Topic: processing arduino program (Read 1 time) previous topic - next topic
abdelkhalek
hello all,
i'm trying to follow this tutorial to send feeds from my arduino to pachube http://community.pachube.com/?q=node/12
but the processing sketch always shows 0.0 as sensor value
i tried reading the value in firmata test application and it worked correctly ( that meens the circute is ok and the firmata is loaded correctly)
i'm using arduino demillanova and firmata library 2.2
this is the processing sketch:
Code: [Select]
import processing.serial.*;
import cc.arduino.*;
Arduino arduino;
float myValue;
println(Arduino.list());
arduino = new Arduino(this, Arduino.list()[0], 115200);
void draw()
myValue = arduino.analogRead(0);
println(myValue);
PaulS
The analogRead() function returns an integer value in the range 0 to 1023. Why are you storing the return value in a float.
You print a list of serial ports. You connect to the first one in the list. You might say something about the list printed, and whether your Arduino really is attached to the first port in the list.
abdelkhalek
thanks for the reply
actually my arduino is connected to the second port, so i changed it
and changed the float variable to integer baut i still get the same result
PaulS
What kind of Arduino do you have?
abdelkhalek
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
