(RXTXPort.java:213)
   at processing.app.Serial.<init>(Serial.java:136)
   ... 9 more
processing.app.debug.RunnerException: Error opening serial port '/dev/ttyUSB3'.
   at processing.app.debug.Uploader.flushSerialBuffer(Uploader.java:99)
Logged
Scotland
Offline Offline
God Member
Have you had your Arduino fix today?
View Profile
WWW
Vitor2 : goto >      Yourinstallpath\arduino-1.0-windows\arduino-1.0\hardware\arduino\cores\arduino
Create a file caller Arduino.h
and in it type :
#include <WProgram.h>
See if this helps.
Logged
Drew.
(MyPCB MANUFACTURING SERVICE)
Duemilanove - UNO - Leonardo - Mega 1280 - Mega 2560 - Pro
& Way too many custom boards.
Rome, New York
Offline Offline
Newbie
View Profile
OK, when I go to see what's on my USB port, I get
 dmesg | grep "ttyUSB*"
[   18.067339] usb 5-1: cp210x converter now attached to ttyUSB0
[  707.645009] cp210x ttyUSB0: cp210x converter now disconnected from ttyUSB0
[  724.898860] usb 5-1: cp210x converter now attached to ttyUSB1
[ 1849.546332] cp210x ttyUSB1: cp210x converter now disconnected from ttyUSB1
[ 1856.855572] usb 4-1: cp210x converter now attached to ttyUSB2
Wait, what? It connects, it disconnects, it connects?? It won't sit still and let me connect. Works worse on Linux Mint Debian. (None of the drivers work on Windows 7.)
Logged
Pennsylvania
Offline Offline
Newbie
View Profile
Agree, similar problems here.  Variously, it changed my default board "randomly" leading to the sync error.  It "lost" my COM port and produced a similar error.  Then it caused the blue screen of death (never had on this machine).  Suspect a comm driver problem.  Besides the other sync error (which I got with the "lost" COM port), I'm getting a new one "no info" below.  Ideas?
Binary sketch size: 14406 bytes (of a 32256 byte maximum)
C:\Program Files\Arduino\arduino-1.0\hardware/tools/avr/bin/avrdude -CC:\Program Files\Arduino\arduino-1.0\hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega328p -carduino -P\\.\COM36 -b115200 -D -Uflash:w:C:\Users\SEEKIN~1.DAN\AppData\Local\Temp\build5997569703067909922.tmp\Drive16.cpp.hex:i
avrdude: Version 5.11, compiled on Sep  2 2011 at 19:38:36
         Copyright (c) 2007-2009 Joerg Wunsch
         System wide configuration file is "C:\Program Files\Arduino\arduino-1.0\hardware/tools/avr/etc/avrdude.conf"
         Using Port                    : \\.\COM36
         Using Programmer              : arduino
         Overriding Baud Rate          : 115200
avrdude: Send: 0 [30]   [20]
avrdude: ser_send(): write error: sorry no info avail
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
to mellis
i have a board with a 2560 that i made, it has the bootloader for the arduio mega2560 on it, from the hardware directory on v22. I use a sparkfun ftdi adaptor to feed the tx0/rx0 on the board. Arduino 1.0 would not upload to it. Used your suggestion to replace the avrdude.exe and avrdude.conf files with the ones in v22. It does now upload. This may help others with this problem.
I have some other problem with my itead lcd not working anymore, but the program starts running. Using ITDB02_Graph16 to drive it, it was working fine under v22. The SD card works fine, just nothing on the lcd.
RD
Logged
Offline Offline
Newbie
View Profile
Arduino Duemilanove ATMEGA328P-PU
with
FT232R1 datecode 1032 (2010 week 32)
CAN upload with Arduino 1.0
with
FT232RL datecode 1138 (2011 week 38)
CANNOT upload with Arduino 1.0
CAN upload with Arduino 0.22
The difference is in FT232R1 & FT232RL.
Logged
Offline Offline
Newbie
View Profile
with
with
The same problem occurred after I downloaded the driver from FTDI
Windows 2.08.17(Beta)
http://www.ftdichip.com/Drivers/VCP.htm
Arduino IDE version 0022 upload is working.
Logged
London
Offline Offline
Newbie
Arduino rocks
View Profile
WWW
Yes, I'm seeing this too.
I have an Old freeduino which works well with V1, but my newer 328 based clone doesn't work at all.  Both work in v.022
Is this a known bug by the team?  (not that I expect them to support clone boards, but I assume it happens on their hardware too)
Jim
Logged
London
Offline Offline
Newbie
Arduino rocks
View Profile
WWW
I found a workaround for this.
Locate "boards.txt" in the "...\arduino\hardware\arduino\" folder and where it says:
atmega328.upload.protocol=arduino
change it to:
atmega328.upload.protocol=stk500
Effectively, this is asking AVRdude to use the older STK500 settings for uploading to the board, rather than the newer 'Arduino' support that the latest version of AVRDude has.  I don't know why, but using the AVRDude "Arduino" upload configuration on Arduino boards (probably only the clone boards to be fair) that use FTDI FT232RL chip doesn't work.  I think it's a problem with AVRDude's support for FT232RL, and nothing to do with the arduino team.
Jim
Logged
Offline Offline
Newbie
View Profile
@Jim - Awesome thanks! I had same problem with a homebrew 328 board which would upload on Arduino-0022 but not 1.0. Quick change in boards.txt and issue was resolved
Logged
Forum Administrator
Cambridge, MA
Offline Offline
Faraday Member
View Profile
WWW
JimThree, hotchk155, and kwankunghkg, did you only see the problems on Windows?  It sounds like it's a slight change in the behavior of the FTDI drivers or hardware that we should be able to fix with a small patch to avrdude (e.g. to change the exact timing / delays in the "arduino" programmer type's reset of the board).  Would any of you be able to try out some alternative versions of avrdude (with the "arduino" programmer type) to see if we can figure out the problem?
I opened an issue for this on the Arduino Google Code site: http://code.google.com/p/arduino/issues/detail?id=869 .  Let's move discussion / testing there so it's easier to keep track of.
Logged
Pages: 1 [2]   Go Up
Print
Jump to:
