Topic: Arduino "1" software problem with programing a ATtiny85 (Read 1 time) previous topic - next topic
balam
I trying to program a  ATtyny85 using a Arduino  board
with  arduino IDE version 1  and gives compile errors,  (  OUTPUT  is not declare )
after trying few solutions I decided to  download arduino .22
and  give a try,  and it works.  if you guys have an idea of how to fix this issue is very welcome
links to  program a  attiny85
http://hlt.media.mit.edu/?p=1229
http://provideyourown.com/2011/arduino-program-attiny/
Onions
I wrote some cores for the ATtiny85, designed specifically to work in the beta IDE. Give it a go and tell me if they work. :D
http://arduino.cc/forum/index.php/topic,79190.0.html
Onions.
My website: http://www.harryrabbit.co.uk/electronics/home.html Up and running now! (Feel free to look round!) :D
balam
thank Anions
i just try your cores  and did not compile  Here is the error
LIGHSENSOR_at86.cpp:1:21: error: Arduino.h: No such file or directory
LIGHSENSOR_at86.cpp: In function 'void setup()':
LIGHSENSOR_at86.pde:-1: error: 'OUTPUT' was not declared in this scope
LIGHSENSOR_at86.pde:-1: error: 'pinMode' was not declared in this scope
LIGHSENSOR_at86.cpp: In function 'void loop()':
LIGHSENSOR_at86.pde:-1: error: 'analogRead' was not declared in this scope
LIGHSENSOR_at86.pde:-1: error: 'LOW' was not declared in this scope
LIGHSENSOR_at86.pde:-1: error: 'digitalWrite' was not declared in this scope
LIGHSENSOR_at86.pde:-1: error: 'HIGH' was not declared in this scope
Onions
:( I'll try and fix that. Thanks for the feedback!
balam
awesome
let me know when is ready and I will tested
more than happy to help.
Onions
using a Arduino  board with  arduino IDE version 1
Wait, by version 1, do you mean the Non-beta version 0001, or the beta version 1.0? The cores will not (should not) work with the non-beta version.
Onions.
balam
I thinks is finaly
http://arduino.cc/en/Main/ReleaseNotes
Onions
I'd be suprised if it worked, but I've chucked together a ~3500 line core file. I will carry on working, but it could work...
Onions.
balam
will try it soon
keep me update if you have new compiles
balam
I had the same issues with V1
trying to find a  direct programmer came across with  fabisp  from Mit
from there I got a link to   this new tutorial
http://hlt.media.mit.edu/?p=1695
hope it helps
Onions
If the code fails to compile with every ATtiny core, it could be that you set the core up wrongly? Simply extract the .zip file into the hardware file in the arduino file, then open up the IDE. If that's what you've done, then I'm out of iteas... :(
Onions.
balam
Hi Onions
this what I have done in the past with arduino .22 and it works
and I did the same with  arduino v.1
unzip file
move to hardware folder inside  arduino folder (  path on  preferences on arduino software)
fireup  arduino software
etc. etc. etc.
perhaps the problem may be in serialsoftware on arduino software
the attiny85 runs at 1xhrz
I think that arduino serialsoftware likes minimun 5xhrz.
