Loading...
Pages: [1]   Go Down
Author Topic: How to open correct file in a list of files using "name + number" in filename  (Read 317 times)
Hamme, Belgium
Offline Offline
Sr. Member
View Profile
WWW
Having multiple files on an SD card, I can't seem to figure out how to open the correct file. Let's say I have 256 files like this:
Code:
ajob1.txt
ajob2.txt
ajob3.txt
ajob256.txt
Now the number is the ID I get from somewhere else:
byte ID = x
for (int x = 1; x < 257; x++)
then my filename is something like ajob ID .txt
but how do I get to replace the ID by the number so I can use this
Code:
myFile = SD.open("ajob ID .txt");
  if (myFile) {
    Serial.println("ajob ID .txt:");
    // read from the file until there's nothing else in it:
    while (myFile.available()) {
    Serial.write(myFile.read());
    // close the file:
    myFile.close();
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Code:
int jobNumber =14;
char fileName[12];
sprintf(fileName, "ajob%d.txt", jobNumber);
will result in fileName containing "ajob14.txt", which can be used as an argument to SD.open().
Logged
Pages: [1]   Go Up
Print
Jump to:
