Author Topic: That's Alcohol!  (Read 653 times)
Video
Technical details
“That's Alcohol” installation is a prototype for innovative ethylometers to be proposed to italian police in order to prevent drunk-driving. The system is based on a TGS-822 Alcohol Sensor (made by Figaro) that detects the alcoholometric level into the user breathe. The data are collected in real-time by an Arduino board that drives analogically a 24.7 Kg-force servo-motor (Hitec HS 805 BB+) depending on the drunkness-level result achieved. Finally, the servo-motor is connected to a plastic table that pushes through some pistons the string-puppets to let them leaning more or less.
For a stronger feedback, Arduino board dialogues through serproxy with a Flash-based animation that displays step-by-step the results and some suggestions on how to reach a better drunkness-level.
More info
Made by David Boardman, Roberto Pansolli, Pete Knocke (Domus Academy Milan + Interaction Design Institute Ivrea)
+ http://www.netzfunk.org/idesign/idesign-2007-ma-projects/thats-design-salone-del-mobile/
Prototype video
 :o  :o  :o  :o  :o  :o  :o  :o  :o  :o  :o  :o  :o  :o  :o  :o  :o  :o  :o  :o  :o  :o
« Last Edit: May 10, 2007, 08:52:32 am by da5id.b » Logged
berlin
fubbi.com
looking great!
I am looking at using the same sensor for triggering some el-wires
was it complicated to get the sensor calibrated, anything I should be aware of?
Would you mind sharing your script?
Thank you
fubbi
Milano, Italy
Sideralis Arduino!
It's this one the same sensor used by italian police? As I am italian I could install one in my car where I already have an arduino to be aware of the consequences of my night parties... F
Federico - Sideralis
Arduino &C: http://www.sideralis.org
Foto: http://blackman.amicofigo.com
B0100111001000011, USA
I'm confused.  Wait, maybe not..
The problem with installing it yourself is that you know how to uninstall it if you want to drive anyways ;D!
Hi guys, thanks for your comments.
@fubby: unfortunately that script is somewhere lost on an old computer - the project is dated 2007. However, I recall that the code was nothing really complicated.
For the project we used a Figaro sensor that was extremely sensible and accurate. For That's Alcohol project we didn't need to have a precise calibration - the interaction design of the project didn't require it. Anyhow, you can find on the Web different explanations regarding how to calibrate an alcohol sensor. Basically, you just need a glass, water and pure alcohol and some patience. Have fun!
@federico: Of course it is smiley
@all: meanwhile - the project page has moved on another website. Please find it here http://www.tinktank.it/portfolio/contents/exhibition/thats-alcohol/
« Last Edit: July 15, 2010, 03:18:34 pm by da5id.b » Logged
Netherlands
Wow, really cool project. Showed it to my wife and even she liked it smiley-wink (I am usually a bit more appreciative of interactive installations smiley-wink).
berlin
fubbi.com
Hi
yes the script was really simple. However, the pins on the 822 are confusing. I found tutorials for the similar MQ-3 but I have difficulties translating those to the 822.
Do you remember the pin order by any chance?
thanks
@Meinaart: thanks to you and your wife.
@fubbi: yes, I remember the sensor pins handling was quite a pain in the a**. Remember to insulate each pin connection to avoid surprises.
You may want to have a look to the TGS822 datasheet www.figarosensor.com/products/822pdf.pdf
The part you are probably more interested at this point is the "Basic Measuring Circuit" (page 2).
Good luck.
berlin
fubbi.com
I got it hooked up and it reading fine. How hot did yours get? Mine is pretty hot, a little scary...
using a 1k resistor
fubbi
« Last Edit: July 16, 2010, 07:14:20 am by fubbi » Logged
The sensor runs optimally at a certain temperature. In fact, it needs a Vh (heating) to work properly. I remember it was heating up quite a lot in the installation. However, the sensor stayed for 3 days in an warm environment with a poor air flow - and nothing really happened, besides some unexpected values that sometimes popped out (abnormal high or low values). Here some programming effort would help you to normalize the received data.
