Topic: Dog Personality Extender (GPS + Wave Shield Questions) (Read 815 times) previous topic - next topic
Rolento
I'm nearing the end of the semester for my Sensor Based Art class for graduate studies using primarily Arduino equipment, breadboards, etc. so I'm fairly new to doing this, but have had recent experience.
I am focusing on building a vest for my dog to wear that will log GPS cooardinates, and based off if the dog has been in an area before (ie. back at a location already logged within the GPS data log), will speak "I've been here" or "I haven't been here".
I am currently trying to use a GPS Shield on one Arduino Duemilanove and a Wave Sheild on another Arduino Duemilanove.
I am not good at writing programs, but know how it works when I look at a functioning piece of code.
Here's a not so great way of how I want it to work
Quote
GPS Arduino
When Dog is Somewhere
   If ( dog is in same general area as a previous data log then ) {
     Output True or HIGH
   Else {
     Output False or LOW
     Log Location
Wave Arduino
If (True Signal from GPS Arduino ) {
     Play "I've been Here" wav
If (False Signal from GPS Arduino ) {
     Play "I have not been Here" wav
thats the general way I want it to work or think it would work easiest. I am primarily confused what code would work to log, then check the log. Sending a High or Low signal is pretty simple, the rest (primarily all the GPS stuff) is semi confusing.
note: I'm using two Arduinos due to noted conflicts between the libraries of the GPS and Wave Shields.
PaulS
There a number of questions that you didn't answer. For instance, where are you recording where the GPS has been? How are the two Arduinos communicating? What is the criteria for "I've been here before"? The exact same lat/lon value, or some threshold? How big? 10 feet? 10 miles?
Do you know how to read data from the GPS? How is it connected to the Arduino? Which pins does it use?
Do you know how to make the Wave shield play a file?
Quote
Noted by whom?
Rolento
I'm recording where the GPS has been before onto an 2gb SD card into a text file. The two Arduinos would most likely connect via a simple connection of pins sending digital out and digital in signals (basically an on or off state). The criteria for "I've been here before" is in a threshold of an area, which is more close to 10 feet, or even 5 feet if possible.
Quote
I have yet to look exactly at how to read GPS data, but I built the shield for it and ran the example code and it is functioning perfectly. I have yet to be able to check which pins are open/used, though I only need one open for a digital out.
Quote
I've used the example code and reprogrammed a few of the examples with them working (though I am having trouble with one which is working initially, but not playing later). The wave shield is honestly the easiest part of this whole thing, the GPS is the hard part for me.
Quote
Quote
Noted by whom?
I can't find the link right now >_< Basically someone else trying to use both shields had conflicts with the libraries as well as the pins used.
Any help is appreciated so thanks so far  :smiley-surprise:
PaulS
There is a library, TinyGPS that parses the most common GPS output formats, extracting time, lat, long, speed, etc. Comparing a given lat/lon pair with another lat/lon pair is not too difficult (though not exactly trivial, since the distance is not a straight line between two point, unless the distance is relatively small).
Comparing to all values stores on a card is a simple matter of looping, reading a pair from the card, and computing the distance between the current point and the saved point. Break out of the loop if a small enough distance is found. Don't forget to close the file in either case.
The wave shield instructions suggest using specific pins, but they also say that any 5 (or 6?) pins can be used. If there really is a pin conflict, change the pins around. The GPS shouldn't be hardwired to any pins. The wave shield isn't.
Rolento
Huge thanks :)
I'll toss the code around and try my luck at getting the pins to not conflict. I'll post progress if I get this thing working closer to what I need.
