Loading...
Pages: [1]   Go Down
Author Topic: String += not working  (Read 289 times)
Offline Offline
Newbie
View Profile
could someone please test this code on his arduino. It hangs on mine (Arduino Mega2560 R2).
Code:
  const String args[3] = {
    "foo", "boo", "baa"    };
  String result = "";
  Serial.println(result);
  result += args[0];
  result += args[1];
  result += args[2];
That codes hangs after a few seconds. BUT if you replace the
result +=
with
result = result +
everything works fine.
I wonder, as http://arduino.cc/en/Tutorial/StringAppendOperator shows that using += ist OK
regards
Mirko
Logged
Offline Offline
Newbie
View Profile
I tried a few more string-things and had strange results. Can someone confirm that code below, or is that a problem of my arduino?
(Uncomment only one of the lines in the source)
Code:
void setup ()
  String str = "";
  for (int i=0; i<30; i++)
    str = String(str +String(i,DEC));  // works fine
//    str = str +String(i,DEC);  // works fine
//    str = String(str) +String(i,DEC);  // crashes
//    str = String(str+ "-" +String(i,DEC)); // crashes
//    str = String(String(str) +String(i,DEC));  // crashes
//    str = str + "-" +String(i,DEC);  // crashes
    Serial.println(str);
Logged
Miramar Beach, Florida
Offline Offline
Faraday Member
View Profile
Code:
char outBuf[64];
void setup ()
      sprintf(outBuf,"This always works: %d",i);
      Serial.println(outBuf);
Logged
Offline Offline
Newbie
View Profile
Ok, nice workearound, but does not explain why the above crashes or freezes the arduino.
Logged
Offline Offline
Faraday Member
View Profile
One is addition (byte, integer, long). The other is concatenation (string).
It would appear the "+=" does not work with concatenation, only addition.
Logged
Austin, TX
Online Online
Faraday Member
CMiYC
View Profile
WWW
If you look at WString.cpp in the Arduino core files, you will see that concatenation using += is implemented as concatenation.
It works by allocating a buffer large enough to contain the old + new string, then cating it.  This appears to lead to memory fragmentation on ATmegas limited memory and stack environment.
Your workaround works or just treating all Strings as character arrays instead.  This results in much lower over head.  It does require you, as the programmer, to determine ahead of time what size the arrays should be.  Which, in such a limited memory environment, is actually a good idea.
Logged
www.cmiyc.com - A guide to being an Enginerd
Offline Offline
Newbie
View Profile
After changing my code not to use the String class anymore but use char arrays, i ran into another problem
Code:
  char tx[100];
  long TestA = 1;
  word TestB = 1;
  sprintf (tx, "%d %d %d %d", TestA, 2, 3, 4);
  Serial.println(tx);
  sprintf (tx, "%d %d %d %d", TestB, 2, 3, 4);
  Serial.println(tx);
I would have expected the to outputs to be the same, but they are not.
It outputs the following two lines:
1 0 2 3
1 2 3 4
Can anybody explain this to me?
Isn't it possible to use a long or unsigned long with sprintf?
regards
Mirko
Logged
Austin, TX
Online Online
Faraday Member
CMiYC
View Profile
WWW
%d   is an int
%ld  is a long int
http://www.cplusplus.com/reference/clibrary/cstdio/printf/
« Last Edit: December 07, 2011, 09:35:18 am by James C4S » Logged
Offline Offline
Newbie
View Profile
OK, thanx for that info.
I did not know that as i never needed %ld before ;-)
regards
Mirko
Logged
Austin, TX
Online Online
Faraday Member
CMiYC
View Profile
WWW
In that case, you should know that
%u is unsigned int
%lu is unsigned long
Logged
Pages: [1]   Go Up
Print
Jump to:
